| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #31 (permalink) | |
| Senior - BHPian | Quote:
Is your friend planning to add 6 subs in his boot..... all the pioneer subs have different t/s specs....so let us know which sub it is like Navin Ji asked...... | |
| | #32 (permalink) |
| BHPian | hi, he wants to put 2 subs with a helix hxa400 amp. btw how is this amp? he bought it from germany around 4-5 years back we have 2 options regarding the subs. 1 is to use 302c and the other is to use 306c. he has 5 subs(just confirmed) 2 304 are installed in his safari. ill explain again. we have 2 302c subs and 1 306 sub. which one is better? he'll have to buy a 306 if we choose that. now suggest cheers clip |
| | #33 (permalink) |
| Senior - BHPian | the helix give 70 x 4 at 4 ohms and 250 x 2 at 4 ohms in bridged mode...and it is a quite nice and clean amp...I would suggest it for speaker rather than woofers....so please consider it again.... also if you planning to add subs choose same model and dont mix and match...also he 302 is quite old sub...I think it will be working fine....and I am a bit sure it will be a F as earlier day it was hard to find a C woofer.... So you are left with a 306 only..... |
| | #36 (permalink) | |
| Team-BHP Support ![]() Join Date: Mar 2004 Location: mumbai
| Quote:
It seems like to me that Indians believe that if the system they ahve can produce the lows and highs it can produce the middle as well.
__________________ Scixelsyd Etinu | |
| | #37 (permalink) | |
So even the autorickshaws in mumbai have a nice setup then..... ![]() | |
| | #38 (permalink) | ||
| BHPian | Quote:
| | #39 (permalink) |
| BHPian | hi guys, . punjab da putter wants 2 subs. he gives a damn about sq. all he wants is baaaaaaaaaaaaasssssssssssssss. he wants to be low bass makker which he can try throughout his life but cant ;-)). guys 1 more friend is asking for 306dvc enclosure volume and port dimension. they think im kind of a guru. lol. good im cashing in on navinji and the gang's expertise.(not money guys reputation as a pro) just kidding lol. but seriously so many guys here have asked me to do an install. IMHO i think im better than the installers here. obviously i have a backing from you guys. :-) ok on the serious note, the civic guy is going for jbl comps front with 2 subs.(god i only i know how i convinced him that rear fill isnt all that important if you sit in the front.) now the subs are 302f. no, IB and sealed install is not his cup of tea. what to do. but i also made the enclosure for my 304f remember navinji, they were producing a lot of hard hitting bass. what do you guys recommend? now the other guy with 2 306 dvc subs. ok he is running a single coil per sub cause he has a monobloc (pio 510) can it power dual two 4 ohm dvc subs? should i go for what pio recommends ? help me maintain my rep as a guru brothers lol. clip |
| | #40 (permalink) |
| clip, the real difference between the F and C is the Qts. But like I have said before there are few rules in audio. One member on this forum uses a 304C in free air and it produces a lot of BOOM but he likes BOOM so more power to him. I do not advocate neutral sound or BOOM. I do advoate a clean install with the minimum of rattles, buzzes, and a sound that is well balanced (front to rear, left to right). Taking a F series woofer and dumping it in a small box with make it produce some punchy bass but the low end will be limited to about 50Hz after which the drop off will eb quite fast. Taking a C series woofer and putting it in free air will make a lot of BOOM (over blown bass). I have lost track about which guy has what wofers and how many. I think you are now advising atleast 3 or 4 friends right?
| | #41 (permalink) | |
| BHPian | Quote:
hehe 2 friends and me so that makes three of us. i think i understand you better than before. one at a time ok? i wont confuse you guys anymore. this is a general query ok now i need MDF for my enclosure. i went to the market for a survey. i was looking for NUWUD MDF. There are three grades available. green stamp, red stamp, black stamp. these are the three grades. i think in my sealed enclosure green stamp NUWUD MDF was used. im not too sure. LBM sir can you please let me know which is the best for an enclosure? what MDF are you using rightnow? cheers clip | |
| | #42 (permalink) |
| Sadly I dont use plain MDF anymore. I found a sandwich of 6mm marine grade ply, 2 layers of 3mm resin bonded fiberglass and 4 mm MDF offer the best "stiffness for effort" ratio.
| | #43 (permalink) | |
| BHPian | Quote:
is this the better way navin? i wont try it bu im just asking. guys im not happy with you, specially lbm.(kidding ) no one is helping me with the MDF part. kahaan gaye sab ke sab? b&t, JB, Gunman, Sam???help me yaar. | |
| Thread Tools | |
Similar Threads | ||||
| Help me choosing enclosure for GT5 12" Subwoofer | venki7744 | Ask the Gurus | 7 | 25th March 2008 11:50 |
| Hertz ES300D 12" Sub for sale | akg7091 | Shifting gears | 18 | 20th October 2007 16:58 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
