Thread Tools
Old 8th July 2007, 13:15   #1 (permalink)
i_m_anaconda's Avatar
Default Speaker Upgrade for my Santro
I have a Santro that is about 5 years old.
The current system that i have has following components
Pioneer HU - 5650
Sony speakes in front near glove box and stearing column ( dont remember model nuber: were provided free by dealer)
Pioneer tweeters
Pioneer speakers (TS-A6981S) on the wooden plank.
I want to change my rear speakers. But i have following questions for which i am seeking some help from Gurus.
1) Does occasionally filling up your boot with luggage cause any issues to speakers. I ask this because i have observed that my last speakes started giving problems after i came back from my trip to wayanad. My boot was completely packed with luggage in this trip.
2) What are best speakers that will go with my setup.
3) Do i need to add an amp for this setup.
Thanks to all Gurus in advance.
i_m_anaconda is offline   Reply With Quote
Old 8th July 2007, 20:36   #2 (permalink)
DerAlte's Avatar
@i_m_anaconda (baap re baap, kya deadly handle hai), it all depends on what you are planning to do.
* Do you want to add an amp or do you want to drive the rear speakers from the HU as you are doing now?
* Do you want to continue with the 'wooden plank' or do you want to put the speakers in boxes over the wheel arches (better results than the plank, and the speakers are always safe)?
* What is your budget (most important)?
If you want to see a dramatic improvement without doing much, go for a pair of JBL GTO937 or Blaupunkt THx 693 - but LISTEN to the speakers somewhere first before deciding.
Without an amp, the cost would be less than 5K. With the amp, you may need to redo the whole thing, which may require a budget of at least 12K without changing the HU (the questionable Sony speakers in the dash would definitely need to be changed if you use an amp)
* The amount of luggage in the boot won't affect your speakers, unless something is rubbing against or poking into the speaker cone. It just might make the sound a tad different, but you may not notice it with the road noise
What problems did you encounter with the speakers after your trip?
__________________
Never believe it cannot be done - it's only that you haven't found out how!!!
Old 8th July 2007, 22:49   #3 (permalink)
My budget is about 7-10K.
My first choice would be to drive the rears using HU as this would minimize the expense. But, if decent coax can not be handled by HU's built in amp, i can go for an amp also.
Can you suggest me a decent one for my HU?
The problem i am having with my speakers is that it gives tearing sound some times.
Old 8th July 2007, 23:47   #4 (permalink)
I would want to drive the rears using HU as it would be a cheaper option. But, if using AMP remarkably increases the sound quality i can go for an amp.
Can you suggest some decent amp for my setup. Also let me know what would be approx cost.
About problem with existing speakers: I get atearing sound some times.
Old 9th July 2007, 14:23   #5 (permalink)
navin's Avatar
a good 4 ch. amp would cost you 7-10K itself.
for now, just get the 6x9 a good pair will cost you 4-5K and then you can replace the 4" sony speakers with somethng nicer as well (cost 3-4K).
JBL, Blaupunkt, Hertz, Illusion etc. all will have something in this price range.
__________________
Scixelsyd Etinu
Old 9th July 2007, 15:55   #6 (permalink)
DerAlte's Avatar
Does the "tearing" sound come with FM radio or with CDs? Or both?
What you described sounds like there is noise getting into your music ('static', like you get in landline phones in rainy season). The reason could be one of many - loose wires, bad grounding, loose antenna, ... A good installer would be able to correct the problem.
As Navin suggested, you could listen to different brands and decide which sounds best for you.
__________________
Old 9th July 2007, 16:11   #7 (permalink)
mobike008's Avatar
@Deralte, i think he is talking about the speakers making those noise due to not getting enough power to drive them, hence the cracking noise.
Anaconda, first try a nice co-axial and test them powering from your HU, if you hear the same cracking noise if you turn up the volume to decent levels then you better get an amp. I recommend the JBL GTO937, i have the same and its clean and crisp sounding.
Cheaper solution for an amp is Sony 222 ( 4K) and decent amp would be JBL 60.4 ( 6.5k) even better would be 75.4 ( 13K)
__________________
[b][i]The nail that sticks out gets hammered !!!
Old 9th July 2007, 16:57   #8 (permalink)
navin's Avatar
How old are your current speakers? Does the tearing sound only come from the front speakers.if so I suspect you are driving the front speakers with too much low freq. information. If this is true you could aleviate this by adding a simple "bass blocker".
OT warning: Actually Der Alte, Anacondas are rather shy and not really agressive (compared to say Cobras or Pythons esp reticulated pythons or "retics" as they are known). You can (under controlled conditions and with care and pracctice) handle a anaconda but dont ever thy that with a "retic". How do I know. Well my son is into all things creepy and crawlie.
__________________
Scixelsyd Etinu
Old 9th July 2007, 18:28   #9 (permalink)
gopinathann's Avatar
I have a Santro and installed Pioneer HU (don't remember the model, it costs 10k) with Sony XPLOD rear speakers. It gives the sub woofer effect with deep bass. Since I keep this setting one of the speakers gives a hiss sound when bass is more. I have disconnected one speaker. I think with Pioneer HU, Blaupunk rear speakers should be good. I plan to change to Blaupunkt when the other speakers go out.
gopinathann is offline   Reply With Quote
Old 9th July 2007, 18:32   #10 (permalink)
DerAlte's Avatar
You are right, the HU would be clipping (to express it conversely).
Eeuugh, not for me, even if they were the friendliest of animals. I don't think I will get an answer for "Are you hungry?" from them. I'd rather give all those a wide berth with a "Sorry for intruding into your personal space"!
__________________
Old 9th July 2007, 23:17   #11 (permalink)
Sorry for not being able to reply earlier!
To answer some of the questions asked
1) The speakers are about 2.5 yrs old. Had bought it from grey market
2) The tearing sound is common with FM and CDs.
3) It is mainly from one speaker and that too when i am playing some music that has a lot of drums.
4) Yes, it is more when i increase the volume.
If it is problem of HU not being able to drive the speakers, i wonder how was it working for 2 years.
Old 10th July 2007, 10:54   #12 (permalink)
navin's Avatar
do you only hear the "hiss" when the bass is high? Is a hiss or more like a "phut"?
__________________
Scixelsyd Etinu
Old 10th July 2007, 10:57   #13 (permalink)
navin's Avatar
4) Yes, it is more when i increase the volume.If it is problem of HU not being able to drive the speakers, i wonder how was it working for 2 years.
Over the past 2 years your speaker's surround has lost it. This sounds like a worn surround. This can be fixed but do not expect the same quality of sound as the orgiinal. If you can afford it, i would change the speakers. Still 2 years seems an awful short time for even foam surrounds to die. Are you sure you got new stock not something lying on the dealer's shelf for say 5 years?
__________________
Scixelsyd Etinu
Old 10th July 2007, 11:01   #14 (permalink)
Its more of a "PHUT"
Old 10th July 2007, 11:04   #15 (permalink)
Not sure if they were on shelf for long time.
I think i will go for a change of speakers and would opt for a B&W this time.
How would Sony 222 and GTO0937 work with my existing setup?
Thread Tools
Speaker Upgrade sk456 Ask the Gurus 82 30th September 2008 00:50
Stock speaker upgrade on Hyundai Tucson VEA Ask the Gurus 3 10th July 2008 13:42
Need help to upgrade from Santro to a Sedan blueband4u Sedans 32 23rd June 2008 17:19
Please help with HU upgrade for Santro harsh87 Ask the Gurus 15 17th March 2007 11:01
Need help for my Santro rear speaker AdXing Ask the Gurus 126 9th September 2006 13:15
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
