Thread Tools
Old 27th June 2007, 11:55   #46 (permalink)
low_bass_makker's Avatar
Originally Posted by manikjeet View Post
sorry for the delay i was having a hard time finding the car keys and then the measuring tape
so here are the dimentions
length 27 inches
breath 13 inches
hight 13 inches
the length of the pipe is 7 inhes
and the diameter of the pipe is about 2 inches roughly
the internal volume of you enclousre if made of 19mm wood will be about 1.95 cuft. and jbl recommend this..
And I dont think the differnce it to much and will alter the sound much..but I would say to change the port size as per JBL spec.
Old 27th June 2007, 13:21   #47 (permalink)
manikjeet's Avatar
thanks LBM for you help i will have the box made at once
BTW can a bigger box harm the woofer in anyway sorry for asking this
( i have no knowledge about it)
__________________
MANIK NANDA
manikjeet is offline   Reply With Quote
Old 27th June 2007, 13:28   #48 (permalink)
no and yes it depends on which size you are refereeing to plus the amount of power you are going to give it.
if the size like the above one then there is no problem but if the size is like double the above then the woofer will feel that it is in a free air application which is very hard for the woofer.
Old 27th June 2007, 13:41   #49 (permalink)
manikjeet's Avatar
thanks again man
i will post more pics of the bigger box the seller want me to get
and material you will preferences to and can i get a fiber glass box or something like that made
i need to know will the stuff handle all the bass from it
__________________
MANIK NANDA
Old 27th June 2007, 17:09   #50 (permalink)
carlover84's Avatar
Ok people, sorry for so late reply as i was not in the town.....Neways I read what suggestion's u people gave and and iam thankful to u..And Bass_Maker, the amp is original as it is the old one, not the new one which is low in power and produces hissing noise too...The difference between old one and new one is of fuse unit which it uses...Mine is with the unit so it works well....But people tell me one thing, Where to install these three amps??? I cant buy new stuff now so temme how to adjust all this.....Now i can just make a new box thats it.So kindly help me accordingly plz.
__________________
What was ONCE ur LIFE is now ur LEGEND
carlover84 is offline   Reply With Quote
Old 27th June 2007, 17:13   #51 (permalink)
how have you wired the stuff right now...which amp is running which speaker.
Old 3rd July 2007, 12:27   #52 (permalink)
carlover84's Avatar
Well for now my speakers are running on Sony 222,and one amp each for subs and BTW I spoke to car experts regarding the things which you people told me and they checked out my box also, but everything is absolutely fine as there is division by wooden boards between the speakers and the subs too....SO there is no distortion issue of voice and even i checked it also by just connecting everything one by one. If you people still have a doubt then plz firstly visit me, listen to the sound and then lemme know whether things are fixed good or not.One issue is right that I need to change my amps for subs as I have planned to get 2 mono Amps (Same) for my subs, so that the output to each sub remains same as.Right now my one amp is 1000 watt and one is 1200 and that also of different companies so the output to both subs is different otherwise the sound coming is good and no distortion or voice hampering is coming.....CHeers to all
__________________
Old 3rd July 2007, 16:39   #53 (permalink)
sir where do you live in delhi and if you make it to the next team-bhp meet so that we can discuss what is wrong there in your setup. till you have not heard any thing better you cannot tell which is better.
Old 8th July 2007, 03:15   #54 (permalink)
carlover84's Avatar
Sure, I would love to meet you guru's and would enjoy the meet also, but dont know when and where it takes place and how to be a member for that........
__________________
Old 8th July 2007, 03:27   #55 (permalink)
for this keep an eye on this section...
http://www.team-bhp.com/forum/team-bhp-meet-section/
Old 4th August 2007, 23:33   #56 (permalink)
carlover84's Avatar
bhaiyon help to karo...............Till now i dont have any sample pic for a custom boot for my ride
__________________
Old 5th August 2007, 00:47   #57 (permalink)
m4ugr8's Avatar
Well if you want a sample take a look at this
Shot at 2007-08-04
m4ugr8 is offline   Reply With Quote
Old 5th August 2007, 00:58   #58 (permalink)
Drop down to FBD will try to help you about your boot install the way you need it.
Old 5th August 2007, 13:49   #59 (permalink)
carlover84's Avatar
I also have this pic but where are the speakers insalled in this case?
__________________
Old 5th August 2007, 14:02   #60 (permalink)
m4ugr8's Avatar
They must be in the doors
Thread Tools
Custom Swift Headlamps blueraven316 Modifications & Accessories 82 4th August 2008 23:16
Best ICE Setup with Good SQ without 6*9s in the boot? TrueDreamer Ask the Gurus 18 3rd February 2008 13:41
swift audio setup without affecting boot space ronk Ask the Gurus 22 15th October 2007 11:47
Hey guys!! check out my custom swift!! Abix Modifications & Accessories 9 16th April 2006 21:17
Audio setup for Swift gemballa Ask the Gurus 27 20th February 2006 16:57
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
