| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #1 (permalink) |
| BHPian | hi guys, my ice is as follows:- Head Unit - Pioneer 6850 Amplifier - pioneer GM-X944 Front Speakers - Hertz Energy esk165 6.5" components rearfills - infinity ref9613l 6x9 speakers Sub - HERTZ es380 15" damping - front doors. As suggested by some when i got the upgrade done, i would like to build a ported enclosure for the above sub. i have a few doubts which i want to clear. do sealed enclosure give better sq than a ported? i dont want to hurt the sq, just want an increase in bass. dont want boomy sound at all. can ported enclosures(well designed and built) give tight and punchy bass without being boomy? also i tried a few softwares but the enclosure size is coming out to be huge. can anyone give me the exact volume and port dimensions for the above sub? Gunbir? JB? should i go according to the HERTZ manual? im saying this again...i dont want to sacrifice sq much. LBM, what were the differences when you switched from sealed to ported(your new subs - IDMAX)? did the sq suffer? thanks in advance cheers clip |
| | #2 (permalink) |
| BHPian Join Date: Sep 2006 Location: faridabad/rourkela
| clipto,going by your details i think its sealed for you.a ported usually will sound loose and boomy.i persnally think that 15"ported in car and for sq is big no-no. yes the difference is huge in lbms car after going from sealed to ported.the bass is boomy.no matter what you do a ported will have loose bass(usually).rest navinji,gunbir,b&t.......will be explain |
| | #3 (permalink) | |
| Senior - BHPian Join Date: Mar 2006 Location: Bombay
| Quote:
clipto: Gunbir and JB can easily equip you with all that you'd need for a ported enclosure project for a Hertz sub if they find the need for one, I'm sure.
__________________ Operator! Give me the number for 911! | |
| | #4 (permalink) |
| Senior - BHPian | Firstly what hertz people has to say about there sub.... ![]() the sub will be fine in a 40 liters(1.41 cu.ft) sealed box which you have right now.....and for the ported box a volume of 60 liters (2.12 cu.ft) would be good......with a 82mm (3.22 inch) dia pipe with 290 mm ( 11.4 inch) length port...... Now if you go for a ported box you will gain about 3-4 db of more sound...for free without changing your sub or amp.....about SQ who says that the ported one is having trouble producing some nice sound.....when compared to the sealed counterpart.....If i am not wrong the ported enclosure design was patented nearly 10 years before the sealed box design.... here is a nice writeup by JL Audio one of the pioneer of some good SQ products of both car and home audio....there they have explained very clearly the difference between the sealed, ported bandpass designs....please read both the article carefully to fully understand the difference between the various enclosure.... JL Audio JL Audio one thing more I dont understand the meaning of boomy and punchy.....if we refer to boomy as the low end (25-40 hz) of the music spectrum and the punchy (40-80hz) then I think the smaller box will be the best bet....as the enclosure size increases the lower end tends to increase as the qtc of the enclosure increases.....close to 1...not it is the person to decide which way to go.... |
| | #5 (permalink) |
| Newbie Join Date: Mar 2007 Location: Chandigarh
| In much simpler terms, if your amp is powerful enough and/or the guy who makes the enclosures is an average joe and/or you have less space available, go for sealed; and if you have a relatively normal amp and/or the enclosures are being really made well and/or have the space in your vehicle, go for ported. Rest -- believe your ears (tm) (used without permission from Navin).
__________________ My word is my honour; my honour over my life. |
| | #6 (permalink) |
| Senior - BHPian Join Date: Mar 2006 Location: Delhi. Travelling as usual! Mumbai was great.
Infractions: 0/1 (4) | Whenever I say BOOM, I'm referring to the loose and reverbing bass (echo kind) after the original kick from the sub. It doesn't have nothing to do with the real punch. It may also be called the after effect. This tends to be more pronounced in a ported/vented/bandpass /tubed box when compared to a sealed one. Many companies always recommends sealed boxes as the first option. Ported etc. comes after that. Some companies recommend their sub to be used only in a sealed box. I strongly believe this is due to the superiority and simplicity of a sealed box in terms of output quality. Ofcourse, if one is only interested in db and lots of it, then ported/bandpass should be his destiny. Sealed should never be considered because it will decrease the volume of bass when compared to ported. I have a bandpass sub which can knock off a sane person's socks, heads etc.. and I'm very proud to own one. Yes, it produces very heavy and punchy bass which stands out by itself and even causes trouble to drive the car if played to max for some time. But for long listening sessions, I always prefer my sealed one due to the tight, perfectly blended bass. Sealed thingys are supposed to be tight too. Ain't it? ![]()
__________________ A very big THANK YOU, Bombay! Will miss you guys! :( |
| | #7 (permalink) |
| Senior - BHPian | the manufacturer always recommend the sealed one because it is the easiest to built and the chance for error is not there....as there is only one major variable to play with that is the volume of the enclosure....but in a ported one there are many variables present....like volume, port dia, port length, tuning freq.....so there comes the design part.....so people tend to get along the sealed box.....also in a SQ install the sub is not played loud so a sealed box suffice the job.....but when hot blooded punjab de putter like our clip want loud music then a good designed ported or even a bandpass enclosure is a must..... |
| | #8 (permalink) |
Infractions: 0/1 (4) | Oh, BHANGRA and boom boom! I forgot that part. ![]() I have seen and heard an install where an ES380 was installed in a ported box and kept into a Fiesta. The sub can really rock and make the neighbourhoods shake. If that is what Mr. Clip is looking for, then he should get a monoblock amp (or get his DIY sub amp finished) and hook it to this monster. Then, You'll see thingys moving around. But, expect a bit of drop in SQ. But it will be okay to listen and will never sound absurd for sure.
| | #9 (permalink) |
| BHPian | hi, thanks for the suggestions guys. ok let me tell you this. i compared a pio 306 svc(well theres no comparison butt still) in a ported enclosure with my hertz( my old pio sub which is lying with my bro in law) i was playing the song akon - wanna fcuk you. when the lowest bass note hits the pio went haywire reproducing the note. it was like about to chew my ears off. how can i describe the boomy sound? the hertz was like so smooth. it was like crystal clear and was easy on the head. i could only feel the bass. the pio was atleast 4 times louder and it wasnt the bass coming out but a whole lot of noise. hope im not confusing you guys. yes, the punjab da puttar wants bass but with kilarity like our faridabad da punjabi :-) . if the ported enclosure will sound like that then i wont touch it. But IMHO, i should give it a try. i wanna compare a sealed with a properly designed ported enclosure. btw whats the dia of the audiocomp(audison) port you have lbm? i think you only get 1 size dia with variable lenght. also can you give me an idea about the price of an mdf board. .75 inchi. in winisd the volume for the sub was around 400 litre. why? and in bass box pro it was 394 L. should i go with the manufacturers recommended volume? also lbm can you post pics of a sedannwhose trunk lid and boot is damped. just want an idea cause im gonna damp the boot today. (gunbir i re used the damping on the door. i peeled it of very carefully and after heating it up with a 500w halogen light it was as shiny as new lol). got a replacement for the damping as it somehow got stuck on the window glass and machinery. i think it was because of the climate and dust. ofcourse the door looks bad with the re used damping with smaller pieces but the whole door is covered properly and its sounding great. so guys keep the advice coming the punjab da bassy puttars way. i wish someone gifts me an audison or a steg amp on my birthday. then i dont neeed a ported enclosure. btw lbm, how much did you sell your mrd 1005 for? i really liked that amp. keep me posted if theres a second hand audi son or any good sq amp. and please arrange for the finances if you find 1. ![]() cheers clip |
| | #10 (permalink) |
| Senior - BHPian | hmmm.....400 liters....I think you would not require such huge volumes....a 2...2.5 cuft will be fine... I am having a 3 inch port with 9 inch total length which can be reduced.... mrd1005 is for 29k with B/W.......It is very hard to find that amp in grey but I will keep you posted.... And one thing I wanna add here again....ported box does not mean no SQ......it can also do better than a sealed box in some cases no doubt in that...... |
| | #14 (permalink) |
| BHPian | hi, yes. i dont know whats wrong but ill post the T/S Specification. here goes... Qts - 0.52 Vas - 183 L Fs - 24.20 Hz Re - 2.90 Ohm Le - 1.14 Xmax - 9.0 mm Z - ? Qms - 3.93 Qes - 0.60 Spl - 95.00 db BL - 13.28 dia - 325mm caulculate the box volume if you can please and let me know. LBM paaji you also try. cheers clip software im using is winisd beta and bass box pro |
| Thread Tools | |
Similar Threads | ||||
| Help me choosing enclosure for GT5 12" Subwoofer | venki7744 | Ask the Gurus | 7 | 25th March 2008 11:50 |
| Hertz ES300D 12" Sub for sale | akg7091 | Shifting gears | 18 | 20th October 2007 16:58 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
