Thread Tools
Old 20th July 2007, 13:11   #1 (permalink)
vebmetal's Avatar
Default Bluetooth HUs - audio quality?
I am shopping around for an ICE system for my Estilo, and I came across some HUs which have Bluetooth. Seems like it has two uses - to act as a handsfree option for your cell phone, and to be able to stream music to the system (i.e. from your mobile phone).
I tried the streaming option at a dealer, but the audio quality was terrible - most likely because it was being streamed over bluetooth, though there is a small chance the audio file was not very good in the first place. (Also my phone does not have a2dp - that could be the reason).
Does anyone have any experience with these? If so, what is your opinion? Should one go for Bluetooth HUs or is it a frivolous and impractical expense?
vebmetal is offline   Reply With Quote
Old 20th July 2007, 15:42   #2 (permalink)
hemanthisgreat's Avatar
it depends on the head unit u are buying and also ur phone. i have a pioneer 7850bt headunit. i have played mp3 music on the car audio through bluetooth on the phone. it plays really well. and this HU works really well when you use it to connect it to ur phone to make and receive calls. its really helpful if u listen to loud music, as when there is an incoming call, the music switches off and you will be able to speak through the mike and listen through the car speakers. its most useful if u are alone in the car, as everyone will be able to listen to the conversation on the speakers.
__________________
It's not about how you act, how cool you are, or what you're wearing. It's all about how LOUD your car is.
hemanthisgreat is online now   Reply With Quote
Old 20th July 2007, 17:47   #3 (permalink)
devarshi84's Avatar
Delphi grundig X350BT
Clarion FB276Bt
JVC KD-BT1
Pioneer 7850BT (Dont know if it streams music)
Blaupunkts have BT but dont stream music.
Quality shouldnt be a problem if the phones support A2Dp. BTW if your phone doesnt have A2Dp, how did you play music in the first place?
__________________
boyracer.blogspot.com
devarshi84 is offline   Reply With Quote
Old 20th July 2007, 18:08   #4 (permalink)
rocksterraghu's Avatar
Bluetooth has a total bandwidth of 721kbps (kilo bits per second not bytes, if you're not a techie) of data/voice which should be more than sufficient to stream the audio files on your phone. The question is, how capable is your phone and your HU.
I once tried streaming audio from my phone to my laptop that comes bluetooth enabled through the 'handsfree' port and the quality was pretty sad. So, I guess you need to stream stereo audio, the full bitrate from your phone to achieve the quality you desire. I really have no experience with streaming stereo audio.
__________________
Everything should be made as simple as possible, but not simpler
Old 20th July 2007, 18:18   #5 (permalink)
i have this HU. it does stream music. it has got a feature called bluetooth audio, for streaming music from any external bluetooth device.
__________________
Old 20th July 2007, 18:56   #6 (permalink)
devarshi84's Avatar
how much did it cost you?
__________________
Old 20th July 2007, 19:39   #7 (permalink)
the pioneer 7850bt HU cost me 18500
__________________
Old 20th July 2007, 21:05   #8 (permalink)
Nice thread! I was actually very interested in getting details about bluetooth audio streaming.
I only know that A2Dp is some thing which lets you stream some "good quality & stereo" music(??). Can somebody please give more details about it-
1. Does it transfer audio as raw samples (after decoding), or it just sends it as data files, leaving decoding for the destination device?
2. Max bit-rate? (already answered by Raghu: 721kbps). Is this rate guaranteed across all BT variants?
3. If it is raw audio, what is max sampling rate, bits per sample and number of channels? (with above bitrate, CD quality (2x16bit@44.1KHz) is not possible at all)
4. Is there any method to stream music other that A2Dp (most likely inferior, mentioned in fine prints in the manuals if there is no A2Dp support)?
santosh.s is offline   Reply With Quote
Old 20th July 2007, 21:43   #9 (permalink)
CD quality (44.1 kHz 16 bit Stereo) audio requires 1411.2 kbps bandwidth in the transmission medium. The highest bitrate achievable over Bluetooth is 721Kbps. So, a codec, Subband Codec (SBC) originally developed by Philips is used which ensures that a player will compress the CD-quality-stereo file into a size that fits into the Bluetooth bandwidth, and the headphone or speaker on the other side decompresses the streamed audio.
Bluetooth specifies the Advanced Audio Distribution profile (A2DP), which define procedures that are specific to streaming of audio content over Bluetooth. Devices that implement the A2DP profile can play one of two roles, Source (player) of an audio stream or Sink (headphone or speaker) of the audio stream. This profile also provides for Quality-of-Service maintenance to ensure high quality audio transmission, through mechanisms such as Jitter buffers and variable bit-rates.
Also note that bluetooth also supports other optional Codecs such as MPEG-1,2 Audio, MPEG-2,4 AAC, and the ATRAC family.
__________________
Old 20th July 2007, 22:01   #10 (permalink)
vebmetal's Avatar
So I assume my problem is basically that my phone doesn't have a2dp. Well that's ok since I don't really plan on storing music on my phone (which also means that I shouldn't really care about Bluetooth on my HU).
But for purposes of information, how is the sound clarity on Bluetooth as compared to streaming via a FM transmitter (like the iTrip) ?
Old 21st July 2007, 01:17   #11 (permalink)
I don't have first hand experience, so I can't compare the two. However, looking at the two technologies, I think Bluetooth would be a better choice.
If you really want to buy an FM transmitter, please don't buy products like Griffin iTrip, they are really really bad. I bought an iTrip (Griffin) for about 2k and used it for 5 minutes and NEVER EVER used it again. You may consider superior products like - harman/kardon Drive+Play iPod interface, which I guess Sam uses in his Lancer .
Honestly, there are better ways of playing music in your car, like CDs, full speed cables connecting your audio source to the HU or USB drives for example. If you're looking for convenience, then USB drives are a good option - cheap and versatile!
__________________
Old 23rd July 2007, 14:14   #12 (permalink)
sushrutha's Avatar
Hi ...
Can someone explain me as how to use this feature.
I have a pioneer DEHP 5990IB HU, And a bluetooth enabled Mobile which has a feature " Play song via bluetooth device " .
__________________
Honda City
Maruti ZEN - SOLD
Maruti 800
Bajaj Pulsar
Old 23rd July 2007, 21:15   #13 (permalink)
Originally Posted by sushrutha View Post
Hi ...
your HU does not support bluetooth, its that ur phone has bluetooth capability, you cannot use the feature discussed in this thread
__________________
Old 24th July 2007, 15:22   #14 (permalink)
sushrutha's Avatar
Well my HU does support bluetooth. I think i have to put a dongle to HU via the USB cable . Is it so?
My HU manual says - BLUETOOTH ADAPTER READY ( vIA EXT).
__________________
Honda City
Maruti ZEN - SOLD
Maruti 800
Bajaj Pulsar
Thread Tools
Bluetooth car kit or Bluetooth HU? vebmetal Ask the Gurus 40 25th October 2008 11:58
Alpine HUs luvjascha Ask the Gurus 3 22nd July 2008 11:41
BlueTooth Car Audio System + Security System venky6009 Ask the Gurus 1 2nd November 2007 05:45
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
