Thread Tools
Old 2nd May 2007, 13:05   #46 (permalink)
navin's Avatar
Originally Posted by DerAlte View Post
Actually I am searching for drone units with just the cone, surround, spider and frame, which I can experiment with in a custom box.
and pray i ask how do you intend to get this drone cone to resonate?
__________________
Scixelsyd Etinu
Old 3rd May 2007, 00:59   #47 (permalink)
DerAlte's Avatar
Media Markt is cheap but no place for a real audition
I agree. But, it is the convenience of everything under one roof that attracts one to MM. And a decent range to compare - and they leave you to yourself if you want to play around.
If you remove the magnet and voice coil what you will get is a Passive Radiator and a PR needs a sub that has a voice coil and magnet in the same box. a PR (drone cone) is simply a cone with a low Fs and which resonates using the back wave of another woofer.
That, Sir, is exactly what I want - to build a Bass Reflex box!!! The woofer shall be - depending on what size PR I get - an IDQ8 or IDQ10. In the dark ages I had mated a Phillips full range 8" with another with a kaput coil and Bolton tweeters in a teak box - oooohhh! No sir, no tube amps like you, just some home-made Class A stuff with 2N3055's. With a Shure cartridge skimming the surface of the vinyls - sheer ecstasy without substance abuse!!!
This time around no 2N3055, but perhaps a 5-ch amp to drive the BR cabinet and new Infinity References as Sam described.
Originally Posted by Sam Kapasi View Post
But Infinity is rediscovering itself. With the new reference series.
They surely haven't changed their website, which nearly as bad as the Image Dynamics one.
The new reference series (look for the XX23i ending) are positively astounding for the money. The other bit of news is that Infinity has finally produced 2 infinity sounding amplifiers (designed and engineered by infinity). Indian consumers should be able to lay their hands on an Infinity 4X75 amplifier and a 600X1 monoblock, both from the new ref series, in about 2-3 weeks.
My answer to your direct question is indirect. Listen to the new ref 2 way components. You might be surprised.
tell me where I can audition them. Need help locating: Couldn't find any reference to the XX2Xi anywhere - closest I found anything was Ref 5020CS.
The ones that I heard at MM were 5010CS - I guess they are the old ones, but nevertheless very sweet.
I am willing to wait another few weeks to see the new amps and the Refs, hope Sound Factory puts them up soon
__________________
Never believe it cannot be done - it's only that you haven't found out how!!!
Old 3rd May 2007, 13:53   #48 (permalink)
navin's Avatar
That, Sir, is exactly what I want - to build a Bass Reflex box!!! The woofer shall be - depending on what size PR I get - an IDQ8 or IDQ10. ...No sir, no tube amps like you, just some home-made Class A stuff with 2N3055's.
Your woofer's dia has nothing to do with it. In fact i am a big fan of he Nestorovic aligmnet in PR boxes.
A quote of mine from another time and place
diyAudio Forums Archive - Indian equivalents of the following DIY items.
"ok......here goes.....
a) addiing weight to a PR does TWO things. it lowers Fs by increasing MMs and it also lowers sensitivity. I have done some work with this sort of bass tuning (as well as others like using changable ports in bass reflex boxes, aperiodic vents in sealed boxes, etc...).
b) what you will find that for every room and for every genre of music in fact for every album a different bass tuning sounds best. You can drive your self nuts changing the tuning for every album or atleast for every producer (some producers like Alan Parsons are quite consistant).
c) my recomendation is to try the PR as supplied and then if the bass sounds over blown add weights 5gm at a time till the bass is noticed only when it absent. Then u will get a tuning that is good for music. If you want to use the sub for HT you do the same with a few properly recorded soundtracks"
here are some links that can help
http://www.avahifi.com/root/audio_ba...pdf/ab1984.pdf
Subwoofer DIY Project Peerless 12" XLS dual passive radiator system "Adrians Thunder Box"
Nestorovic
and you can even download the patent here
Low range loudspeaker system - Patent 3984635
enjoy.....
http://www.fortunecity.com/rivendell...d/dddllqd.html
__________________
Scixelsyd Etinu
Old 3rd May 2007, 13:53   #49 (permalink)
navin's Avatar
BTW who told you about my tubes amps et. al.?
The 3055 is nice, a very flexible transistor. did you parallel it or only une it push pull or did you (lump in thorat) do a 3055 SE?
__________________
Scixelsyd Etinu
Old 3rd May 2007, 20:51   #50 (permalink)
Sam Kapasi's Avatar
I feel your emotion Old man. I used to look everywhere for Motorola 2N3055 and build everything from them, right from reg power supplies to power amps. I miss them already.
I think they already have the new speakers. Amplifiers should be in, in a week or so.
__________________
Live the YetiLife®
Old 4th May 2007, 00:59   #51 (permalink)
iraghava's Avatar
Wait till Elfy reads this one
__________________
Power corrupts. Absolute power is kind of neat.
Old 4th May 2007, 01:04   #52 (permalink)
DerAlte's Avatar
Sir aap mahaan hain sirji!!! I wish I could find the smiley for "egyptian syncopatic raising and lowering of both arms kneeling on the ground". Or maybe the smiley set on the right should include one for "You rule!"
I am inspired now. Ich bedanke mich vielmal, mein Herr.
Kya sir, aap bhi! Khud likhein aur poochhein ke kisne kaha?
Normally Class B Push-pull, fed by 186/187 or 286/287. Ishtandard 8ohms drivers. A couple of paralleled Class A. Got married after that, khallas! I must be still having a few 3055s and even AD149s (20Wrms Class B, remember?) in a box in the basement that has escaped the lady's broom.
Thanks, Sam. I will have a look (hear?) asap.
No, not the one that Elf maintains in India, but the original infinitysystems.com website. They could really use Elf's services.
__________________
Old 4th May 2007, 11:33   #53 (permalink)
navin's Avatar
Der Alte,
I only wondiered becuase you have about 20 posts to your credit and did not kow you have read my older posts. Yes I have discussed EL84/34, KT 88 based amps etc.. on this forum.
Thank you for the compliments. Let me know if you need more info.
I only suggested Nestorovic becuase it seemed like a good idea for your application. Of coruse you can use the standard PR tuning as well.
__________________
Scixelsyd Etinu
Old 4th May 2007, 11:39   #54 (permalink)
clipto333's Avatar
hi deralte,
what's ERGO??
cheers
rishabh
clipto333 is offline   Reply With Quote
Old 4th May 2007, 12:09   #55 (permalink)
Sam Kapasi's Avatar
Ergo is an english word.
It is adopted from Latin, along with many other middle english words.
Though in meaning it is similar to the word "therefore", it is a a more literate and quality expression and cannot be used in every circumstance and sentence, in place of therefore.
Let me know if you want examples.
__________________
Live the YetiLife®
Old 4th May 2007, 14:17   #56 (permalink)
clipto333's Avatar
hi,
thanks sam for letting me know. wouldnt mind the examples.
cheers
clip
Old 4th May 2007, 14:45   #57 (permalink)
v1p3r's Avatar
Cogito, ergo sum. Literally, I think, therefore I am. Some very important Frenchie.
__________________
I've lost my phone. Please PM me your phone number if I'm on your contact list.
Old 5th May 2007, 17:14   #58 (permalink)
DerAlte's Avatar
Originally Posted by rishism View Post
Sorry DerAlte, all but you have been allowed to answer the query.
Another time mi amigo.
ism; By example, would be a good way to go.
Most welcome! I learn more by allowing others to speak.
But "ism; By example, would be a good way to go" was full OHT! ??
__________________
Old 24th March 2008, 17:59   #59 (permalink)
gunbir's Avatar
Infractions: 0/1 (4)
Cool
Sir, I'm pleased to inform you that someone heard your complaint. Check out Image Dynamics USA
Cheers!
__________________
Often imitated, never duplicated!
Old 24th March 2008, 20:58   #60 (permalink)
DerAlte's Avatar
Thanks, Gunbir. At least they have made a good beginning, though they have a lot of information to put in (specs mostly). The current text is still confusing, e.g. it is not apparent till you read the right side bar to know the difference between CXS62 and CXS64.
Still a long way to go to reach the website efficiency of JL Audio - currently they are the best organized (no comments on their wares), followed by DLS. Focal and Hertz are way too artistic to be ergonomic, though their info content is good.
__________________
Thread Tools
Rock On for Humanity Concert. X-Machine Shifting gears 3 16th October 2008 17:38
Looking for a Banquet Hall in Bangalore (to host a reception) androdev Shifting gears 24 21st May 2008 15:38
Amar Bose in US Inventors Hall of Fame Nikhilb2008 Gadgets, Computers & Software 21 14th March 2008 15:19
Who's Gonna be at The Bryan Adams Concert?? Maverick5490 The Team-BHP Meet Section 1 1st February 2006 00:11
What happens at a rock concert if it has free entry !!! varun_patra Shifting gears 0 31st January 2006 16:38
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
