Thread Tools
Old 1st August 2007, 15:24   #1 (permalink)
Default Simple question regarding stereo
Does it 'damage' the car in some way if you listen to your stereo without actually turning on your engine? because i do it sometimes while i'm waiting for people and whatnot, and i was just wondering.
Thanks guys!
krayzii is offline   Reply With Quote
Old 1st August 2007, 15:35   #2 (permalink)
navin's Avatar
if you have a simple stereo with no amplifiers then it is quite safe to run the stereo for short periods of tieme (say 30 mins). but larger stereo systems with multiple amps can drain the battery quite fast.
When a car is started it demands a lot from the battery and these demands if not met means the car wont start.
__________________
Scixelsyd Etinu
Old 1st August 2007, 17:47   #3 (permalink)
hemanthisgreat's Avatar
my ice contains 2 sets of components and 2 amps and a subwoofer, and the car is a 6 month old hyundai getz, so would it be a bad idea to listen to music with the engine switched off. till date i have not had any problems even though i listen to music with the engine switched off. will it affect the battery in the long run.
__________________
It's not about how you act, how cool you are, or what you're wearing. It's all about how LOUD your car is.
hemanthisgreat is online now   Reply With Quote
Old 1st August 2007, 23:02   #4 (permalink)
esteem_lover's Avatar
Infractions: 0/1 (5)
It is probably a matter of time when it happens. I have also been guilty of the same (i have only one amp though).
__________________
Goodbye Dada, you made us proud.
esteem_lover is online now   Reply With Quote
Old 1st August 2007, 23:09   #5 (permalink)
gr8guzzler's Avatar
One more question from my end on the same topic, is it possible to add another battery which is dedicated for the music system only?
__________________
Kishore
gr8guzzler is offline   Reply With Quote
Old 1st August 2007, 23:21   #6 (permalink)
And how will you charge this battery ?
__________________
Old 1st August 2007, 23:49   #7 (permalink)
gr8guzzler's Avatar
No idea John, probably the same way as the main battery. I remember seeing on one of those "Pimp my Ride" shows, they had added additional batteries for the ICE.
__________________
Kishore
Old 2nd August 2007, 00:05   #8 (permalink)
this thread here could be of some use
http://www.team-bhp.com/forum/ask-gu...much-load.html (Help ... Need High Output Alternator TOO MUCH LOAD)
__________________
Old 2nd August 2007, 00:38   #9 (permalink)
Bass&Trouble's Avatar
A lot of competition vehicles use one or more batteries dedicated to the music system.
Batteries could be completely isolated from the music system, or they could be set to be a part of the charging system when the car engine is running.
__________________
Operator! Give me the number for 911!
Old 2nd August 2007, 01:09   #10 (permalink)
gr8guzzler's Avatar
Thanks Ajay. If you could share a bit more on how this can be done, that would be great.
__________________
Kishore
Old 2nd August 2007, 01:53   #11 (permalink)
low_bass_makker's Avatar
Hmm my fav topic.
Like Navin Ji said in the first post it all depends on requirements.
Using multiple battery where the current demands are high. and one has to play the setup with out starting the car. But I would never recommend to run the setup with out the engine running. because of the huge demand of power by the amps.
the extra batteries can be isolated by a relay with the main battery ciruit. But for charging them they need to be connected or even a separate alternater can be added also the stock alternater will be a quite small for this job so it is need to be changed according to the battery add in the car.
Old 2nd August 2007, 10:42   #12 (permalink)
no it's stock speakers and all, but it gets quite loud (and very nice with a big thud ) when i want it to be.
it's because sometimes when i wait for people or after cleaning my car i put it pretty loud.
sorry i'm kinda noob, but how can you tell if you have an amp or not?
Old 2nd August 2007, 12:02   #13 (permalink)
Like LBM said, a battery isolating device is used if you want to keep the system running without starting the car. This prevents your starter battery from discharging. The isolator completes the circuit only when the ignition switch is turned on.
The additional batteries are kept totally isolated from the starter battery when the battery/ batteries used for the system are of a different voltage from the starter battery which will almost always be 12V.
__________________
Old 2nd August 2007, 13:43   #14 (permalink)
navin's Avatar
you need an upgraded alternator and a dual battery isolator etc... so this can be done but why? are you often waiting for periods of more than 15 mins?
__________________
Scixelsyd Etinu
Old 2nd August 2007, 14:05   #15 (permalink)
2fast4u's Avatar
i have forgotten many times to turn off the stereo for over 10hours at a stretch (in a hurry to get to office) luckily its factory stereo with no additional amps.
__________________
332kmph 1999 unrestricted GSXR1300R
ROYAL ENFIELD MACHISMO 1992
636
RB20DET NISSAN
2fast4u is offline   Reply With Quote
Thread Tools
Integrated stereo question Revention Ask the Gurus 3 11th February 2008 16:56
Keep It Simple Kool_Kid Ask the Gurus 18 28th January 2008 21:33
Simple Car Stereo navin Ask the Gurus 50 22nd August 2006 23:29
a simple question.... panky12345 Ask the Gurus 1 6th April 2006 07:23
Few simple photographs arijit Shifting gears 5 28th June 2004 18:28
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
