| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #16 (permalink) | |
| Distinguished - BHPian ![]() | Quote:
Here is where I disagree with you. Imagine, your source is low on highs and mid highs, therefore more dominating on the bass, low mid front. You run it through a system with a subwoofer. The already dominating lows are further amplified and the submissive highs take a step further back? I think, if he is keen to listen to his Indian 128Kbps CBR recordings, he needs a system with clear emphasis on mid and highs. Lastly, mithun, you need to have a broad and open humorous mind to come to this section. The broad is for me, the open mind is for you to appreciate our stupid jokes. Kasam Paida karne waali ki.
__________________ Live the YetiLife® Last edited by Sam Kapasi : 16th June 2007 at 13:19. | |
| | #17 (permalink) | |
| Senior - BHPian | Quote:
@Mithun, even i have a 2K songs error free songs on my ipod (hindi/english mix) and most of them are either 128kbps bit rate or lesser and only thing that you will miss is the loundness or the jingle and jangle (treble) for the rest of the main components of the music ( midrange and especially bass ( my fav of the lot ) remains more or less intact.Simple solution is to play a few of your songs in a car ( find somebody) having a basic system and then play the same in another car having a more expensive system and i am sure the fog will be clearer. Good Luck !!!
__________________ [b][i]The nail that sticks out gets hammered !!! | |
| | #18 (permalink) |
| BHPian | I don't think mp3 makes songs "low on highs and mid highs" or "dominating on the bass", does it? I believe amount of highs is still there but their quality is compromised during compression. Some encoders (like lame for example) are good at the job while some are not. Last edited by santosh.s : 16th June 2007 at 21:03. |
| | #19 (permalink) |
| BHPian Join Date: Feb 2007 Location: Kolkata
| So speakers that are criticised as being a bit too bright may actually make these MP3s sound more accurate?
__________________ Every man has his follies. And often they are the most interesting things he has! |
| | #20 (permalink) | ||
Of 128Kbps CBR:- I think you believe this too. Quote:
That automatically will translate to bass domination at higher volumes - this is a simple simple equation. Make everything else a little soft and the bass is loud. To suggest that the person then add a subwoofer with an amplifier to THIS system, thereby amplifying the only thing that is not compromised, is to practically kill the highs and mids into submission. We're not discussing LAME here. Or any other high quality MP3 convertor/ripper/encoder or what have you. Mithun has a simple request, he just wants to listen to his 128CBRs. @nura- Not accurate, I believe an overall brighter setup may tend to be more enjoyable in a case where the source is noticably less bright, if the source has ill-pronounced highs. This ofcourse will also increase the noise and hiss factor, but one can't have everything. This is strictly MHO ofcourse.
__________________ Live the YetiLife® | ||
| | #21 (permalink) |
| BHPian | Not to further confuse mithun with details, here is my opinion once again in simple words- 1. CD versus 128kbps CBR mp3=> I won't change the quality of system between two just for the format difference. It would rather depend on what you listen to, oldies or new songs as given below. 2. Oldies = recordings lacking in bass, sub won't be utilized much, 6x9 ovals would be enough. Noisy in treble, you may have to reduce treble anyway to avoid hiss. So, highly capable tweeter will also be underutilized. Though, I don't know how to strictly define oldies as such, because one might call Bhappi da's disco songs mostly featuring Mithun da (you? ), as oldies, but I think those records are good.3. Modern songs (probably everything after 80's, definitely after 90's) = Much better recordings, I would go for a good system including a sub. @Sam sir, no arguments... |
| | #22 (permalink) |
| Senior - BHPian | Thanks for the overwhelming response (especially hydrashok & Sam) !!!! For the old songs, I've used GoldWave and cleaned out most of them. I've also normalised the dB level of all the MP3's using MP3Gain And, I'm a great fan of treble than bass. So what should I do to get crystal clear treble ?
__________________ Hold fast to dreams, for if dreams dry, life is a broken-winged bird that cannot fly. |
| | #23 (permalink) | |
but dont you feel tired or irritated after you listen to too much high freq for long duration? Or did you mean you like strings kind of?
__________________ -__- | |
| | #24 (permalink) | |
| | #26 (permalink) |
| BHPian | hi, sam bhai, could you please explain the difference between Constant bit rate and variable bit rate. if already discussed before, please let me have the linky:-) . honestly speaking, i have my collection mostly in 128kbps cbr. i've tried to test both mp3 and original cd with a same track but couldn't really make out the difference between them. maybe i wasn't serious enough about the test thing. cheers clip |
| | #27 (permalink) | |
| Team-BHP Support ![]() Join Date: Mar 2004 Location: mumbai
| Quote:
What a friend tells me (I dont use CBR) is that VBR 320 is better than CBR 256 but the files size in 320 VBR is actually a bit smaller than CBR 256. Music used was Miles Davis, Pancini, and Rolling Stones. more here. ScratchLIVE.net · General Discussion · CBR vs. VBR continuation thread...
__________________ Scixelsyd Etinu Last edited by navin : 18th June 2007 at 18:12. | |
| | #28 (permalink) | |
| Team-BHP Support ![]() Join Date: Mar 2007 Location: Bangalore
| Quote:
__________________ Never believe it cannot be done - it's only that you haven't found out how!!! | |
| | #29 (permalink) | |
Just make sure your Audio CD is not made from reconverting that 128KBps file lol
| | #30 (permalink) |
| Senior - BHPian | ^^There is a massive difference even between 320kbps mp3 and plain old cd/ripped WAV/FLAC. If the equipment is resolving enough, its very very audible. However the difference between 128kbps whether VBR and CBR and uncompressed/lossless compressed media is audible even on crappy 1000-1500 rupee speakers. |
| Thread Tools | |
Similar Threads | ||||
| 1 lac to spend on a 1.8TPI..what would you do..? | nanu28 | Modifications & Accessories | 4 | 13th May 2008 20:17 |
| How much do you spend on fuel every month | Rtech | The Indian Car Scene!! | 156 | 24th January 2008 22:03 |
| How much you spend to visit bunk? | sathya_nars | Shifting gears | 14 | 21st August 2007 07:52 |
| 48 Hours! And how best to spend it than...... | speedzak | Street and Travel Experiences | 64 | 11th August 2007 01:54 |
| How do TBHPIANS spend their free time | Team Fiat | Shifting gears | 47 | 16th June 2005 02:54 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
