Thread Tools
Old 10th June 2007, 00:18   #1 (permalink)
Awaiting Email Confirmation
Default External Power for ICE, can it be done?
Hi all,
I was thinking of something and was wondering whether it could be done or not. Is it possible to have some way with which one can connect the car ICE to an external normal 220 volts power source..so that if one opens the boot and decides to have a party of somekind, fuel and car battery are preserved...is something like this possible? has anyone ever done something like this? how much would it cost?
Thanks alot
I hope i was clear enough
vidvai is offline   Reply With Quote
Old 12th August 2007, 10:31   #2 (permalink)
Rehaan's Avatar
Hi Vidvai,
There is a solution for what you are talking about.
Its kinda like a UPS (Uninterupted Power Supply) in your car, kinda.
Sam will be able to give you more information as i think he has recently done some research on these.
cya
R
Old 12th August 2007, 11:15   #3 (permalink)
Dhar's's Avatar
I think it is possible. I have seen a similar set up in a RAM.
The system could be from a AC power source as well. The guy explained to me how it worked but after seeing that setup, my senses were numb and didnt understand a word he said.
It had 2 Rock Ford P3 15" Subs, 4 T series amplifiers, and God knows how many speakers and woofers inside the cabin, one LG LCD/Plasma TV and PSII.
Dhar's is offline   Reply With Quote
Old 12th August 2007, 12:00   #4 (permalink)
Hi Vidvai,
cya
R
I was thinking along the same lines. Because, if i put a UPS(w/o a dedicated battery) between my ICE and the car battery, then the UPS would have an AC connection, which when connected to any power source would "untrip" the UPS from the car battery.
I guess that is what is needed..although..deep inside I have no idea of what i am saying.
__________________
Speed kills! BUT IT SURE DOES THRILL!
Old 12th August 2007, 14:50   #5 (permalink)
low_bass_makker's Avatar
You will needing a AC to DC power supply to power the setup. The rating of the power supply will depend on the load you plan to put on it. Like Sam Bhai made the eyeballer and used a 150 amps power supply to run the setup indoors. You dont need a UPS just a AC to DC power supply capable to give the juice to the setup...
The eyeballer had the following config...
http://www.team-bhp.com/forum/115059-post1026.html (Car Audio Advice from the Audio Gurus: Use "Search thread" before posting a new Q!)
http://www.team-bhp.com/forum/115063-post1027.html (Car Audio Advice from the Audio Gurus: Use "Search thread" before posting a new Q!)
Old 12th August 2007, 15:55   #6 (permalink)
WOW!
Actually thing is, that i will need something to automatically switch between car power and the AC power, when the plug is plugged in. Even if not automatically, i will need some sort of switch to do it.
Also, what do i tell my friendly neighborhood mechanic? As in, what instructions do i give him?
__________________
Old 12th August 2007, 16:21   #7 (permalink)
Vivekphadnis's Avatar
So you want a switch with which you can switch between the external power and car battery?
__________________
Thank God for DIY audio.
Vivekphadnis is offline   Reply With Quote
Old 12th August 2007, 20:00   #8 (permalink)
Sam Kapasi's Avatar
So Weird,
I replied in the morning and it's not there! Maybe I'm a newbie that's why.
Sure vidvai, you can get a 12V external power supply. e will need to know how many amps and speakers you have, to decide how many amperes you need. The power supply can be even more powerful than your battery.
Be prepared to spend though it's not cheap.
__________________
Live the YetiLife®
Old 13th August 2007, 01:49   #9 (permalink)
Originally Posted by Sam Kapasi View Post
So Weird,
Oops..the last sentence made me skip a beat. On this forum, when people say expensive, i get scared, very scared.
Well, i have one sony 554, one 12" pio sub, 2 6X9s pio, and 2 sony explods(6.5"). The HU is kenwood dpx 701 double din.
How expensive would it work out to? Why would it be so expensive?
Well yes. Actually, i just want a convenient way of running my car audio through a normal electricity plug.
__________________
Old 13th August 2007, 11:30   #10 (permalink)
A normal 12 volt car battery charger would be enough for your application, and a spare battery along it.
Old 13th August 2007, 12:12   #11 (permalink)
Sam, he needs one of the PSUs you had for the eyeballer at Vahan Yatra, maybe a tad smaller.
__________________
Old 13th August 2007, 14:27   #12 (permalink)
navin's Avatar
You need a 220VAC to 14V DC adapter capable of delivering 50A.
__________________
Scixelsyd Etinu
Old 13th August 2007, 15:00   #13 (permalink)
Sam Kapasi's Avatar
Vidvai,
A decent 50A power supply would cost more than all of that equipment put together. A high end one would cost about 4 times the money you spent for all that equipment.
It would have to be a switch mode supply (A transformer based 50-60A supply would be mammoth), perfectly regulated, with forced cooling.
Components that go to make this would be expensive.
However 50A is an over estimation. You could manage with a decent 25A power supply. Expect it to cost about Rs. 12000/- -15000/- for a nice quality regulated SMPS.
__________________
Live the YetiLife®
Old 13th August 2007, 16:01   #14 (permalink)
Thanks alot Sam, Navin and Vivek. But this is working out to be alot alot over what i had expected it to. So i guess i will just scrap it, for now at least, till the time i can probably DIY it all.
Thanks a lot guys, just hope this thread helps others.
__________________
Old 13th August 2007, 16:07   #15 (permalink)
navin's Avatar
the 554 puts out about 50W rms x 4 = 200W. assuming 50% efficiency it would need 400W. add a bit more for the HU and you could be looking at 500W.
500/12 = 40A. since you dont get 40A components of the shelf i suggested 50A.
__________________
Scixelsyd Etinu
Thread Tools
ICE & Battery / Power issues s0uljah Ask the Gurus 38 21st September 2008 00:17
Brake lights cutting power to ICE??? tmanish76 Technical Stuff 7 31st March 2008 12:28
Uninteruppted Power for ICE bruce Ask the Gurus 26 23rd October 2006 17:05
power-house of ICE need help!!! amit_sound Ask the Gurus 54 17th May 2006 13:27
How to determine what size Power Cables for ICE? Answers inside... gunbir Ask the Gurus 96 8th May 2006 12:34
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
