Thread Tools
Old 15th March 2007, 17:37   #31 (permalink)
hydrashok's Avatar
Originally Posted by clipto333 View Post
can anyone explain how to set gains using a multimeter? or is there any other way to set the gains properly?
Rishabh, I've replied to the same post you made in the "Car Audio Advice from the gurus..." thread
__________________
Alpine 9887 | TRU Tech S44 | Image Dynamics XS65 | Image Dynamics IDQ12 D2V2 | Connection Audison
Old 15th March 2007, 18:55   #32 (permalink)
Steeroid's Avatar
in the wire between the Hu and the speaker +ve terminal.
So if I've fixed new speakers without changing the OE wires (yeah you can talk about it over a few beers at the next ICE meet) then this 'bass blocker' (what is it?) still exists?
__________________
Steer
Petrols Suck. Diesels Torque. Q.E.D
Steeroid is offline   Reply With Quote
Old 15th March 2007, 19:29   #33 (permalink)
vid6639's Avatar
nope the bass blockers are usually with the speakers generally. so there shouldn't be a problem for you.
__________________
\ / ][ |) `/ [_] "!"
vid6639 is offline   Reply With Quote
Old 16th March 2007, 01:09   #34 (permalink)
Rahulk76's Avatar
Hi Audio Experts
I am in Bangalore for some official work and will be going back to Pune tommorow...
Out of the blue, I went to Sebastian and Sons and met Zac there for some decent speakers for my dicor...
He suggested to go for, compos in the front(6k) and coax(3.2K) in the back..
Now please suggest the following
I am looking for good sound.....i mean the clarity like when you you put of headphones (or nearly like that in the budget of 15k)
Que1 :::: Shall I go for the Blaupunk offered by dealer ( i heard that its quality is comparable to alpine) If so then what least model shall i query for from the dealer to support this configuration of speakers?
Ques2:::: What is the actual size of the speaker in the doors (5 1/4 or 6 inches) dealer said 51/4 and some mentioned in the thread 6 so i am confused
Ques3::: Is it ok to go for Blaupunk coax in the rear and boston compo in the front.
Ques4:::What amp are required if any ?
No sub as for now...
Rahulk76 is offline   Reply With Quote
Old 16th March 2007, 11:10   #35 (permalink)
navin's Avatar
not nessacrily. the bass blocker can be anywhere in the speaker wire. It is best to check the wire to see if it still exists. I myself once installed a bass blocker at the HU end of the wire. I did not want too many wire joints in the door.
__________________
Scixelsyd Etinu
Old 16th March 2007, 11:15   #36 (permalink)
navin's Avatar
Originally Posted by Rahulk76 View Post
Hi
a) Did you like the sound fo the Blaupunkt?
b) I think, you can install 6" with a spacer.
c) THere are no absolutes in audio. Install what sounds good.
d) An amp will offer better control over the speakers this is espicially noticeable in the midbass (the 6" speakers you are using wont produce much low bass) if your budget permits it go ahead. If your budget is fixed at 15K I'd suggest just getting a good HU for 7K and 2 pairs of coax for 8K.
__________________
Scixelsyd Etinu
Old 16th March 2007, 16:06   #37 (permalink)
clipto333's Avatar
hi,
sorry hydra it was a mistake. also this post didnt show up for quite a few minutes. so i posted it there
thanks
rishabh
clipto333 is offline   Reply With Quote
Old 17th March 2007, 21:30   #38 (permalink)
Rahulk76's Avatar
A. I used Kenwood before, but i hear that Blau is a better quality and in equla terms with Alpine ( am no expert on these matters) all i want is a clear sound and a tight bass
B. I think ill go with 5 1/4 as i dont want the speakers to be protuding as kids will poke their fingers into them
C> here is what dealer has offered
All Blaupunk
Headunits
Bahamas mp46->10,900/-
Maui/Montery -> 9750/-
Speakers
A Pair of GTX 132, CoAxials -> 1900/-
A Pair of TH 132, Components ->4250/-
Wiring - Approx 300-500.
As i dont have a good idea, but is this good setup along with the price ?
Old 20th March 2007, 13:30   #39 (permalink)
navin's Avatar
Headunits
Speakers
I'd focus a bit more on the speakers and a bit less on the HUs.
Say if you are spending 15K, equal ammounts on the HU and 4 speakers.
Also consdier other brands and keep in mind that the Safari's cabin can sound bass shy without a subwoofer (cheapest sub-amp combo will cost 8K).
__________________
Scixelsyd Etinu
Old 21st March 2007, 16:18   #40 (permalink)
Su-47's Avatar
Drifter,
Sorry for Hijacking your thread. I am also planning to do some low-budget ICEing on my safari and thought it would be better to discuss it here rather than opening a new thread:
Gurus,
I am interested a basic ICE setup for Safari (12-14K). Before everyone redirects me to the sticky, here are my specific requirements:
The system should have decent mid-range performance. Good on vocals, and if possible good on Bappi Da's music from 80s.
A couple of more observations which might help the gurus in shortlisting stuff :
While listening to music at home I always keep my Onkyo amp in “direct” mode with all fanciful DSP turned off. I am ok with the bass-performance of Polk-Audio R-15 bookshelfs (though the midrange could’ve been better). The sub is *always* off. I might be deaf for lower frequencies.
I hate car-tweeters that fire on the face. Actually, I dont like too much of high frequency sound. I might be extra sensitive here
A couple of days back I heard the following configuration on a friend’s Qualis:
HU - Pioneer DEH-2950MP
Front: JBL 6x9" oval GTO-927
Rear: JBL 4" CS-2104
I noticed that the rear speakers (mounted in the luggage area) seemed out of sync with the front ones (some kinda phase delay). I think this issue might be because of the huge difference in relative distance of the front and rear speakers from the driver’s seat. (The same system sounded Ok in an Alto).
How do I avoid such a thing in the Safari. I am thinking of installing a speaker in each of the four doors. Whats the maximum size of the speakers that can be fitted on Safari’s doors? And which ones?
If possible, I would like to avoid buying an amp and a sub. So, given my constraints and likings, can the gurus suggest a HU (with decent inbuilt amp) and a good set of speakers?
Thanks,
Su-47
__________________
Never wrestle with a pig, for if you do, you will both get dirty, but the pig will enjoy it - Charlie Munger
Su-47 is offline   Reply With Quote
Old 21st March 2007, 16:45   #41 (permalink)
navin's Avatar
Originally Posted by Su-47 View Post
[b]
Audio being subjective we really cant recommed specific brands but since you claim you prefer a recessed HF I would suggest you consider brands like Infinity, Alpine, etc. I dont know however which of these will fit your budget.
Your friend installed 6x9s in the front (I assume they were 937)? where? how? Did he have the tweeter level on high or low (the 937 offers the user to change tweeter level by about 3db)?
As far as the phase issues are concerned you can reduce this by getting a HU that has Time Alignment. These HUs are not the cheapest. I would guesss than they'd cost upwards of 10K.
I would consider using 6" speakers in the front and rear instead of the 6x9 and 4" combo your friend used.
__________________
Scixelsyd Etinu
Old 21st March 2007, 17:31   #42 (permalink)
Su-47's Avatar
Ok lemme try Alpine and see if it is worth the extra $$$. BTW, is Sony as good as Pioneer when it comes to HUs?
My mistake. It has 6X9s in the back and 4" in the front.
Thank you! Hope I am able to fit these on the doors.
__________________
Old 21st March 2007, 20:37   #43 (permalink)
low_bass_makker's Avatar
i would any day prefer a pioneer and a alpine HU against the sony.....leave the sony behind....they "its a sony" thats it end of story.....
ya one can easily fit a 6.5 inch drive in the front door easily.....
low_bass_makker is online now   Reply With Quote
Old 18th June 2007, 23:46   #44 (permalink)
Gurus, I have a similar need.
I have a Pioneer 4950 HU in my Safari with some local speakers made into a box, kept at the back. I want to change that.
Please suggest as to what I can do for a max of 8k.
4 speakers?
What size?
Which brand and model?
I need CLEAR sounding audio, thats it.
__________________
Proxima
2004 Safari LX
2008 Pulsar 180
Proxima is offline   Reply With Quote
Old 19th June 2007, 00:34   #45 (permalink)
plain and simple go for jbl coax in the front and 6x9 in the rear in a small box so that they can produce some thump also
Thread Tools
Suspension setup Safari Dicor 3ltr v/s 2.2 ltr PAVAN KADAM Technical Stuff 13 13th May 2008 14:49
My Safari 3.0L - Help me with the ICE setup Su-47 Ask the Gurus 20 2nd November 2007 13:03
Elantra ICE Setup 1self Sound Off and Show Off 78 19th October 2007 02:59
ICE Setup for Swift prashant.dinkar Ask the Gurus 5 11th October 2007 13:20
ICE setup minus the HU ! jkdas Ask the Gurus 16 28th December 2006 10:48
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
