Thread Tools
Old 29th May 2007, 23:32   #121 (permalink)
navin's Avatar
Originally Posted by Autophile View Post
I want to ask that on what basis do you draw conclusion that one brand is more esoteric than other?
esoteric can also mean "secret" as in
esoteric definition - Dictionaries - MSN Encarta
I have seen more of Audison than Steg. To me the Steg were a bigger secret than Audison. It does not mean one is better.
__________________
Scixelsyd Etinu
Old 29th May 2007, 23:35   #122 (permalink)
navin's Avatar
Originally Posted by Bass&Trouble View Post
I'll let Navin answer your question, but I do want to point out that I absolutely do not regard a mono amp as a MACK and 2/ 4 channel amps as 911s. That would be a whole lot of generalization.
It is generalization. It is best I could do under the circumstances. Compare for example the JBL 755.6 vs the JBL 601.1 (both cost about the same). In fact I should have said "multichannel amps". A 40x4 amp compared to a 160x1 amp for example.
__________________
Scixelsyd Etinu
Old 30th May 2007, 01:20   #123 (permalink)
gunbir's Avatar
Infractions: 0/1 (4)
Originally Posted by clipto333 View Post
i am planning to build a ported enclosure for my sub but im not sure what will be the effect on sq. want your expert advice on this gunman. what is the basic difference between properly designed sealed and ported enclosure for the same sub?
Clip, this basically differs from sub to sub. In this case, the ES380 will sound a bit louder around some frequencies but still remain smooth. So little loss of SQ here.
__________________
Often imitated, never duplicated!
Old 30th May 2007, 01:28   #124 (permalink)
low_bass_makker's Avatar
I think the ported will be at loss at the freq which will be lower than the tunned one but otherwise it will be good everywhere.....nice and smooth....
Old 30th May 2007, 01:48   #125 (permalink)
clipto333's Avatar
hi gunman,
this was the reply i was looking for. so i will definitely build a ported enclosure now that ive got the advice.
1 more thing. i think driven had the exact dimensions for all the subs according to the car. if thats the case, can you help me with it so there is minimum error? nevermind if not possible.
that toh i know. waise gunbir what would be the tuning frequency if the enclosure is built according to the recommendation by HERTZ?
thanks guy
clip
clipto333 is offline   Reply With Quote
Old 30th May 2007, 01:56   #126 (permalink)
clip I have posted the same a few pages before.....check it out...
Old 30th May 2007, 02:03   #127 (permalink)
hertz recommend a 60 lts box...with 25 hz tunning freq which will require a 82mm dia port with 290 mm length
Old 30th May 2007, 13:51   #128 (permalink)
clipto333's Avatar
hi,
thanks again lbm. i forgot that you had posted it earlier. i have a bad memory :-) . the tuning frequency is quite low. i think it wll be ok. what do you say?
Old 30th May 2007, 14:14   #129 (permalink)
ya it is quite adequate for the job.....
Thread Tools
Help me choosing enclosure for GT5 12" Subwoofer venki7744 Ask the Gurus 7 25th March 2008 11:50
Hertz ES300D 12" Sub for sale akg7091 Shifting gears 18 20th October 2007 16:58
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
