Closed Thread
Thread Tools
Old 16th July 2007, 15:44   #121 (permalink)
low_bass_makker's Avatar
Originally Posted by clipto333 View Post
LBM, two highly respected persons who know their stuff have said it. just name the person from whom you want to clarify. who are the other audiophiles? ok jb, navinji, b&t please can we have your comment on lbm's question? no offence bro.
None taken Sir.
I agree here that there is a difference in Audio CD and MP3, No doubt in that. but can they tell which one of the either is playing with listening to it.
low_bass_makker is offline
Old 16th July 2007, 15:48   #122 (permalink)
gunbir's Avatar
Infractions: 0/1 (4)
Sure Gunbir but would you pay more if your exisitng "CD only" could also play Mp3 or other formats. Remember the caeveat "without affecting the sound of the CD output".
No I wouldn't pay more. Not a single rupee actually. Our Panny Tube HU has MP3 but we've never really used anything other than ACDs on it. Never have never will.
__________________
Often imitated, never duplicated!
gunbir is offline
Old 16th July 2007, 16:06   #123 (permalink)
DerAlte's Avatar
the arguemnt is that why dont MOST high end systems include Mp3
Because nothing comes for free!
A manufacturer like Wadia or M-L may not:
* see the need to invest for a market segment they are not focusing on (maybe a prejudice, but it is *their* choice)
* want to increase complexity, BOM cost and chances of failure, even though they could use a general purpose CPU to handle the codec & disk directory handling
* have the expertise or people to integrate the MP3 codec and the disk directory handling at the silicon level into their controller chip
Originally Posted by abhi182 View Post
Why should a 400K DVD player be any better than a PC ..any half decent Video card with HDMI support should technically be able to blow the 400K dvd player to oblivion
That would be too much generalization.
HDMI is an interface, not a guarantee of resolution - and you have not accounted for a high-resolution (1600x1200) display to complete your hypothetical PC. Cost of a "half-decent video card" rises exponentially after the medium-fi (1280x1024) PC display cards.
End-to-end HDTV is *costly*. And no, PCs are still no match for HDTV at 1024p - try HDTV material on a high-end PC monitor and you can see the difference; also, would you like a PC in the middle of your drawing room?
__________________
Never believe it cannot be done - it's only that you haven't found out how!!!
DerAlte is offline
Old 16th July 2007, 16:17   #124 (permalink)
abhi182's Avatar
DerAlte, this is not a hypothetical PC, it's alive & kicking in my house
Anyway, let us take the Display out of the discussion...
that 400k DVD player and the hypothetical PC can be connected to the same display (whether a tiny 26" LCD or a 106" Plasma)
So with the fair assumption that the same display would be used as the output device for the 400K DVD player and the PC....why should the output of a PC running even a puny 7600GT be not better than the 400k DVD player (connected to the same 1024p HDTV)
abhi182 is offline
Old 16th July 2007, 16:31   #125 (permalink)
^^yup Santosh..you missing sumthng
You need a DAC to conver the digital data stream to analog output that can then be fed to the Amp...and the qiuality of this DAC is in fact perhaps more important than the quality of the Amps...
I didn't get you... I was NOT talking about differences in cheap versus good DACs or pre-amps or amps. Because I know there can be significant differences. I was only asking about "transport" (disk reading mechanism). And I guess our understanding is same- cheap CD player should be as good as fancy one as long as it is digitally connected (coax or optical SPDIF link, or HDMI) to rest of the system and is capable of reading disks without any data errors.
most people get bad audio from PCs because they use the low grade on-board sound output
BTW, there has been great improvement in the quality of "on-board" sound cards. They were indeed quite bad say 5-6 years back, but as of now they are far better.
santosh.s is offline
Old 16th July 2007, 16:38   #126 (permalink)
DerAlte's Avatar
Let us just assume the same display (whether a tiny 26" LCD or a 106" Plasma) would be used as the output device for the 400K DVD player and the PC
So why should the output of a PC running even a puny 7600GT be not better than the 400k DVD player?
Till the VDAC output stage the issues are the same: compression and decompression losses and "gains" (the subject of discussion of this thread), right? So the drive (error rate), codec and the VDAC matter: same logic as average versus high quality Audio CD players.
Beyond that, it is a comparison of the bit drawing rates on the display (this includes the transfer rate over HDMI and the speed of the final display buffer in the monitor). The best displays available now do it at 6-8ms, frame time is 20ms for non-interlace - still comparable. Screen size matters - becomes slower as screen size increases: longer conductors, more capacitance, lesser speed!
__________________
DerAlte is offline
Old 16th July 2007, 16:41   #127 (permalink)
zucchero's Avatar
lbm,in order to differenciate between the two,one needs to listen to the set up extinsively.even the so called'audiophiles' listen to the equipments for HOURS before comin to any conclusion.
we were only for 3-5 minutes in your car and you want us to hit the spot in the blind test!!!!!!!
zucchero is offline
Old 16th July 2007, 16:45   #128 (permalink)
abhi182's Avatar
True, but if you want your source to be as good or better than a dedicated Wadia/ NAD or any other good dedicated CDP, you can't compare the noisy onboard sound with the quality DACs and pre-amps on a dedicated CDP
To reach or better that level, you need to invest (not much in comparison though) on a quality DAC like a M-Audio Audiophile/Transit
External DACs sit outside the electrically noisy chassis of a PC cabinet and are typically USB connected to the PC
Thus if you are playing say a FLAC or a Wav (or a mp3 for that matter), your PC (sasta as many may percieve it to be in comparison ) acts as a digital streamer only....
This digital output (Bit-perfect as some call it) goes to the external DAC which converts it to a clean analog signal and feeds it o the amp....
Yup..pretty much!
Better still, why not just rip the CD as a wav/FLAC onto your Hard drive and simply eliminate the data error/skipping problems altogether
abhi182 is offline
Old 16th July 2007, 16:49   #129 (permalink)
abhi182's Avatar
Deralte, think you are missing out on my point...
What I am trying to get at is, everything else being the same (i.e. for the same display), a 400K DVD player would be no better than a simple mid-end PC
As for the VDAC, that is the reason why I talked of HDMI since HDMI takes away the whole VDAC part out of the equation from the Video player's side
Now a binary output from a million $ device would be the same as the binary output from a $200 box....wouldn't you agree? After all the million $ device can't beautify that binary output in any way and if it does, it is doing a bad job then
abhi182 is offline
Old 16th July 2007, 16:52   #130 (permalink)
abhi182's Avatar
Wouldn't my car journey come to an end in those few hours?
sorry, couldn't resist that
abhi182 is offline
Old 16th July 2007, 16:52   #131 (permalink)
Originally Posted by DerAlte View Post
So the drive (error rate)...... same logic as average versus high quality Audio CD players.
Do you mean to say that cheap drives will have unacceptable error rates in order to preserve the original quality? Remember, there is a certain theoretical limit on the "quality" of any digital record (which corresponds to each single bit being correctly read, in time). No system can ever cross that.
Old 16th July 2007, 16:56   #132 (permalink)
abhi182's Avatar
^^exactly, and also, data reads from any half decent Hard disk drive (Or better still, a solid state drive) will have better error correction and lower error rates than the best quality optical drive
abhi182 is offline
Old 16th July 2007, 17:07   #133 (permalink)
moralfibre's Avatar
Very interesting discussion. I have had a demo in some audiophile cars which include Sam, Ajay, Shrivz and EVO6. When we auditioned Sam's Verna he played MP3's and I was satisfied with the output. I wouldn't have noticed difference if he started playing an ACD first. I have had the privilege to hear Ajay's Sierra + Palio + WagonR and he auditioned his setup using MP3 CD's and I found it equally great as Sam's Verna. Same goes with Shrivz setup as well as EVO's setup.
I didn't even know that EVO's car had an HX-D2 until I saw his Audi audio thread. Now I didn't know that the HX-D2 doesn't play MP3's but only ACD's before Gunbir mentioned it somewhere on this thread. I think I need to take an extended hearing to notice differences. The point I am trying to make is most equipment I was auditioned too was done on MP3's and they sounded satisfying enough for my listening tastes.
Since Navin mentioned that adding an MP3 feature in any of these high end HU's wouldn't make a difference in SQ right? So why wouldn't manufacturers add say around $50-100 to the existing prices and give it as a feature.
How many customers does the world of car audio in India get who ask for an exclusive test of equipment on original audio cd's only?
__________________
"As long as there are short, balding, middle-aged men, there will always be a market
for the Porsche 911." - A BMW Owner. :)
moralfibre is online now
Old 16th July 2007, 17:31   #134 (permalink)
rocksterraghu's Avatar
A very interesting discussion indeed. I had a great time going through this entire thread and would like to just put my opinions forward:
1. (A Marketer's point of view): There is a different segment of customers targeted every time a product is planned, with a strong research and their ways of listening understood, pretty much thoroughly. So, the marketers may have realized that people who would buy a true SQ HU, would only listen to Audio CDs since they are very very meticulous about SQ and would NEVER need MP3 playback. There may be other reasons like a survey would have made them understand that a customer wanting to buy a great SQ HU already has his big collection of Audio CD's that he has collected, preserved and cherished for years and would give a damn to MP3s (which may also mean that he can always afford to buy the original Audio CD's from the store like he buys peanuts). Marketers wouldn't want their segments overlapping too much, they would rather have different products for different segments and that would make their job an awful lot easier. The HU's made for this segment would be simply dedicated to the core activity that it does, plays music to a T. Period.
2. (An Audiophile's version) If I could afford a HU that was built to be one of the best for SQ, I would never bother to play MP3's on it. I would like to make the best use of the best product and it is as simple as that. Whether I can make out the difference or not when it is crowded is out of question, I would still love to play Audio CD's and wait for those quiet patches when I could switch to my favorite track and enjoy my music in the BEST possible manner.
IMHO.
__________________
Everything should be made as simple as possible, but not simpler
rocksterraghu is offline
Old 16th July 2007, 17:44   #135 (permalink)
I think wave audio is better but what mp3 offers is 90 % of the same quality with 100 % of mobility like its easier to download transfer and save
it offer more songs per storage device so it has its own benefits but it cannot be as good as the pure wave track
rubin2006 is offline
Closed Thread
Thread Tools
Car Audio Advice from the Audio Gurus: Use "Search thread" before posting a new Q! Sam Kapasi Ask the Gurus 8960 18th November 2008 22:24
SQ MP3 Players rahulv1 Gadgets, Computers & Software 20 19th September 2008 16:49
What's my best mp3 solution? vebmetal Ask the Gurus 22 12th September 2007 10:38
Audio cd or Mp3 ? Beemer Shifting gears 27 30th April 2005 15:24
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
