Thread Tools
Old 29th June 2007, 13:04   #46 (permalink)
shrayv's Avatar
no idea abt the pre-amps...
how can find it out.....
and by the way i thought i can get the tweeters + an aux setup as a bday gift...
the budget just seems to be soaring
shrayv is offline   Reply With Quote
Old 29th June 2007, 13:23   #47 (permalink)
panky12345's Avatar
Infractions: 0/1 (4)
see, thats the best part about ICE, loving to spend others money....i came here with a budget of 6-7K more than a year back; upgraded and stayed.
on a pretty serious note, this becomes a vicious circle. pehle tweeter, then comps, then amp, reh gaya sub, then woh bhi, then wires, then confusion for brands....and so on.
i would recommend going to a decent car accessory shop, listen to both "only tweeter" and "comps" option and then decide.
u might like to audition desi TS20; they are good for the kinda money that u spend and always have the option to upgrade; they would also solve your purpose of getting just highs.
__________________
SINGH IS KINNNNNNNG..
Old 29th June 2007, 13:30   #48 (permalink)
shrayv's Avatar
thnks for the advice but the desi ts-20's are too powerful
anyways will find out the other brands too
Old 29th June 2007, 13:34   #49 (permalink)
navin's Avatar
You got the model number of th HU? We have a secret weapon who can get the required info once we have the model number.
__________________
Scixelsyd Etinu
Old 29th June 2007, 14:35   #50 (permalink)
DerAlte's Avatar
Desi or phoren, I'd recommend you listening to the tweeters in a car (preferably your own) before deciding. If you have heard it in someone else's car before, and that is making you say that, then please think: the other guy may have had an amp with it (forget the brand for the moment) and may have also set Treble to MAX.
At a pinch, maybe setting treble higher in your own HU may satisfy you, if you have not tried that.
Also, trying means listening different sources - different CDs, different FM programs, etc. - many times to find out whether what you have is really lacking.
__________________
Never believe it cannot be done - it's only that you haven't found out how!!!
Old 29th June 2007, 19:24   #51 (permalink)
shrayv's Avatar
the setting in my eq is
bass 5
mid 2
high 5
the maximum setting is 6
Old 30th June 2007, 18:51   #52 (permalink)
shrayv's Avatar
i've finally decided to go in for for amp first and then upgrade later
which ones do u suggest?
which one is better, 2ch or 4 ch amp? and whts the difference in terms of output
Old 30th June 2007, 19:47   #53 (permalink)
panky12345's Avatar
Consider this:
2 speakers + 1 sub : 4 channel;
2 speakers : 2 channel;
4 speakers : 4 channel;
only sub and 2 speakers from HU: 2 channel
better would be to go in for a 4 channel (future udgrade). You may want to consider JBL 75.4 or Pio 6200. both are good; u'll be better off (sound wise)with JBL though!!
__________________
Old 30th June 2007, 21:06   #54 (permalink)
Sam Kapasi's Avatar
bass 5
mid 2
high 5
I think the first thing you need to do is bring those numbers as close to ZERO as possible.
__________________
Live the YetiLife®
Old 30th June 2007, 22:08   #55 (permalink)
shrayv's Avatar
wht setting do u suggest
Old 1st July 2007, 12:57   #56 (permalink)
shrayv's Avatar
and how much do the JBL 75.4 or Pio 6200 amps cost???
Old 1st July 2007, 15:01   #57 (permalink)
low_bass_makker's Avatar
the 75.4 is for 13k with b/w and 9k without
the 6200 amp is for 6k without b/w
Old 1st July 2007, 15:10   #58 (permalink)
shrayv's Avatar
any other models which comes under 6k
Mods note: Suggest you collate your thoughts and post. Read to gather your set of questions. Please don't treat this like a chat board.
Thanks.
Old 1st July 2007, 15:53   #59 (permalink)
Thats what Sam says, close to ZERO.
__________________
I am an eco-driver
2001 Santro LP - 16.8/18.2 kmpl in C/H
2007 Verna XXi - 14.2/16 kmpl
Visit ecomodder dot com
appuchan is offline   Reply With Quote
Old 1st July 2007, 16:38   #60 (permalink)
shrayv's Avatar
sorry for the mistake rudra....
i'll start again,
i'm lookin for 4ch amp below 6k
and i'm goin for an aux setup.....
i've enquired from a dealer abt the aux setup....he said there are 2 options
1. normal aux cable and the other one - 750 bucks
2. the wire with which u connect the multi-cd changer.... 1000 bucks
which one will be better
Thread Tools
GTO 608c Tweeter Terminals vrrraju Ask the Gurus 10 2nd September 2008 01:26
Tweeter Mounting Position - Rear Door Component ? BHAGWAN Ask the Gurus 2 23rd June 2008 12:23
JBL 607c my-T1 tweeter VS infinity tweeter vkhandelwal Ask the Gurus 15 31st October 2007 17:31
immediate sale amp,tweeter,sub,spkr clipto333 Shifting gears 1 8th February 2007 04:55
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
