Thread Tools
Old 6th June 2007, 00:52   #16 (permalink)
mclaren1885's Avatar
Originally Posted by Sam Kapasi View Post
However in the case of the verna, the antenna is on the roof rear, where the shark should be.
If I replace my existing antenna with the shark kind, do you think that will affect my reception? Or should I try it and let you guys know?
Its funny that ICE guru is asking us this rather than giving us the solution. Comeon yeti.
__________________
Phoenix!
Old 6th June 2007, 01:17   #17 (permalink)
BUSA's Avatar
@ Sam - The reception would be the same but you would have to make the shark antenna replace the stock one.
__________________
Got Bhp? Team-Bhp.com
Old 6th June 2007, 11:17   #18 (permalink)
navin's Avatar
same as in opel and skoda. No it wont affect your reception atleast it did not make a difference in a opel corsa someone from my family had. the original antenna was stolen so we installed a shark and it works as good as the original. BTW it is better described as a shark fin (no not the vodka).
__________________
Scixelsyd Etinu
Old 6th June 2007, 12:05   #19 (permalink)
abhilashvk's Avatar
[huge, motorized, extending above boot in sedans. A few high end cars have it tilted backward; what purpose doest it serve?]
Should be tilted so that there is no air resistance at high speeds. My Accent's motorized antenna have tilted outwards with time because of air resistance, so for many other Accents, I have noticed.
__________________
Abhi
Any man who can drive safely while kissing a pretty girl is simply not giving the kiss the attention it deserves.
abhilashvk is offline   Reply With Quote
Old 6th June 2007, 12:37   #20 (permalink)
tsk1979's Avatar
Sam, a long straight wire(4-5 feet long is a good idea) makes a Decent FM antenna for strong stations. Thats why your Nokia phone, or non creative nano players etc., which have FM use the earphone cable as an antenna.
However if the reception is not very good, or there are lots of reflections, in lets say a street with high rise buildings etc., you need to go a little technical. But still nothing you cannot DIY
The glass antenna, the rabbit ear antenna(Remember old TVs?), the Tata indica antenna are all "Dipole antennas".
Below I will try to explain to you how to make a nice dipole antenna. Its similar to the glass antenna, but design is better. You will find the design on numerous websites too, each having a different goal(HAM etc.,). Below is what was tried way back in college.
1. Take a 300ohm wire. In Radioshack USA it was called the lead in wire. I am sure you audio shoudio guys will know the exact terminology. Its basically two copper wires running parallel to each other Cut it to 4 feet 11" length. At both the ends cut away 1" of insulation. So now you have a 4'9" length of wire covered in insluation and 1 inch exposed at each end. Tie the wires at the end together and cover with tape. You have your dipole now.
2.Now cut the dipole in the middle as shown in figure, and this goes to HU, see figure
There, you have a nice antenna.
Now lets talk about manufacturers.
First Tata indica. The dipole antenna is very very small. FM is 3(98MHz) meter wave,
Without going into technicalities, you need to take 468 and divide by freq in MHz(Taken from TV engineers handbook). So if you listen more to 91, 92Mhz you can make your antenna longer(5 feet) but if you listen to FEVER 104 and only fever 104, then make it 4 feet 6 inches. Make sure you leave one inch at each end, we folded that remember.
Thats the reason when I switch on the AC, 104FM plays okay but the 95FM is patch, 91FM is even worse sometimes. That antenna is good for 300Mhz I think.
Then the glass antennas. Since they are part of the heating mechanism(I salute that engineer) everything gets messed up.
So sam you are a DIY guy go ahead and make it.
As for omni-directional antenna you can make a folded dipole antenna or turnstile antenna, but they are not conducive in a car, unless you want it too look like a bat mobile.
Last but not the least, remember those old TV antenna's with rods parallel to each other, that is a Yagi antenna, and very good directional antenna(useless in a car, but best for your home FM)
And many people use a cycle tires in areas of strong reception to make good omni directional antenna
__________________
Reclaiming.....!
Old 6th June 2007, 13:08   #21 (permalink)
tsk1979's Avatar
another thing I forgot the add, remember the days before satellite TV when you had that black ribbon cable doing to antenna? Thats a 300 ohm lead in cable. Cost is around 5rs a meter.
__________________
Reclaiming.....!
Old 6th June 2007, 13:17   #22 (permalink)
navin's Avatar
TSK, I can see that now. Sam in his jeep with one hand holding the 5 foot long antenna like the Statue of Liberty. If that dont get him arrested nothing will.
__________________
Scixelsyd Etinu
Old 6th June 2007, 13:22   #23 (permalink)
tsk1979's Avatar
Navin ji, you can mount it on the windshield, just like in the indica, only thing is that instead of extending half a feet on each side, it will extend 5 feet, almost to the end of the windshield.
__________________
Reclaiming.....!
Old 6th June 2007, 13:42   #24 (permalink)
anonymous's Avatar
Originally Posted by kartikkumar View Post
Good question. I had problems with the glass antenna on my Indica. Even on open roads the signal for certain FM channels was weak and I would get a lot of crackle. While it may allow for no protrusions, I think the external antenna on the Swift (which I drive now) looks great and works well too.
Any expert views on this?
I have experienced it. When I am far away from delhi, lets say around 100 KM, my indica's internal antenna doesn't not catch any signal of any FM but at the same location, other cars, which have external antennas, pick up singals for every FM. Also in delhi, sometime the reception quality is not very good.
anonymous is offline   Reply With Quote
Old 6th June 2007, 13:47   #25 (permalink)
tsk1979's Avatar
Thats because the indica antenna is too small, you need something atleast 4'6" long. With a big antenna you will be able to get FM even in Panipat and Karnal.
__________________
Reclaiming.....!
Old 6th June 2007, 13:51   #26 (permalink)
anonymous's Avatar
Hi tsk,
How can I get this one fitted in indica. Does it have to be internal or external one?
Old 6th June 2007, 14:13   #27 (permalink)
tsk1979's Avatar
See my post, after you make it with your TV antenna wire, just stick it to your windshield, disconnect the old antenna and connect the leads to this one. It is just like your original antenna, but much longer, will run end to end on the windshield
__________________
Reclaiming.....!
Old 6th June 2007, 15:16   #28 (permalink)
clipto333's Avatar
hi,
nice work there tsk. i have a problem. my OE antena in my accent has conked off(the motor). i hav to get it replaced. with the aftermarket antenna. will the reception be ok? my wife drives the car(i only get the car when i come back form work :((. ) if the reception aint good, she'll force me to buy the OE antenna which is for 5600/- . so what im planning to do is to buy the after market power antenna and diy the antenna you mentioned above(only if it'll work throughout the fm band) and use it instead of the after market antenna. what do you suggest??
cheers
clip
clipto333 is offline   Reply With Quote
Old 6th June 2007, 15:33   #29 (permalink)
Originally Posted by clipto333 View Post
hi,
clip
To make it work reasonably across the whole FM band, antennae are tuned to the frequency corresponding to the center of the band.
Making an FM antenna is probably the easiest DIY... but wouldn't it look plain ugly?
Another doubt, since glass antenna is surrounded by metal all around (worst in case of defoggers), wouldn't it deteriorate it's performance?
santosh.s is offline   Reply With Quote
Old 6th June 2007, 15:49   #30 (permalink)
tsk1979's Avatar
The dimensions I have given are for around 98MHz, i.e. bang center of band, 20MHz is fairly narrow, so this antenna will work.
As for the metal part, its better to mount it on front windscreen, but if you use a high end car or have a anti Infrared sun film, it may not work. Reason, many modern high end glass as well as films have lot of metal in them. Thats the reason windshield mounted GPS antennas also do not work well in these cars.
But since mostly people going in for such contraptions drive normal cars, you can just use what I listed.
Now comparing OEM, Aftermarket and DIY antennas, well its just a wire. OEM antennas take aesthetics into play, so they are usually worse off. For example a 1 meter long straight wire will work as a good enough antenna too if you are near a FM station.
So just buy that TV antenna wire, make this antenna, stick it on the windshield. In case of cars like indica which already have a windscreen mounted antenna, all you need to do is disconnect that, and connect the 2 wires to this DIY antenna.
__________________
Reclaiming.....!
Thread Tools
PROBLEM: Accent's Antenna Twisted sizoo Technical Stuff 4 4th September 2008 13:48
Looking for an antenna adityamunshi Gadgets, Computers & Software 10 11th February 2008 00:38
Power Antenna vivaid Ask the Gurus 18 17th September 2007 22:29
Someone Broke my Radio Antenna! amit The Indian Car Scene!! 7 15th October 2004 22:48
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
