Thread Tools
Old 15th April 2007, 20:29   #1 (permalink)
Default WagonR LPG Audio Phase-2 Help
Hi Guys,
I have a WagonR LPG. My current setup is
Pioneer 6850
JBL CS2104 - 4''
JBL 937 - 6x9s
I want to add a woofer and amp into the setup. A friend of mine suggested getting Blaupunkt THW1200, thin sub woofer under the passengers seat. With some amp under my seat.
1. Suggestions for AMP
2. Suggestions for Setup
3. Suggestions for Installers in Hyd. Couldn't find any decent ones.
Thanks in advance,
smokie is offline   Reply With Quote
Old 16th April 2007, 03:13   #2 (permalink)
Sam Kapasi's Avatar
I do not think the wagon R passenger seat has the place to accomodate any woofer. You may fit an amplifier under the seat but not a subwoofer. You would 100% have to put an enclosure in the boot of the car.
__________________
Live the YetiLife®
Old 16th April 2007, 03:29   #3 (permalink)
manikjeet's Avatar
but how will he put a box in the boot with the spare wheel in place
first he has to find a way of getting ride of the spare wheel so he can put a box
__________________
MANIK NANDA
manikjeet is offline   Reply With Quote
Old 16th April 2007, 11:58   #4 (permalink)
Hey guys,
Thanks for the responses. Sam, the woofer won't fit why? Because of the depth or the radius?
The Blaupunkt woofer is only 2.5 inches in depth. If its the radius, then I can get the 10 incher, THW1000.
Getting RID of the spare wheel is not an option. Secondly, I don't want a woofer on top of the LPG tank.
Any ideas?
Old 16th April 2007, 12:46   #5 (permalink)
hydrashok's Avatar
smokie, I don't think you can get away with a box of a depth of less than 6in bare minimum. Then again a clearance of about 1" over the box (and the cone) would be nice to have. Do you have a minimum of 7" under your seat? And I guess a minimum width of 12" would be needed even for a 10" sub. Do you have that much?
And are the TX subs available still? Are you getting them in India, or from abroad? I have been under the impression (I could very well be wrong) that the TX subs were not made available in India at all.
I also feel a box in the boot would be the only option. If you don't want to place the sub in the boot, or on the LPG tank (It is where the spare tyre normally is, right?) I guess getting an Infinite Baffle setup on a parcel tray would be the only other option. It would be a bit difficult to get it done well, but I think a good installer will be able to do it. But you will lose a lot of boot-space as most IB setups would have a fixed parcel tray that cannot be lifted or removed. And again, if the bottom of the rear seats are open to the boot, IB may not work. Then a box would be the only way.
__________________
Alpine 9887 | TRU Tech S44 | Image Dynamics XS65 | Image Dynamics IDQ12 D2V2 | Connection Audison
Old 16th April 2007, 13:20   #6 (permalink)
esteem_lover's Avatar
Infractions: 0/1 (5)
I think a box could be accomodated in the boot. There is ample space on the right side.
__________________
Goodbye Dada, you made us proud.
Old 16th April 2007, 14:14   #7 (permalink)
sys_whiz's Avatar
I believe building a fiber glass enclosure in the right side space will help in this case. And will look nice too.
sys_whiz is offline   Reply With Quote
Old 8th May 2007, 14:22   #8 (permalink)
ramki067's Avatar
smokie, Can u post some pics of the audio setup of your WagonR. It would be much useful to others.
ramki.
ramki067 is offline   Reply With Quote
Old 22nd June 2007, 19:37   #9 (permalink)
Do wagonRs come prewired for audio, like indicas? And is there provision for sepakers ? If so where? Dash? Front door? Rear? (Where)? Indicas have parcel tray as standard, and provision / wiring for speakers in rear parcel tray.
(thinking of DIY - hence the question)
Old 22nd June 2007, 21:39   #10 (permalink)
speedzak's Avatar
Location: Delhi. Travelling as usual! Mumbai was great.
Infractions: 0/1 (4)
WagonR has speaker provision in the dash. It is a 4" size. It doesn't come pre wired for audio. But you don't have to take too much trouble for the powering of the stereo as the power from the battery to stereo comes from the factory itself.
For speakers, you will have to do some wiring.
The rear speakers are normally fitted on an extra parcel tray or fitted on the boot door. I would prefer a Parcel tray made of MDF.
__________________
A very big THANK YOU, Bombay!
Will miss you guys! :(
speedzak is online now   Reply With Quote
Old 23rd June 2007, 10:14   #11 (permalink)
DerAlte's Avatar
Don't WagonR's come with top-of-dash mounting (grills near A-pillar, firing into the windscreen)? The Mandovi Motors Blaupunkt demo vehicle - a WagonR - that I had seen had Blau OD co-axials (5.25/6.5) mounted there, and that was sounding quite nice with a good sound stage. (Had a fundu Blau HU with in-dash LCD the guy said costs 1.25L!)
__________________
Never believe it cannot be done - it's only that you haven't found out how!!!
Old 23rd June 2007, 10:22   #12 (permalink)
DerAlte's Avatar
The space available can accomodate about 0.4cft box. Even 10" thin subs like the ones from Pio need about 0.8-1cft, not good enough. It would be possible to put 8" ID subs in a 0.4cft box, but that would be decent SQ, not boomy SPL.
For that there is no substitute for the boot area. Depending on the listening choice, a 10" sub tube may not take much space if hung behind the back seat, but still give decent SPL.
__________________
Thread Tools
LPG Conversion woes in WagonR aks_karthik Modifications & Accessories 7 20th June 2008 13:44
WagonR LPG: The next Indian Taxi? DCEite The Indian Car Scene!! 22 29th March 2008 18:09
WagonR - LPG or CNG? imran_kasu Technical Stuff 9 18th July 2007 00:03
xeta CNG vs WagonR LPG tushar79 Hatchbacks 23 18th October 2006 14:11
WagonR LPG Launched Kool_Kid The Indian Car Scene!! 33 23rd July 2006 12:33
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
