| LinkBack | Thread Tools | Search this Thread |
| | #166 |
| Senior - BHPian | I think it is a little dirt in the amp switches which sometimes causes this type of interference. Try cleaning/fiddle with the amp/switches and then check. |
| | #167 |
| BHPian Join Date: Feb 2007 Location: Kolkata
| I have not been able to install the mono amp as yet so the 2nd power cable remains unterminated. Today while I was listening to a CD, I happened to blow the horn & the music stopped for a few seconds & then restarted but not from the same spot. It went to the beginning of the song! Did this also happen because of the unterminated wire acting as an antenna or is there some other problem somewhere? Looking forward to your replies, nura. |
| | #168 |
| Senior - BHPian | Doc, I think your ICE is hinting that you get that new car you were talking about ![]() Seriously though, I think you should get your wiring checked once, starting with the horn. Then try a process of elimination - connect each ICE component one by one to see if any of their wires is the culprit. I know this sounds very rudimentary, but it helped me sort out some wiring issues in my car. We should catch up sometime - would love to see/hear the new mono. |
| | #169 | |
| Senior - BHPian | Quote:
Would you be able to try removing the HU, pulling the harness off and snapping it back in, and then listening to music? If that doesn't solve the issue, will you be able to try with another HU, just to see if the problem disappears? | |
| | #170 |
| Thanks razor4077 & hydrashok for your suggestions. My harness is indeed a weak link as its wires are pretty flimsy. Are there any branded wiring harnesses available & how much would they cost? Someone told me that the harness for the Santro Zip Plus is different from the Santro Xing. Is this true? Where in Kolkata should I look for a good harness for my car? I am hoping to get my new amp installed on Holi day. Thanks in advance. |
| | #171 |
| Team-BHP Support ![]() Join Date: Mar 2007 Location: Bangalore
Thanked: 965 Times
| Harness flimsy? Nah, 'tagda' wires and connectors would be an overkill for the current that flows for the signals. The culprits for most problems is normally a bad/loose contact or an improperly mated connector. If the problem is not occurring frequently, don't think of making changes. Just check for loose connections. |
| | #172 |
| Thanks, DerAlte. Yes, I'll probably not do anything till the mono amp is installed. Let us see what happens after that. Just for my information, though, how much does a wiring harness cost these days? I paid 100 bucks for mine, 6 years ago. nura. |
| | #173 | |
| Senior - BHPian Join Date: Sep 2005 Location: New Delhi
Thanked: 12 Times
| Quote:
| | #174 |
| Thanks, Gunbir. I had checked with the Blaupunkt distributor in Kolkata some time ago. At that time he had the Xing harness but not the Zip Plus one. I will check again. Maybe I can place an order. |
| | #175 |
| BHPian | My JVC headunit used to have the same problem,i.e whenever the horn is used the whole HU restarts , first we thought the problem could be with the wiring harness,but later we traced it back to the HU itself,so got rid of and got myself a pioneer 5650. |
| | #176 |
| That's rather scary, but thanks, muneemmk, for sharing your experience. |
| | #177 |
| A very happy Holi to everyone. I utilized the holiday to install the mono amp in the morning. I don't know if the horn-related problem is solved or not, since I haven't taken the car out of the garage. But the sub is, certainly, sounding a lot better. |
| | #178 |
| Just wanted to report that, after installing the mono amp, the horn-related noise disappeared completely. The sub is sounding really good now. As of now, it's wired to show 4 Ohms but just to satisfy my curiosity, one of these days I'm going to wire it to show 1 Ohm & see what happens. I don't suppose I could do anything with the following. One pair of free preouts (rear) on the HU One pair of RCA cables One free channel (sub) on the old amp Thanks, all, for your help. |
| | #179 |
| BHPian Join Date: Feb 2006 Location: Chennai, Thiruvalla
| I was thinking of a small upgrade to my ICE and didn't want to start a new thread so querying here. My present setup is Pioneer DEH-P5050UB Hertz 6.5 Componets (front, think it is DSK 165) Hertz DCX 690 Co-Axs (Rear) Though I am mightily pleased with the sound I would like to add a lil more to it. I was thinking of adding a sub but something underseat 'cos I don't wan to loose any of the boot space. I did a lot of searching here and came up with Hertz ES 250. Is it good ? ![]() Can it go under seat ? What should be the box dimension ? Vented or Sealed ? Which amp can go with it ? If someone can recommend something that is less costing but equally good it would be so welcome. |
| | #180 |
| I had sent the car to the workshop to sort out a knocking problem. I had removed the sub from the vehicle to give the mechanics access to the fuel-pump. They replaced the air and fuel filters, cleaned the fuel-pump & did an engine tune-up. The knocking is gone but when I re-connected the sub & switched on the HU, the display came on but there was no sound from any of the speakers. The display showed the name of the 1st track on the CD (car had gone to workshop with CD inside HU) but track play time stayed at 0. I ejected the CD and re-inserted it. Normally the HU comes on when I do this, but it did not and I had to start it manually. Same result, no sound, display ok, track play time remains stuck at 0. I switched to radio and was relieved to hear the system start playing normally. I switched back to CD and the CD started playing normally too. I am left wondering what could have wrong temporarily and how I can prevent this from recurring. I have removed the sub each time the car went for a service but never faced this problem. My thanks in advance for your replies. |
Similar Threads | ||||
| Lancer ICE - Installation & Tuning Queries | pramodkumar | Ask the Gurus | 4 | 25th July 2012 21:57 |
| BMW 5 series - ICE, BSI aftercare packages & other post purchase queries | sujithnk | Modifications & Accessories | 231 | 18th November 2011 11:41 |
| Ice Tuning and hardware query in santro. | UniqueMods | Ask the Gurus | 12 | 23rd March 2010 11:15 |
| I-10 ICE [equipment & installation] Pictures | BHAGWAN | Sound Off and Show Off | 125 | 6th September 2008 21:08 |
| Tuning queries for Pioneer 7950 and JBL75.4 | vkhandelwal | Ask the Gurus | 21 | 17th September 2007 14:43 |
