Thread Tools
Old 1st May 2007, 19:55   #1 (permalink)
archangel's Avatar
Default ICE for an Estilo
Hi guys,
i am planning to ICE my estilo and i am on a shoestring budget. needed to keep the expense to 10000+/-
searching through this section, i think that a pioneer headunit (3 preouts) and jbl front and rear speakers will maybe fit my budget (loan can be arranged from pops if the budget rises ). can i get some suggestions. am from kochi. i like to hear the vocals clear. bass and treble comes next. am planning to stall the sub for now. will i need an amp for this setup?
archangel is offline   Reply With Quote
Old 2nd May 2007, 01:58   #2 (permalink)
blueraven316's Avatar
A Pioneer Head with 3 preouts in Grey itself will cost you around 8 to 8.5k. The remaining will not get you JBL Speakers if the budget is 10k.
I would rather suggest a 2 Pre out 5950 which will be around 7.5k approx and JB speakers will take the total up to 15k approx.
blueraven316 is offline   Reply With Quote
Old 2nd May 2007, 02:20   #3 (permalink)
Pioneer 4950 & 5950 comes with 3preouts. The prices start below 5k.
Mate it to JBL 607 components in front. Leave the setup as this for now.
When you get some more dough, get JBL 937 ovals for the rear and you are SET.
You may also need to strengthen/fix your parcel shelf using MDF then.
It would better to run these speakers from an amp. For example, JBL 75.4 etc.. But that will cost more than 10k just for the amp itself. So, that can be kept as a later upgrade.
Get in touch with Automate at byepass. They are the authorised dealers for JBL.
Old 2nd May 2007, 04:20   #4 (permalink)
manikjeet's Avatar
man i to have a estilo nice cute car i have also iced it up like i do all ma cars
for the hu i got a song vcd player it was around 8 K and then i have screen for 9k and some sony in the front and jbl 6x9 and then a sony amp and a single 10" sub the total system cost me a round 25k-/+
for your buget would suggest a jvc (start out from 3.9K) hu and a good pair jbl 6x9( 2900 without warrenty)
__________________
MANIK NANDA
manikjeet is online now   Reply With Quote
Old 2nd May 2007, 09:06   #5 (permalink)
hydrashok's Avatar
Like Zak said, I'd also do it in 2 stages if the current budget is 10K.
HU + fronts now. Rears next.
If you're doing everything now,
HU: Pio 4950: 5K
Fronts: JBL GTO 607c (6.5" 2-way comps): 6500/- OR GTO 507c (5.25" 2-way comps): 5500/- (Depending on what the Estilo takes in front). If its like the Wagon R, you'll be able to get only 4" co-axes in front. Then it would be the GTO 427: 2700/-.
Rears: Since you have no sub, get 6x9s. JBL GTO937: 4900/-
Unless you have definite plans for an amp and sub later, you can settle for 2 pre-outs in the HU. If you're not at all likely to go for amps and subs, one pre-out will do.
@Manikjeet, what size does the Estilo take in front? Is the stock provision on the dash or on the doors? Does it have stock provision for speakers in back?
__________________
Alpine 9887 | TRU Tech STEEL S44 & S500 | Image Dynamics XS65 & CTX6 | Image Dynamics IDQ12 D2V2 | Connection Audison
Old 2nd May 2007, 10:19   #6 (permalink)
vid6639's Avatar
Estilo has speaker locations in all the 4 doors. By looking at the size I think they are 5.25" all around.
__________________
Let's get "instigated".....
\ / ][ |) `/ [_] "!"
vid6639 is offline   Reply With Quote
Old 2nd May 2007, 10:24   #7 (permalink)
Estilo has speaker provision on doors. Even the rear doors have provision for speakers. I am not aware of the size.
Old 2nd May 2007, 12:50   #8 (permalink)
navin's Avatar
For 10K get a HU for 5K and 4 6" speakers for 5K. JBL makes a CS series of speakers that might just fit your need.
__________________
Scixelsyd Etinu
Old 2nd May 2007, 12:56   #9 (permalink)
kpzen's Avatar
JBL CS2165 6" coaxial speaker - Rs 2850 with B&W
__________________
Prajesh
Old 2nd May 2007, 13:09   #10 (permalink)
navin's Avatar
there you go. 6K for 4 speakers not ust add a simple Pio HU for 4-5K and you are almost under budget.
__________________
Scixelsyd Etinu
Old 2nd May 2007, 15:42   #11 (permalink)
archangel's Avatar
Talking
thanks a ton for all your advice, guys.
i have seen you guys persuading a 10k budget guy to finalize a 20k ICE. thats why i mentioned a 10k budget first.
i think JBL GTO607c (6.5" 2-way comps) will fit in the front stock location (it is 6") and GTO607c is packaged with 2 metal adapters which can be installed in 6", 6-1/2", and 6-3/4" openings according to the manual.
about the headunit, there is still confusion. pioneer 7950 is a HU where you can plug in the USB rite. it is around 10k in grey. is it worth it?
speedzak and hydra@ am planning to do the installation by a friend who works at automate.
Old 2nd May 2007, 16:38   #12 (permalink)
kpzen's Avatar
What are those metal adapters ?
__________________
Prajesh
Old 2nd May 2007, 17:02   #13 (permalink)
hydrashok's Avatar
So you have learnt the way of TBHP ICE
the Pio 7950 is USB "ready". That means it is ready, waiting for you to plug-in that 4K connector cord (CD-UB100) that you'll need for connecting a USB drive. No connector = no USB Otherwise it is a good HU. I'd get the 6950 for about 2K less (unless you plan to buy the ISB Adapter).
__________________
Old 2nd May 2007, 17:04   #14 (permalink)
hydrashok's Avatar
They must be some spacer-like things and reducer-like things to help the install. Nice to know stuff like this comes bundled.
__________________
Old 2nd May 2007, 17:16   #15 (permalink)
navin's Avatar
for the budget concious there is a stripped down version of the 607. Sam can proide model details.
__________________
Scixelsyd Etinu
Thread Tools
Basic ICE for Zen Estilo - Rs. 10,000 vebmetal Ask the Gurus 52 7th April 2009 22:17
ICE for Zen Estilo ultimatechamp Product Discussions 50 22nd September 2008 12:11
Estilo - Way to Go simonkayar Test-Drives & Initial Ownership Reports 28 14th May 2008 18:52
ICE setup in my Estilo - Kudos to blueraven Krato Sound Off and Show Off 31 20th October 2007 18:46
First Drive - Estilo herculesksp Test-Drives & Initial Ownership Reports 3 21st December 2006 08:51
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599
