Thread Tools
Old 22nd May 2007, 16:06   #1 (permalink)
harryc's Avatar
Default Need an ICE advice for Swift -- Budget: 15-20K
Hello,
This is my second post in this forum. I was thrilled to see overwhelming response to my earlier post "Which car to buy?". Thank you all for your valuable time and advice! I have finally booked SWIFT - VXI, arriving home in about a couple of days! Thank you, bhpians!!
// Believe me, i've spent umpteen hours and several days searching for a good ICE configuration between 15-20K budget on this forum. Though every moment has been really worth it, however with each post i go through - it is getting more and more confusing. Therefore, instead of scraping this, please respond with your expert advice//
I am looking for an HU with a USB 2.0 port along with AUX input. I also need a SUB alongwith an AMP. Please suggest me the best possible ICE configuration within 15-20K range.
Please also share do's/dont's for ICE setup w.r.t. SWIFT. Do you know any reliable places to get ICEing done in Delhi ? Thanks again, in advance!
-harry
harryc is offline   Reply With Quote
Old 22nd May 2007, 16:44   #2 (permalink)
gopz's Avatar
You can probably go in for grey stuff if you want all the features in the HU and also a sub and amp. Because it might be difficult to accomodate USB HU, front + rear speakers, amp and sub for 15-20k. IMO you can consider stretching the budget a little bit (like all BHPians end up doing
gopz is offline   Reply With Quote
Old 22nd May 2007, 16:49   #3 (permalink)
speedzak's Avatar
Location: Delhi. Travelling as usual! Mumbai was great.
Infractions: 0/1 (4)
Hi and welcome to the most wicked section of Team-BHP.
I suggest you go to DRIVEN at Mayapuri. He is a good informed installer and he stocks good ICE equipments. He is also a team-Bhpian.
You should look for 5k HU, 5K front components, 5k amp, 3k sub. Rest, you will have to spend a bit on quality wiring, box and labour.
__________________
A very big THANK YOU, Bombay!
Will miss you guys! :(
speedzak is online now   Reply With Quote
Old 22nd May 2007, 16:55   #4 (permalink)
BUSA's Avatar
A Pioner 7950UB fits the bill perfectly but it costs 10k(grey) and 12k(B&W)
5K - JBL CS Series Compos
5k - Sony 554 amp
3k - Pio 307C
2k - Wiring & making a enclosure for the sub.
Above prices are rough estimates.
You can get a Sony CDX-GT460U for 6k (grey) & 8k with B & W
__________________
Got Bhp? Team-Bhp.com
Old 22nd May 2007, 17:05   #5 (permalink)
hydrashok's Avatar
Welcome to TBHP ICE, Harry!
You'll fond most of what you want to know here: http://www.team-bhp.com/forum/ask-gu...io-thread.html (The Swift Audio Thread)
AND here: http://www.team-bhp.com/forum/ask-gu...k-25k-30k.html (basic ICE - systems at various budgets -10K, 15K, 20K, 25K & 30K)
You'll find good HU recommendations (similar to your requirements) in this thread: http://www.team-bhp.com/forum/ask-gu...ensive-hu.html (Budget install with a expensive HU)
The Swift has provision for 6 to 6.5" speakers in the front doors & rear doors. You can get ovals (6x9") installed on an MDF parcel-tray if you want to skip using the rear doors, or if you want 6x9s.
For 15 to 20K:
HU: 8K-10K (JVC/Sony/Kenwood/Pio7950: since you need a HU with USB input with speakers within this budget. Most HUs above 6K, esp. Pios will have aux-in implemented one way or the other).
Fronts: 5K (JBL CS2165c 6.5" 2-way comps)
Rears: 3K (JBL2165 6.5" coaxials)
Getting a sub & amp also within 20K will be tough and you'll have to compromise for not-so-good equipment all through. Adding a Sub and Amp will also involve at least 2K additional for power & RCA wiring.
I'd suggest getting 6.5" speakers for the rear for now and doing the amp & sub later. Or you can skip the rear speakers now and get an amp & sub instead by stretching the budget just bit.
Sub: Pio306C (about 3K)
Amp: Pio 6200 (about 7K) or the Blau GTA special (6k) mentioned in the 3rd link I posted above. You can use these amps to run your front components & the sub.
__________________
Alpine 9887 | TRU Tech S44 | Image Dynamics XS65 | Image Dynamics IDQ12 D2V2 | Connection Audison
Old 22nd May 2007, 18:23   #6 (permalink)
rocksterraghu's Avatar
Originally Posted by harryc View Post
Hello,
-harry
If you're very particular about all these features, you'll either have to settle for Sony (Did I hear someone scream compromise? ) or you'll have to spend 9,500+ on the Pio 7950. If you have a budget of 20k, it would be very hard to get these features on the HU AND a good set of amps, speakers and sub.
__________________
Everything should be made as simple as possible, but not simpler
Old 22nd May 2007, 21:23   #7 (permalink)
navin's Avatar
like Hydra said
8K for the HU
8K for speakers
add sub and amp later (budget 15K for this)
OR if you want BOOM now
5K for HU (Pio 2950 or Blau Mumbai) just dont expect USB etc...
6K for coax in front and rear
8K for sub (4K with box) and amp (Sony 552 for 3K) and pair of RCA wire (1k)
1K for install
__________________
Scixelsyd Etinu
Old 23rd May 2007, 00:20   #8 (permalink)
harryc's Avatar
Thank you gopz, speedzak, BUSA, hydrashok, rocksterraghu and navin for your responses. After seeing your suggestions, i think i should shell another 5k which increases my budget for a good ICEing upto 25K now. I checked out the Pio 7950 today and i'll be buying it for sure. All you experts, please send me the best Possible configuration with Subs and AMP.
I am very fussy about buying everything with B/W. So Grey is a NO NO!
Speedzak, do you have any contact number for DRIVEN in Mayapuri please?
Thank you!
Are there any other places to get good ice'ing and accessories done in West Delhi?
Old 24th May 2007, 04:40   #9 (permalink)
low_bass_makker's Avatar
Another budget increase...
for sub and amp combo i would also consider JBL sub and for amp my latest favorite 75.4 it can drive your component in the front and the subs in the back.....and I would suggest to drop any rear door speakers as they dont sound right there ( I have a swift) put ovals in the tray if you want to put any rear speakers (as I am not using none) and power them through the HU...
Old 24th May 2007, 11:01   #10 (permalink)
Autophile's Avatar
Here is DRIVEN (Manik's) number ....please USE PM.
__________________
Danes Don't Lie !
Autophile is offline   Reply With Quote
Old 24th May 2007, 11:28   #11 (permalink)
Sir I think we must not put mobile numbers directly on the forum it can be misused....
Old 25th May 2007, 00:50   #12 (permalink)
Autophile's Avatar
Yeah right....LBM.
And Navin thanks for editing my post.
Though I can take out so many posts where mobile numbers have been freely posted but there was no objection at all but I don't want to because its of no use absolutely.
Harry you have my PM regarding DRIVEN's details.
__________________
Danes Don't Lie !
Old 25th May 2007, 01:04   #13 (permalink)
Yeah right....LBM.
No problem Sir it was for the better only.....So Harry what are your final equipment planned....
and as suggested by Autophile....go to Driven he is a good installer...
Old 29th May 2007, 00:18   #14 (permalink)
harryc's Avatar
Default Look at the Icing!
Thank you Autophile and LBM and others who responded earlier!
I have got my Swift Iced with :
HU: Pio 7950
Front : JBL Comp GTO Series - 607
Rear: JBL GTO Series - 937
And that's it! Believe me, this sounds just great! Performance beyond my expectations!
I just wanted to know, where to get the rear USB and Aux cable for Pio 7950 from? To my wonder, the box didnt have that!
Thank you, everyone!
Old 29th May 2007, 10:57   #15 (permalink)
Sam Kapasi's Avatar
Hi harry,
Your title says "look at the ICing" but i cannot see any pics. Where did you get your setup from? Any install pics?
Good you went for the GTO series. They are nice. What made you go for them? Since i saw some CS advice...
Congratulations! and I'm glad you are happy with the sound.
__________________
Live the YetiLife®
Thread Tools
Recommend a good setup for my OHC - Budget 18-20k pranavt Ask the Gurus 7 3rd November 2008 01:40
Help needed for ICE in swift- Budget 20K raptor_79 Ask the Gurus 36 26th August 2008 19:21
ICE for IKON..Budget 20k MAX.. Ford_madhan Ask the Gurus 28 26th December 2007 12:12
ICE-Swift Chandiagrh(Budget-20k)No idea how to go about it!!! Gill Ask the Gurus 17 14th August 2007 11:50
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
