| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #31 (permalink) | |||
| BHPian | Quote:
. Why high frequencies are used in communication has many other reasons, like their interaction with earth, atmosphere around it, interference from outside space, reliability. There are some basic reasons as well, like-1. The size of transmitting antenna, lower frequencies need very big antennae. In audio it is size of sub versus tweeters. 2. Low frequencies need to operate at high power levels, again same as in audio. I don't know the exact reason, but I feel that for an efficient receiver, you should have equally big antennae but that is not the case. Imagine AM radio with a 100 meter antenna . In case of audio too, microphones that I know of are in generally small... including our holy pair of ears! When you compare different sounds, it depends on not only the power level, but the psychoacoustics as well (equal loudness contours) and what power low and high frequencies have to begin with. If you measure db level of two frequencies at different distances, roll off of higher frequency with distance will be more. Quote:
![]() Quote:
| | #32 (permalink) | |
| Team-BHP Support ![]() Join Date: Mar 2004 Location: mumbai
| Quote:
2. Car Gain / Room Gain is nodal. These gains are not like LPFs. The gain is peaky and is dependant on the size of the room/cabin, absorbtion/diffusion/dispersion characteristics of the cabin/room, the placement of the speakers within the room (the speakers will excite the nodes diffrently when placed at different locations; the nodal freqencies do not change just the level of their excitment) and remember all this can mean different things for different people a lot depends on the music you are listening to. Baroque music for example will make for a very different expereince than Trance.
__________________ Scixelsyd Etinu | |
| | #33 (permalink) | |
| Quote:
Like I have said beofre Room/Cabin Gain is not like a LPF. Just becuase a cabin has a 6db boost at 60Hz it wont nesscarily have a 12db boos at 30Hz.
| | #34 (permalink) | ||
| BHPian | Quote:
Buttttt....... I "believe" that this behavior happens above a certain frequency which is the lowest room mode, and its wavelength is twice the longest internal dimension of the room/cabin. Real questions that I have are -I repeat it once again- What happens to frequencies below the lowest (i.e. the first) room node? -Is it as chaotic as explained above, and spoils SQ? -Or is it more like a smoother, cleaner, LPF gain? -Is that the reason why sealed boxes are better suited to cars, which have a natural roll-off of 12db/octave? This link tends to say that it should be so since the room gain experienced for sealed boxes is exactly equal to this- 12db/octave (it is a hyperlink in the previous link, named "below the lowest room resonance" : http://www.linkwitzlab.com/images/gr...losure-spl.gif I tend to think that at very low frequencies, it is more like a much cleaner, LPF kind of gain. Because I definitely don't hear room modes in case of headphones/ear buds/canal buds, and still enjoy very good bass....unlike home. And then, I have another related questions as mentioned in post #16: Are sealed subwoofers more suitable under such room gain conditions? Do ported ones show weired behavior (their problems getting aggravated or something)? | ||
| | #35 (permalink) | |
| Quote:
Sealed box woofers do have a roll off that is very much similar to room gain. Ported boxes rolll off 6db/oct after than sealed box woofers. Again one might not hear his difference (faster roll off) is one's music does not have significant information in the very low bass (sub 40Hz).
| | #36 (permalink) | |
| Team-BHP Support ![]() Join Date: Mar 2007 Location: Bangalore
| Quote:
__________________ Never believe it cannot be done - it's only that you haven't found out how!!! | |
| | #37 (permalink) |
| BHPian | By now, I am pretty much enlightened ![]() Navinji, the point taken about rooms/cabins being "leaky". Effect of leakiness is very apparent in case of ear-buds and headphones. Just a little loose and you miss a lot of bass, make it firm and bass is brought back to life. I think the effect is almost absent in case of big ear-cup type of headphones which remain sealed with cushion and firm enough around the ear, all by themselves. BTW, once I lost a foam cap of my Nokia headset and I was desperate to get it back for the same reason. I thought shopkeepers would laugh at me if I asked for that tinny foam pad! So I just bought a Rs. 40/- ear-bud of similar size, took out their foams and stuck them permanently to the headset with Fevicol. Why not, I am a DIYer too ![]() OK, open question now is about "ported subs operated below lowest room resonance". Let me be more precise about it: Do ported subs have trouble with frequencies in this "gain" region? I know that if the frequency is below it's port tuning frequency, then it anyway has it's own trouble. And the gain can only make things worser. But the question is- that let us say the frequency is within the range it was designed for, but it falls in the gain region of the room/cabin- In this case, will it's sound be deteriorated as compared to what it would be in an anechoic chamber? |
| | #38 (permalink) | |
| Quote:
I have little knowledge about ahechoic chambers. I have only seen one twice.
| | #39 (permalink) | |
| BHPian | Quote:
Not to mention, I am just asking these things for academic interests. I want to understand theoretical aspects to a reasonable extent, by that I mean- until it is fairly easy to deduce practical significance, without any contradictions/confusions. | |
| Thread Tools | |
Similar Threads | ||||
| Did any Indian company produce a Hummer look-alike? | salilpawar1 | The Indian Car Scene!! | 16 | 12th November 2008 15:51 |
| Cabin Interior Lights | kjdesigns_2000 | Modifications & Accessories | 17 | 7th November 2007 10:54 |
| Chinese co to produce British sports car in America | Ram | The International Automotive Scene | 2 | 14th July 2006 15:54 |
| Toyota to produce low cost vehicles for emerging markets | bigman | The International Automotive Scene | 0 | 3rd April 2006 01:04 |
| India to produce 2,00,000 Harias tomorrow | aandy | Shifting gears | 1 | 3rd December 2005 15:29 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
