Thread Tools
Old 27th July 2007, 03:21   #1 (permalink)
vikram18's Avatar
Default Focal speakers
I had installed Polk Momo series speakers in my Honda Civic earlier (comps upfront, and coaxials at the rear). I wasn't very happy with the rears as there was a distinct buzzing noise. The installer maintained it was due to the thinness of the speaker tray, but after even more damping and subsequent replacement of the rears (Vibe coaxials), the noise went away. I replaced the HU with an upgraded touchscreen version and now the sound is even better. My only problem with the components is that they're just too "bright". Tweaking the crossover hasn't really helped and the equalizer just doesn't do much and I'm planning to replace these as well.
Here's my current configuration
JVC EXAD touchscreen HU
Polk Momo components
Vibe Coaxials
Alpine 4-Channel amp
JBL GTO monoblock
JBL subwoofer
Monster cabling throughout.
Here are my questions for the Gurus
1. Which are the best Focal speakers that you'd recommend
2. Will replacing the stock wires with thicker Monster cables reduce the brightness of the tweeters?
3. If I install components as both fronts and rears, will I need a subwoofer all the time, and will they lack bass if I detach the sub?
4.If budget is not an issue, what are the best speakers that you'd suggest?
vikram18 is online now   Reply With Quote
Old 27th July 2007, 05:11   #2 (permalink)
v1p3r's Avatar
Can you put up a pic of your HU? Never seen an aftermarket HU install in a Civic, though I'm a real noob in this section.
__________________
I've lost my phone. Please PM me your phone number if I'm on your contact list.
Old 27th July 2007, 05:56   #3 (permalink)
sk456's Avatar
The best Focals that I have heard are the focal Beriliums Kit 7. But... then to get the most out of them you need a very well tuned set up.. installation will also greatly matter... the Kit 7 goes very well with the focal dual monitor amp.... Be preapred to shell out a LOOOT of moolah for them....the whole thing includign the amp will take you back by over 5-7 K Dollars...
Frankly if you dont like the "bright"" sound Focal might not be the best choice.... i would look at Dynaudio,Morel,Rainbows for a more mellow top end.
__________________
Car : Kenwood - Tru - Rainbow - ID
Home : Dynaudio - Krell
In the audio world, adding to the music is the biggest sin.
sk456 is offline   Reply With Quote
Old 27th July 2007, 09:00   #4 (permalink)
hydrashok's Avatar
@vikram,
1. i don't have much personal experience with Focals. I'd go by what sk456 said. I've heard mostly the same on the 'net.
2. No, thicker wires won't make the speakers less bright. (And Focals do tend to be inherently a bit bright if you plan to get them). Maybe you can do a bit of XO modding a la Navin to tame the highs? And maybe the XOs have a setting in the to cut the highs?
3. Comps in back will not essentially improve bass response. You have Vibes in the back now. if bass-support is all you are looking for, I think they will do well enough. Comps in the back will make the overall music sound better if you sit in the back. Else, personally, I think getting comps in the back are really not needed. Maybe coaxialsin the same range from whatever brand you get in front will be better.
But if you are planning to upgrade your front stage, then I guess there is no harm in moving the current comps to the back and ditching the vibes.
4. Again, I'd go by sk456's recommendation. I'd add Hertz Hi-Energys to that list. BTW, saying "budget is not an issue" is akin to suicide here, ok?
I haven't seen one either. it usually needs the Scosche adapter or a lot of FG skills.
__________________
Alpine 9887 | TRU Tech S44 | Image Dynamics XS65 | Image Dynamics IDQ12 D2V2 | Connection Audison
Old 27th July 2007, 10:46   #5 (permalink)
navin's Avatar
of these 3 I'd try the Rainbow's first. Dynaudio is very laid back and Morel's designs are based on Dynaudio patents.
__________________
Scixelsyd Etinu
Old 27th July 2007, 11:52   #6 (permalink)
sk456's Avatar
yes.. Dynaudio was too laid back for soem genres of music according to my taste... Morels were also quite mellow.. Rainbows were jsut right for my tastes....
__________________
Old 27th July 2007, 12:53   #7 (permalink)
low_bass_makker's Avatar
1. If you dont like bright sound then forget the FOCAL.
2. No
3. If you need the low end of the sound. then a woofer is required.Component cannot replace a woofer.
4. there are many and sky it is the limit. the choice of speakers will depend on the other stuff you have in your car.
Like if you get the Dynaudio and run them through a Pioneer amp it will not do justice to them. For that you would need better amps like Steg, JL audio etc
so since you have alpine amp (which model) you can go for Infinity , Illusion Luccent series eTc.. as they are said to be smooth and non bright when compared to other...
Old 27th July 2007, 13:27   #8 (permalink)
navin's Avatar
LBM does have a point, FOcal, DLS, Rainbow, Dynaudio, etc... demand better amps.
Focal is sweet. I wont call them bright. With the right amps they can delvier detail without the harshness. Too bad ScanSpeak does not make a Revelator version for the car.
__________________
Scixelsyd Etinu
Old 27th July 2007, 13:31   #9 (permalink)
Navin Ji the Focal will sound sweet when connected with a sweet amp.
Old 27th July 2007, 13:32   #10 (permalink)
vikram18's Avatar
[quote=hydrashok;513443]@vikram,
Comps in back will not essentially improve bass response. You have Vibes in the back now. if bass-support is all you are looking for, I think they will do well enough. Comps in the back will make the overall music sound better if you sit in the back. Else, personally, I think getting comps in the back are really not needed. Maybe coaxials in the same range from whatever brand you get in front will be better.
I know comps wont "increase" bass response. My Q was that if I detach my subwoofer, which is in the boot (for more luggage space), how will the comps sound?
Old 27th July 2007, 13:35   #11 (permalink)
vikram18's Avatar
I have the Alpine MRP-F450. Sweet enough?
Old 27th July 2007, 13:36   #12 (permalink)
vikram18's Avatar
I'll post one really soon. You get an exact fit cabinet that can be fitted with any HU.
Old 27th July 2007, 13:38   #13 (permalink)
shrivz's Avatar
While browsing through other car audio forums, I've noticed that people say, Audison + Focal is a fantastic combo..
__________________
Technical skill is the master of complexity, while creativity is the master of simplicity...
shrivz is offline   Reply With Quote
Old 27th July 2007, 13:41   #14 (permalink)
but the combo will cost a lot....also the FOCAL is priced quite expensive in India and one can get better products for that price.
Old 27th July 2007, 13:43   #15 (permalink)
shrivz's Avatar
Yes, and they're not easily available in Pune, as far as I know, only Bafna Motors keeps Focal in Pune and that too, very limited stock. I havent heard them, so can't comment on how they sound.
EDIT: Technocrat once mentioned that Bafna had done a Focal install with a Sony amp. (the 554/544 whatever is the model no.)
__________________
Thread Tools
Mmats Audio And Focal? CaliforniaKnight Ask the Gurus 61 12th November 2008 23:41
Focal 165 V2 akg7091 Shifting gears 4 9th January 2008 14:52
Focal speaker voice coil smooshed. Need help!!! cleansound Ask the Gurus 7 28th December 2007 13:25
Alpine 9855+Focal 165KPS.. Need some help on the Amps skyliner Ask the Gurus 14 13th May 2007 01:03
speakers chetan Ask the Gurus 4 16th March 2006 07:03
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
