Thread Tools
Old 17th July 2007, 22:04   #16 (permalink)
Originally Posted by DerAlte View Post
(OEO = O Enlightened One!
Not yet enlightened... none of the answers explain what makes car subs more suitable to acoustics of a car's cabin!
Some more background on my questions- I knew that in any room, above certain frequency (corresponding to the lowest room mode), there is this unavoidable problem of reflections and standing waves. And it is "chaotic" to say the least. But leaving that part aside, I had little or no information on what happens below the lowest room mode frequency. The mouthshut debate was based on what I had learnt from an article on Rod Elliot's page (see section on wave versus pressure-mode propagation of sound):
The Subwoofer Conundrum
Today I saw another passing comment about this on Linkwidtz Lab site (see section "C2- Sound waves in a rectangular, rigid room"):
Room Acoustics
However, both these articles cover the point superficially, thereby leaving it unclear. Both of them seem to imply that at very low frequencies (low being defined by the size of room or cabin), pressure-mode dominates over soundwaves. And that the "pressure-mode" leads to improved acoustic response for subwoofers, popularly known as room or cabin gain. The first one says that sealed subs perform "better" than ported ones under such circumstances, whereas the second one says this gain is 12dB/octave for "sealed" subs (no mention of ported subs here!).
The last point about sealed versus ported can actually be a good sub-topic for this thread
santosh.s is offline   Reply With Quote
Old 17th July 2007, 22:31   #17 (permalink)
Sahil's Avatar
I love the bass that was put out in my mercedes. Was very clean and crisp as opposed to hard and loud when you use a sub woofer.
Havent been able to achieve such bass from other speakers that i have ever fitted in any of my cars.
I am yet to find speakers that can give such bass in standard fitment.
__________________
______________
__________
______
__
Sahil is online now   Reply With Quote
Old 18th July 2007, 00:32   #18 (permalink)
navin's Avatar
I was talking about what happened after that: OEO asked "how is a car sub different from home sub (Ignoring all electrical or environmental factors)": sub as a component. .
Oops. Ok most car subs do not make good home subs. Most home subs wont survive too long in a car.
I have used home subs in a car (4 8" 8N515 Focals becuase I had them lying around and the install in my nephew's car called for a small sub so I built him a pair of isobarik 4th order bass reflex). The sounded good while they lasted but I guess Mumbai's heat and humidity got to them before too long.
There are a few home subs that look good as car subs. Many of these have heavy cones, huge surrounds, and huge Xmax and low Sensitivity. They are meant to be driven with big Class D amps and while they can pump out prodigious ammounts of bass in the home or in a car the bass is not of very good quality.
I feel that most car subs if used at home will need proper placement to produce decent bass and even then might end up sounding a bit lumpy. I have never used car subs at home (as usually I have more home speakers lying around than car speakers) but Vivek Phadnis is working on such a design. We will see what happens when he is done.
__________________
Scixelsyd Etinu
Old 19th July 2007, 07:50   #19 (permalink)
mithun's Avatar
The length of the average car interior (including trunk) is in the 12 ft range the 40 Hz note will be longer then the car's interior. This is why notes below 70-90 Hz (depending on the vehicle) will have a greater output than the rest of the frequencies. Once this magic frequency is reached, bass output will increase by about 12 dB/octave below that frequency. This phenomenon is called cabin gain or "transfer function". So a smaller vehicle will have a greater cabin gain and should be able to have greater low bass than a larger vehicle. This is true for identical subwoofer systems with identical power.
Because there is so little space in a car the bass notes (which are long waves) build up inside the passenger area. Hope that may be the reason why we can't produce clean bass in a car's cabin.
__________________
Hold fast to dreams, for if dreams dry, life is a broken-winged bird that cannot fly.
Old 19th July 2007, 10:21   #20 (permalink)
You mean to say as you go on reducing the cabin size, more and more "clarity" will be compromised. Think of headphones- there is very tiny space between them and ears. However, they are very good at producing "clean" bass (Not only they are supposed to be free from room modes, they are also able to provide stereo bass). How do you explain that?
Like I said earlier the reason we are able to produce bass that is lower than the wavelengths supported by the boundaries (in a car or in a home) is that we are
1. able to damp all resonance nodes and their overtones sufficiently enough for these low frequencies to be heard
-Resonance modes occur at frequencies above the one that corresponds to twice the maximum dimension of the room, not below that. Since car cabin's max (internal) dimension is quite low the first room mode itself should be quite high in frequency. Say it is 5-6 feet, then there should not be any resonance mode below wavelength of 10-12 feet, which is about 100Hz, and it covers pretty much the whole "bass" range! Does that mean that bass in fact may be cleaner in cars as compared to typical homes?
-Room modes or standing waves are a result of reflection from rigid boundaries. In case of car the tin walls are far from being rigid for acoustics. I believe they vibrate themselves so much and a lot of sound is transmitted outside, especially at bass frequencies. That is probably why people hear that thump from a passing by car. And AFAIK, the damping material applied in car walls helps more to tame its own vibrations (ringing) than helping in reducing the reflected sound. And in any case, damping materials don't help much for reflections at bass frequencies, right?
Old 19th July 2007, 12:07   #21 (permalink)
tsk1979's Avatar
There is a wrong assumption here, i.e. the car is an enclosed space.
Its not. Its only a partially enclosed space.
A car may be 12 feet long but how thick is the steel?
We can safely say atmost 2 sheets totalling about 1 inch.
Also car doors or glass do not have vaccum, right?
So the "sound energy" is not enclosed, but can be easily transmitted outside.
If you take car which has sound proof glass, i.e. vaccum or air filled double layer glass, then you will get more.
Now if your wavelength is 12 feet, and your car has 6 feet of space, that will lead to a standing wave.
In a car like environment, which is not "opaque" bass energy can be dissipated easily, so no issue of energy buildup in normal cars.
To have a good Bass response, the interior of a car should be such that it does not reflect sound.
Why do you think Cinema halls have all those thick curtains, so that no reflections are there.
As long as the level of reflections in a car is kept to minimum, the Bass will be clean.
__________________
Reclaiming.....!
Old 19th July 2007, 12:23   #22 (permalink)
low_bass_makker's Avatar
Sir in a headphone it is a case of IB install with on side of the driver is cover directly over the ear and the other side is open, the work done is by the air trapped between the ear and the driver.
Old 19th July 2007, 12:41   #23 (permalink)
As always, nothing is perfect in practice, so yes it can not be considered as infinitely rigid enclosed space. But on the other extreme, it is not fully transparent (acoustically) also, which would be as good as open air- cabin boundaries would be no issue at all, in this case. It has to be somewhere in between these two. As compared to cement-concrete rooms that most of us live in, car is much more transparent and I had mentioned this point.
if you are referring to metal sheets used to make the body, it is far less than 1 inch.
I believe glass is much more opaque (rigid) than metal/plastic doors (although for sound, not light!)
You are referring to techniques to make it more sound proof, but as I said above solid glass itself is pretty much sound proof and it causes significant reflection of sound. Glass walls are a major problem in room acoustics (though, in spite of this fact, you may find many "demo" rooms with glass walls all around!)
Well, I know why curtains are there, but do you know that they are good at high frequencies and that for bass they provide little or no benefit?
Old 19th July 2007, 12:48   #24 (permalink)
Exactly, so I was thinking that the air trapped in the cabin may be doing some similar job. Though it is not as "trapped" as in headphone because of its size is relatively bigger. As the size becomes very big, there is no "trapping" as such and it would become more of "free" air. Does it make sense?
Old 19th July 2007, 12:51   #25 (permalink)
navin's Avatar
guys mithun does have a point.
All cars have a transfer function and part of that transfer function is a roll off in the low bass (below 60Hz). Car subs are designed to compenate for this roll off by having a rising response.
Like I said it is not diffcult to produce bass in a car but dont expect a home sub to do the job satisfactorily.
The gauge of steel in a car is 18GA or at best 16GA. Even with damping it does resonate some. Almost every door panel resonates. If one built a car that was really sound proof one would nee a 400 cu in block to move it and it would give 4 mpg.
__________________
Scixelsyd Etinu
Old 19th July 2007, 13:16   #26 (permalink)
I guess you have said it the other way round, by mistake. There is a "gain" at lower frequencies and subs have to be "roll off"
Old 19th July 2007, 13:35   #27 (permalink)
DerAlte's Avatar
Not entirely. "Free air", as the term is used, is absence of interplay, i.e. absence of a "transfer function". Headphone "trapped air" does have a transfer function, so it is not also "free air". Canal buds, or in-ear EPs are the closest, where the "free air" is a few cc with no interplay (other than the hair in the canal). Capisce?
Santosh, now THAT is the closest to enlightenment you can get on car subs v/s home subs.
Navin-ji, !!! Sorry, there was a problem with the decoders all this while, and it was going OHT.
(Navin-ji, Metric units please, Imperial/US is confusing) Why *would* one want such a sound proof car? Talking of psycho-acoustics, don't forget the NVH distraction. From another viewpoint, if one can afford perfection, such a car and 4MPG are insignificant issues.
__________________
Never believe it cannot be done - it's only that you haven't found out how!!!
Old 19th July 2007, 14:08   #28 (permalink)
I referred the term "free air" for two things-
1. Completely (acoustically) transparent boundaries, which is as good as having no boundaries.
2. "As the size becomes very big", here it is literally like free air.
Regarding transfer function, well free air is NOT neutral or "without interplay". It absorbs high frequency energy better than lower ones, that is why as you move further and further away from a sound source, you hear more of bass and less treble. In speaker enclosures, air does not compress linearly if the amount of compression is too much. That is why large throw (Xmax) woofers in relatively small enclosures suffer more from air-compression related distortion.
However, I tend to believe in whatever you have said about canal buds- that their transfer function comes (relatively) close to "no interplay". Because the only better method that I can think of is attaching the voice coil directly to ear drum
Are you serious here, or making fun of his typo??
If you go through the links that I have been posting, you know that I did have an idea about this "cabin gain" and I think most of us have. But that explains the "boom" factor, real enlightenment would be knowing what happens to SQ (our religion) or any additional gyan.
Old 19th July 2007, 15:16   #29 (permalink)
clipto333's Avatar
Even I am waiting for the gurus' knowledge and views on Subwoofer drivers (HT and ICE). Uee habh hard Nobhin-ji and LBM-da, now uee are oetting phor Gunobir and Clip-da and athars to shay shamtheeng. Hoeyar eej Sham?
did you mention my name deralte? was it by mistake? im not a guru, im shishya . also im not a home audio guy at all and i know little about ice.
im participating by reading this thread.
im really enjoying reading this thread. its giving my brain a good workout. i have never seen a thread in which one gets so much technical gyan. keep up the good work guys(gurus)
cheers
clip
clipto333 is offline   Reply With Quote
Old 19th July 2007, 22:01   #30 (permalink)
DerAlte's Avatar
Your lunch must have really disagreed with you, as must have mine with me. Both of us are making fundamental mistakes!
Oy, shorter waves (higher frequencies) attenuate lesser, travel further. True for all frequencies from audio to light, no? That's why you need to push more power into the subs (and Xmax matters) than into the tweeters, no? And a whistle is heard farther than a bellow? And the crack of a cracker heard farther than the boom?
You have described the ultimate bionic audiophile!!!
Shantam papam, shantam papam! Car Gain is not the only component of the Transfer Function, and nor is apparent loudness in 2 different environments! Car Gain makes it sound louder than, say, your drawing room, but does not explain frequency response and roll-off. That way, a bad HT woofer would be a great car sub practically? Or am I missing something? You're the expert.
Yes, I did, @clip. (Sorry, I forgot to include @B&T!). And no, it is not a mistake. A "guru" is by attitude, by thinking, not just knowledge. You have that, as does TEO - and that's what matters, bandhu.
__________________
Thread Tools
Did any Indian company produce a Hummer look-alike? salilpawar1 The Indian Car Scene!! 16 12th November 2008 15:51
Cabin Interior Lights kjdesigns_2000 Modifications & Accessories 17 7th November 2007 10:54
Chinese co to produce British sports car in America Ram The International Automotive Scene 2 14th July 2006 15:54
Toyota to produce low cost vehicles for emerging markets bigman The International Automotive Scene 0 3rd April 2006 01:04
India to produce 2,00,000 Harias tomorrow aandy Shifting gears 1 3rd December 2005 15:29
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425</
