Thread Tools
Old 9th April 2007, 18:18   #1 (permalink)
Default Help Needed : JBL 1000 10" subwoofer in a tube
Dear Gurus,
I need help with an issue with my new ICE set up :
I am experiencing a booming & jarring noise coming from my subwoofer tube encloser which is kept in the boot of my NHC ..This 'booming' noise that emanates from the SW is very disconcerting & the only option is to switch off the subwoofer.
Could anyone please tell me why this is happening..I, in the first place was not toO keen on getting a SW in a tube & wished if it could have been a box (conventional SW set up) but the dealer insisted the tube set up..Could it be because there is no damping materail used in the boot..Please let me know the remedy & how to get around it?
Ash
AshOnTheRocks is offline   Reply With Quote
Old 9th April 2007, 18:35   #2 (permalink)
low_bass_makker's Avatar
one could any day can take out the sub from the tube and put it in a sealed enlcosure to get the good sound.......
about the rattle there must be some thing loose in the boot of your car...like any car part also.....not the tube only....
Old 9th April 2007, 18:36   #3 (permalink)
revtech's Avatar
firstly you should have got what you wanted cause your paying for it.if you were getting it free its another thing.
any way check the gains on your amp also make sure bass boost if off or set it really low. and what are you settings on your HU ?
set your LPF to 60-80 HZ make sure LOUD is OFF.Bass the lesser the better.as prefered by you.
rev
__________________
Revin Beyond Limits !!
revtech is offline   Reply With Quote
Old 9th April 2007, 18:38   #4 (permalink)
Technocrat's Avatar
I am no expert BUt will try. What is your HU & what settings are you running for your Sub. Also if am not wrong then probably the amp might not be configured correctly for sub. Some one correct me if I am wrong.
__________________
The Holy Trinity: Traction, Torque and Tarmac
Old 9th April 2007, 19:43   #5 (permalink)
L_B_M : As I am looking for good, tight, low bass (pun unintended :-) !) , I would go back to the dealer for sub in a sealed enclosure solution. Then hoping the 'boom' will diappear..what do you think?? Also how & where do you think the sub in sealed enclosure should get installed in the boot?
Revtech : HU is set at low bass boost. LPF set at 80 Hz (should I lower it to 60 Hz..will try) & LOUD is OFF always. Almost all the settings are towards the lower level of the equaliser.
Technocrat : HU is Pio 6990 I think.(sound is little bright for my liking) & amp (JBL cs 604.3 is configured for low bass & not for loud bass. Will still get it rechecked to make sure the config is appropriate..
Old 9th April 2007, 20:15   #6 (permalink)
Bass&Trouble's Avatar
There is a member on this forum called abhibh and you are AshOnTheRocks. Together, you can form Team Bhp's very own AbhiAsh!
Back to your problem. Before you change the enclosure and all, place the sub in the passenger cabin on the rear seat and listen to it. If it still distorts, then it has something to do with the sub or its enclosure, otherwise its something else rattling in the trunk.
__________________
Operator! Give me the number for 911!
Old 9th April 2007, 22:51   #7 (permalink)
This simple test will tell you where the fault is....please try it before changing anything..........
Old 10th April 2007, 00:09   #8 (permalink)
Hi B&T, Ash here, Abhi is missing!! (Aw Abhi where art thou??!!)
Thanks so much for such a lovely input..The beauty of a great thought is when the recepient wonders why he coud not think of it..This is one such thought..No seriously..I will do this 1st thing tomm.morning & report later in the day..
Thanks & Cheers
Ash
Old 10th April 2007, 00:33   #9 (permalink)
esteem_lover's Avatar
Infractions: 0/1 (5)
Thats what our B & T is famous for. Lovely inputs. LBM is good in the output section, i heard. right, LBM ?
__________________
Goodbye Dada, you made us proud.
Old 10th April 2007, 12:28   #10 (permalink)
Sir which output we are talk here about..........
Old 10th April 2007, 12:41   #11 (permalink)
LBM I think he's talking about your car's anticipated amplifier output when its ready to rock n' roll . Offcourse I can be wrong !
Thread Tools
Pio 3050UB (2 RCA) + JBL 4Ch GT5-A604 = HOW to GET A SubWoofer "DILEMMA" svsantosh Ask the Gurus 11 4th October 2008 09:41
Suggestions for "Tube" upgrades for my Zen amtak Tyre & Alloy wheel Section 3 13th December 2007 14:13
For Sale - JBL Bass Tube Revvhead Shifting gears 8 18th July 2007 09:32
"Tube type" tubeless tyre vRS Tyre & Alloy wheel Section 4 8th March 2006 23:39
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
