| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #1 (permalink) |
| Newbie Join Date: May 2006 Location: Kuala lumpur
| Hey guys! 2 problems... 1. how do i get rid of the high pitch sound? 2. The other problem i have is when i turn on/off my system, there will be a "thub" sound. what causes that and how to get rid of it? I've got a basic setup of two amps, one 10"sub and 2 sets of component speakers. 1 amp drives the sub while the other powers the front component set. the rear set is driven by the player. they all go through an electronic crossover. Hope i've provided enough information. Thanks in advance! |
| | #2 (permalink) | |
| Team-BHP Support ![]() Join Date: Mar 2004 Location: mumbai
| Quote:
Who installed your system? Which amps do you have? To remove/reduce alternator noise check your wiring. To reduce/remove the turn on thud check your amps.
__________________ Scixelsyd Etinu | |
| | #3 (permalink) |
| navin, A regular shop got it done for me. that said that the wire brand is a good one so i dont know what make it is. Amps i'm using are sony (sub) and coustic (front component) What do i look out for on the amps with regards to the "thud" noise? the whinins bit i guess i can live with as it's audible a low levels. But the thud is scary! Like it really pumps the speakers... The sub is driven by a 1ohm amp by "sony" (meant for subs) and the front speakers are driven by a "coustic" amp. they all go through an electronic crossover by prestige. My player is a sony. I guess the high pitch sound is bearable cause it's only audible at low levels but the "thud" is really scary... what do i look out for on the amp for the "thud" sound? Thanks for the reply ![]() |
| | #4 (permalink) | |
| Quote:
Is the thud only heard from the sub amp or from both amps (try one at a time). the whine can be irrirating. If the cables are good (BOSS cables are notorious for not being able to isloate whine) like Monster or Audisson, etc... then maybe you are ty routing the RCA cables away from the power cables. I always tell my installer to wire the RCA and speaker cables on the right side and the Power cables on the left. Not that the side makes a difference but it makes for simple intructions and keeps the cables apart. Now you got one more component that I wonder about. The Prestige Crossover. To isolate the source of all this noise..connect one component at a time. try this. 1. connect jsut the coustic amp and HU and all 4 speakers. if that is ok (check for the whine and thump) then.. 2. add the sony amp and connect the sub to that amp (check for the thump). if that is ok then 3. add the prestige crossover. BTW why do you use an external electronic XO (which is what I assume the Prestige is)? are you triamping (sub amp + using a 4ch coustic amp to drive the woofers and tweeters)? If not you could make do with using the passive crossovers your components speakers came with and using the HPF of the coustic amp to filter out the stuff below 60Hz or so.
| | #5 (permalink) |
| hang on... first of, i made a lot of grammar mistakes earlier... sorry for that. Now, its 2 component sets and one sub. the rear component is driven by the player (short of 1 amp). The front component is driven by the coustic amp and finally the sony amp is driving the sub. Now, they all connect to the XO in which level adjustment and roll offs' can be easily accessible. I'm not triamping... ![]() As to the thud, i was told that the amps are to old. Actually they are roughly between 10-15 years. Sound is very clear... just the thump. I've actually brought those amps from my previous car and even then the "thump" was there. That sound comes from both the amps... i guess i really have to test it out properly.. but to what i recall, before i got the XO, that sound was still there... sigh... Thanks so far. Guess i should take my time with this and get it checked! |
| | #6 (permalink) | |
| BHPian | Quote:
what Head Unit do you use? this usually happens with the pioneer HU. i had both the problems which were sorted out later. cheers clip | |
| | #7 (permalink) | |
| Quote:
sage, the thump can sound dangerous but as long it only in the wofoer amp (sony) it is safe. Is it that loud? What bothers me more is the whine which should be recitified by redoing the wiring. Old Pio amps used to have a turn on thump. the soft start ckt is quite easy to implement. just 2 tranistors (why if one is smart one can make do with a single transistor and a diode). Dont bother though. If the thump is too loud and in the coustic amp there is a small chance (very small) that you can blow the tweeters.
| | #8 (permalink) |
| Senior - BHPian | sage I have read the thread and did not understand a thing....not even grammar also ...so please list your equipment properly and the second thing which speaker or woofer gives the thump......it is the front or rear or the sub or just left side ones or right sides ones or all of them.... |
| | #9 (permalink) |
| LBM from what I understand Sage has a HU connected to a (Prestige) crossover. the crossover is connected to a Sony amp for the bass (10" woofer) and the cousitc amp for the front components. The rear components are fed from the HU.
| | #10 (permalink) | |
| Senior - BHPian | Quote:
I think the EQ is the culprit.....sage try the setup without the eq and then comment.... | |
| | #11 (permalink) |
| Senior - BHPian Join Date: Sep 2005 Location: New Delhi
Infractions: 0/1 (4) | Whine and turn-on pop? The HU appears to be a Pioneer. Just ground your RCA ground to the car chassis. This alone will solve your problem.
__________________ Often imitated, never duplicated! |
| | #14 (permalink) | |
Do what Gunbir said... See this thread (What is a condenser?) if you need a picture of what to do. Allready been discussed. Also please use the search in the future ![]()
__________________ "Its not the size, its the heart, so dont hate... Accelerate !!!" | |
| | #15 (permalink) | |
| Quote:
I wanted to try the search but i didn.t know what to look out for... ![]() Thnks for the advice. Navin, the thump has been there for years! finally one tweeter gave way. The speakers are old too. I've just been bearing with that sound. I hope that when i try removing the EQ and do what gunbir said, it might atleast lessen the whine... A picture would help thanks again! | |
| Thread Tools | |
Similar Threads | ||||
| WHINING SOUND - Pioneer HU - Any Help ? | passion4cars | Ask the Gurus | 4 | 23rd August 2008 19:48 |
| Strange humming noise from my Safari(EDIT: Solved, window was open hence the noise) | himanshugoswami | Technical Stuff | 14 | 14th May 2008 16:00 |
| Swift = Whining in Overdrive | ballkey | Technical Stuff | 37 | 17th October 2006 02:55 |
| Wind noise or Aerodynamic noise | vivaid | Technical Stuff | 15 | 2nd July 2006 20:58 |
| Whining sound from speakers at low volumes... | frankmehta | Ask the Gurus | 16 | 17th May 2006 16:19 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
