Thread Tools
Old 28th August 2007, 20:19   #76 (permalink)
nura's Avatar
Which will be the best grounding point for my amplifier, if I install it on the left rear seat of my Santro? I wish to avoid drilling a new hole, if possible.
__________________
Every man has his follies.
And often they are the most interesting things he has!
nura is offline   Reply With Quote
Old 28th August 2007, 21:16   #77 (permalink)
sabret00the's Avatar
read the whole thread..this is way beyond my knowledge of ICEs hence gained a lot of knowledge...as a matter of fact I was of the notion that Pio 7950UB was better than Sony CDX 660US and that's where my knowledge comes to an end
...anyways will continue to follow this thread to learn more about ICEs
__________________
________________
2003 Kinetic GF170 Laser Sport Edition
2007 Bajaj Pulsar 180 DTSi
2007 Suzuki ALTO xFun
________________
sabret00the is online now   Reply With Quote
Old 29th August 2007, 11:02   #78 (permalink)
Sam Kapasi's Avatar
And that's the fun thing about a forum sabre. I learn too over here. Every single day.
__________________
Live the YetiLife®
Old 31st August 2007, 00:09   #79 (permalink)
nura's Avatar
My external antenna has got rusted & cannot be pulled out. Can I fit an internal one? What would be the advantages & disadvantages of an internal antenna? Where would it be fitted & would the wiring be visible? Thanks in advance.
__________________
Old 31st August 2007, 10:55   #80 (permalink)
DerAlte's Avatar
Blaupunkt has an internal antenna that mounts on the inside of the front windshield - adhesive mounting, no drilling. The wiring, if done correctly, should not be visible.
__________________
Never believe it cannot be done - it's only that you haven't found out how!!!
Old 31st August 2007, 11:53   #81 (permalink)
panky12345's Avatar
Infractions: 0/1 (4)
But not as effective as it should be!! Better to go in for external one IF you listen to radio. I hardly do, so internal one is OK for me.
__________________
SINGH IS KINNNNNNNG..
Old 31st August 2007, 12:11   #82 (permalink)
Try using the seat belt screw or the seat mounting screw cos both of these are going into the chassis
dont forget to remove the paint from the screw
simply_sunny001 is offline   Reply With Quote
Old 31st August 2007, 14:05   #83 (permalink)
nura's Avatar
Thanks DerAlte, panky12345 & simply_sunny001. How much does the Blau antenna cost? Is there an antenna which mounts on the internal rear view mirror?
__________________
Old 31st August 2007, 14:15   #84 (permalink)
Internal ones dont work well and this is my personal experience,All TATA cars come with an internal antenna pasted on the windshield near the rear view mirror.
problems faced are imperfect reception,pasting going kaput at times and that might be cos of bad quality in TATA products
but still try to find any external robust antenna(like the one in Ford ikon/skoda) and shd cost you around 500 bucks in local market.
Old 31st August 2007, 14:57   #85 (permalink)
nura's Avatar
Thanks simply_sunny001. The popular brand in Kolkata is ER, costing less than 200 for external & less than 300 for internal. Anyone know of better brands?
__________________
Old 2nd September 2007, 20:46   #86 (permalink)
nura's Avatar
Yesterday I got the front doors gas cut for the midbass speakers. I have posted a few pictures of my new ICE stuff here
Picasa Web Albums - nura - My Santro ICE...
__________________
Old 2nd September 2007, 21:02   #87 (permalink)
I have a 30 month old Indica. It came with an internal antenna. No problems till date, and the reception is superb( better than my sister's alto with an external antenna, which still perplexes me till date )
Why not install two antennas ( both internal ) and then solder the wires from both of them together and then add the jack. You should have awesome reception then. I am not sure whether this would work, but can't think of any reason it shouldn't
akg7091 is offline   Reply With Quote
Old 3rd September 2007, 10:13   #88 (permalink)
navin's Avatar
wont there be an impedance mismatch between the HU and the 2 parrlleled antennas? to do this one would need some way to switch between the 2 antennas (which ever one had better reception) or multiplex the signal. I have seen this principle used oon some HUs to minimise "picket-fencing".
__________________
Scixelsyd Etinu
Old 3rd September 2007, 12:06   #89 (permalink)
panky12345's Avatar
nura, some local brand is available here in delhi for internal antenna for Rs. 150/-
__________________
Old 5th September 2007, 14:10   #90 (permalink)
nura's Avatar
I have just added a few more pictures of my ICE here
__________________
Thread Tools
Some Queries on My Santro Xing MadhuG Technical Stuff 13 28th October 2008 14:37
Tuning your Ice: What are Your Settings? Magma Sound Off and Show Off 35 11th September 2008 00:41
I-10 ICE [equipment & installation] Pictures BHAGWAN Sound Off and Show Off 125 6th September 2008 22:08
Tuning queries for Pioneer 7950 and JBL75.4 vkhandelwal Ask the Gurus 21 17th September 2007 15:43
My latest ICE Installation - NHC AshOnTheRocks Sound Off and Show Off 21 20th March 2007 00:46
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
