| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #138 (permalink) |
| BHPian Join Date: Feb 2007 Location: Kolkata
| I am thinking of getting a separate amp for my sub. The 2 Ohm voice coils are connected in series to show 4 Ohm. What would the pros & cons of the following options be? Class AB Mono amp Class D Mono amp Bridged 2 channel class AB amp Bridged 2 channel class FD amp Thanks in advance. nura
__________________ Every man has his follies. And often they are the most interesting things he has! |
| | #139 (permalink) |
| I am planning to buy a separate amp for my sub & am thinking of running a separate 4 AWG power cable from the battery to the new amp, instead of going the distribution box route? Imported, branded power kits seem to be pretty expensive so I thought of looking for suitable cable on the Finolex website. However, the AWG rating of the products is not mentioned. Now the only thing that I know about 4 AWG wire (I am not even sure if this information is correct) is that its area should be 21.2 sq mm. On the Finolex website, under pvc insulated battery cables, there is a cable with the following specifications Conductor Nominal Area in sq mm 25 Conductor number & diameter of wire 196/ .4 mm Radial thickness of insulation 1.2 mm Overall diameter 9.7 mm Current carrying capacity 71 amps Is this what I should be buying? Any helpful link will also be sincerely appreciated. nura
__________________ Every man has his follies. And often they are the most interesting things he has! Last edited by nura : 30th August 2008 at 11:34. |
| | #140 (permalink) |
| Senior - BHPian | Ya it is ok for you. Here is something you would love to read... http://www.team-bhp.com/forum/696016-post15.html (A question about cables) Energy solutions - Metric Cable size to AWG Conversion |
| | #141 (permalink) | |
| Quote:
Once I buy the cable, I will need to attach connectors, fuse-holder & fuse. Are there any particular brands that I should look for? Also how are they to be fixed to the cable? Again, links will be sincerely appreciated.
__________________ Every man has his follies. And often they are the most interesting things he has! | |
| | #142 (permalink) | |
| Senior - BHPian | Quote:
You will need hole one for the ground to the chassis like seat mounting bolt. And one for the battery terminal. For the pin type it will go at the amp end. ![]() Take a print out and show it to the shop keeper. | |
| | #147 (permalink) | |
| Quote:
I did a little comparison between Finolex 25 sq mm & Lightning Audio 4 AWG. Finolex has 196 strands, Lightning Audio 1862 strands. I believe flexibility is directly proportional to number of strands. Does this mean that it will be difficult to route the Finolex from the engine bay to the boot of my Santro? I could not find out the number of strands in Connection Audison 4 AWG. I may have to buy Connection Audison if I can't find the appropriate fuse holder & fuse to go with the Finolex. At Rs 170 per metre, the Finolex is pretty attractively priced, though.
| | #149 (permalink) | |
| Senior - BHPian Join Date: May 2006 Location: Chennai
| Quote:
Thats some very good information. Also, wont it be better if the multistrand wires end are soldered just a bit at the end, to ensure that the strands do not snap while crimping? Cheers
__________________ Walk the Talk..Always! | |
| | #150 (permalink) | |
Ya, soldering the wire is a good thing , but since the thimble are soft , the breakage of copper is quite less. | |
| Thread Tools | |
Similar Threads | ||||
| Some Queries on My Santro Xing | MadhuG | Technical Stuff | 13 | 28th October 2008 14:37 |
| Tuning your Ice: What are Your Settings? | Magma | Sound Off and Show Off | 35 | 11th September 2008 00:41 |
| I-10 ICE [equipment & installation] Pictures | BHAGWAN | Sound Off and Show Off | 125 | 6th September 2008 22:08 |
| Tuning queries for Pioneer 7950 and JBL75.4 | vkhandelwal | Ask the Gurus | 21 | 17th September 2007 15:43 |
| My latest ICE Installation - NHC | AshOnTheRocks | Sound Off and Show Off | 21 | 20th March 2007 00:46 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
