| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #16 (permalink) |
| Senior - BHPian | @nura, SK456 has installed 3-ways in his Santro in the same way you've described. There were pics posted someplace by JKDas, but I can't find them now. (I think there were in l_b_m's "Saga of L-B-M thread). If you plan on selling the car without the ICE, it would make a lot of sense to get custom door panels done. Since the Santro has straight door panels, MDF will do just fine (fibreglass will not be needed). Or, you can cut the OE panels, but sell the car with a pair of second hand 6.5" speakers (you can get them when you sell the car) in the provision you've cut. Whichever suits you ![]() Modification of the baffle/provision in the dash may not be needed, as it is not affected by any other driver.
__________________ Alpine 9887 | TRU Tech S44 | Image Dynamics XS65 | Image Dynamics IDQ12 D2V2 | Connection Audison |
| | #18 (permalink) | |
| Senior - BHPian Join Date: Sep 2005 Location: New Delhi
Infractions: 0/1 (4) | Quote:
Re your PM (have been busy, sorry I couldn't answer earlier) and your posts here; I guess most of your questions have been answered. Re the door panel, ask your friendly neighborhood Hyundai workshop and you may just find out that the stock replacement panel costs as much as a custom mdf panel job will.
__________________ Often imitated, never duplicated! | |
| | #20 (permalink) |
| BHPian Join Date: Feb 2007 Location: Kolkata
| Thanks Autophile, Hydrashok, LBM & Gunbir for your wonderful suggestions. I started off by stating that I wanted to go for 1 amp to drive the 3 ways & the sub. Would there be an advantage having 2 amps instead? For example the JBL cs60.4 bridged (160W x 2) driving the 3 ways & the JBL GTO301.1 driving the D4 sub (294W x 1 at 2 ohms) will together cost about 22K. I am trying to get the power up & the cost low but if I'm going completely off my rocker don't hesitate to say so.
__________________ Every man has his follies. And often they are the most interesting things he has! |
| | #21 (permalink) |
| Senior - BHPian | nura, I'd start with just the 75.4 (powering the fronts & sub) and see how things go. You can always add another amp later (make sure your power wires are chosen with this in mind) if you want to. And, if you go this way, after the upgrade, you would have a better speaker amp than the CS60.4 in your car, and you could get a more powerful sub-amp (more powerful than the 301.1) later if you want to. And you would have no post-install cash-flow issues now ![]() If right now, budget is not a constraint, two amps would be better. The fronts and the sub would get the power they deserve. But then this would push the amp budget up by 10K plus (additional cost of Distri Block and some extra wiring also now) immediately, right? Do you really want to spend that much now?
| | #22 (permalink) |
| The 75.4 now & something better than the 301.1 later? Would that be the 601.1? Total cost of 75.4 & 601.1 is just a little more than SRx3 but as you rightly pointed out I can get just the 75.4 now & the D-class amp later. Is the SRx an A/B-class amp or A/B-class for fronts & D-class for sub, if there can be such a thing? How would the 75.4 + 601.1 perform compared to the SRx3?
| | #23 (permalink) | |
| Senior - BHPian | Quote:
also the jbl sounds a little bright and straight forward.....but the audison is a bit layerback.......so I would suggest try to listen to both of them before buying...... | |
| | #24 (permalink) |
| Very nicely explained LBM. Thanks. A request to BHPians from Kolkata who have similar set-ups, can I have a listen?
| | #27 (permalink) |
| You're right. The SRx3 certainly pumps out a lot of power to the sub. It can even drive a sub of 2 ohm impedance, which most AB-class amps can't do in bridged mode. If only I could hear the 2 amps.
| | #28 (permalink) |
| @Autophile/ Gunbir - If I wanted to go for a 2-channel amp to drive the 3-ways & a separate monobloc for the IDQ sub, what would you recommend - the SRx2S & the LRx1.400? How are they priced? Thanks.
| | #29 (permalink) |
| Senior - BHPian | @nura, the SRx2S is just made for those 3-ways But it is a bit expensive for a 2-ch amp. It runs to about 28K (as against about 25K for the SRx4 -- 4 ch amp). The LRx1.4 will be a bit of overkill and quite a bit expensive at about 35K. You can probably get the SRx1 at about 25K, and run a dual 4ohm IDQ (IDQD4 V3) wired for 2 ohms, thereby giving it 350w RMS. The advantage of the LRx1.4 is that you buy can a dual 2 ohms IDQ now and run it at 4 ohms/350w RMS; Then, later you can add another dual 2 ohms IDQ and run the two dual 2 ohm IDQs wired for 1 ohm, giving them 450w RMS each. Between an SRx2S + SRx1 combo and an SRx3, maybe the SRx3 will be a lesser costly investment. But the SRx2S + SRx1 combo will really rock your socks off in comparison. Or, get an SRx4 now, and run the fronts & the IDQ from it (the sub will not get what it deserves), and later get a monoblock, then bridge the SRx4 to 2 ch and drive the 3-ways. My 2 bits. JB and Gunbir will have better ideas ![]()
__________________ Alpine 9887 | TRU Tech S44 | Image Dynamics XS65 | Image Dynamics IDQ12 D2V2 | Connection Audison Last edited by hydrashok : 4th May 2007 at 18:39. |
| | #30 (permalink) |
| BHPian Join Date: Jun 2006 Location: Delhi/Noida
| hydra that was such a mind twister...how do you do it....lol........
__________________ Car : Kenwood - Tru - Rainbow - ID Home : Dynaudio - Krell In the audio world, adding to the music is the biggest sin. |
| Thread Tools | |
Similar Threads | ||||
| Knocking Sound in Santro | Vys De BlUR | Technical Stuff | 18 | 29th April 2008 17:32 |
| Knocking Sound in Santro | Vys De BlUR | Technical Stuff | 0 | 5th March 2008 18:38 |
| Sound Enhancement - Please advice | gigatech2006 | Ask the Gurus | 6 | 12th October 2007 13:54 |
| Need advice - Thud Sound while taking IKon out from Parking | FlairBoy | Technical Stuff | 4 | 9th July 2007 12:01 |
| Sound Advice needed for 2 Cars.. A Palio and an Accent.. | Ad1tya | Ask the Gurus | 10 | 4th May 2007 13:44 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
