Thread Tools
Old 18th December 2007, 15:28   #121 (permalink)
I currently have a Pioneer TS-A6991S 6x9" Coaxial speakers at the rear in my zip, planning a change to JBL GTO 937 6x9" Coaxial speakers.
A poineer HU
My query is whether the system has to be re-tuned to match the speakers or the same tune setup is enough???
junky is online now   Reply With Quote
Old 18th December 2007, 18:16   #122 (permalink)
DerAlte's Avatar
A poineer HU
Depending on your listening tastes, you might have to change the tone settings on the HU, if they are not set to flat.
If set to flat, first just see if you like the sound without changing settings.
__________________
Never believe it cannot be done - it's only that you haven't found out how!!!
Old 22nd December 2007, 22:43   #123 (permalink)
nura's Avatar
The Alpine 9887 HU was finally installed last Sunday & even without TA adjustments it has made a huge difference.
Somewhat surprisingly, the orange wire meant for illumination was missing from the supplied harness. Luckily, I had found a capable installer this time. He used the audio-interrupt-in wire instead to get the HU lights to dim, when the car lights were switched on. This guy also soldered the wires together instead of merely twisting & black-taping them. Needless to say, I had some heat-shrink tubing handy to go over the joints.
One thing I haven't been able to figure out is how to get the HU out of the dash, when the need arises. The supplied keys are too big for the holes in the HU. I guess I need to take the protection collar out first but have no clue how to do it. Or has Alpine messed up & supplied the wrong keys? Help will be sincerely appreciated.
__________________
Every man has his follies.
And often they are the most interesting things he has!
nura is offline   Reply With Quote
Old 25th December 2007, 20:29   #124 (permalink)
gunbir's Avatar
Infractions: 0/1 (4)
Supreme messed up again, they have done this before. Call their office and complain.
__________________
Often imitated, never duplicated!
Old 28th December 2007, 14:58   #125 (permalink)
nura's Avatar
I am trying to adjust the Alpine 9887 HU correctly but am confused about the following settings.
1. What should the crossover point & slope on the HU be? The LPF & HPF on my amp are set at 80 Hz & the 3 way component speakers also have their own passive crossovers. I have a sub only, no rear fill. Is there any advantage/ disadvantage in using HU, amp & passive crossovers together?
2. Should the subwoofer phase be set at 0 degrees or at 180 degrees? What is the difference? Is it the same as reversing the polarity of the sub?
3. Should the subwoofer channel be set at stereo or mono? Why? I have a 2 Ohm DVC sub with the voice coils wired in series to get 4 Ohms.
My sincerest thanks in advance.
__________________
Old 28th December 2007, 15:11   #126 (permalink)
Bass&Trouble's Avatar
Passive crossover is doing a different job from that of the head unit and amplifier's crossover in your case. So passive crossover is not something you have to worry about.
Ideally, for a 3-way component set, you should set the HPF at 50Hz or so so that you can get the extra bass from the midbasses. Do this either from the head unit or the amp.
Same as reversing polarity, yes. Choose whatever provides better integration of sub with the speakers.
Mono.
__________________
Operator! Give me the number for 911!
Old 28th December 2007, 17:05   #127 (permalink)
nura's Avatar
Thanks a ton.
A few clarifications
1. Are you suggesting both HPF & LPF at 50 Hz or HPF 50 Hz & LPF remaining same i.e. 80 Hz?
2. What would you recommend for the slope?
__________________
Old 28th December 2007, 18:29   #128 (permalink)
HPF & LPF both at 50Hz. Dont have them overlapping. It could cause either a peak or a dip in the band.
Umm, 6dB at 50 Hz could be a bit too much for the speakers. 12dB should be fine. For the sub, try with 6, 12, 18. If you can find one to sound decidedly better, stay with it.
__________________
Old 28th December 2007, 19:42   #129 (permalink)
navin's Avatar
Originally Posted by Bass&Trouble View Post
Umm, 6dB at 50 Hz could be a bit too much for the speakers. 12dB should be fine. For the sub, try with 6, 12, 18..
B&T/Gunbir/Blueraven/Gurus, I have noticed that 6db HP slopes and 24db LP slopes dont really gell well in most applications. have you noticed the same?
__________________
Scixelsyd Etinu
Old 28th December 2007, 19:54   #130 (permalink)
Yeah, me too. 20-20-20
__________________
Old 29th December 2007, 10:41   #131 (permalink)
nura's Avatar
Clear. Thanks once again. Will tweak & post results shortly.
__________________
Old 29th December 2007, 18:00   #132 (permalink)
gunbir's Avatar
Yes, same here as well. 12dB works best in most cases.
__________________
Old 15th January 2008, 13:40   #133 (permalink)
nura's Avatar
I would like to use the time correction feature on my Alpine 9887 HU, for the front right seat listening position. I understand that I need to measure the following distances.
a) Front right head-rest to sub
b) Front right head-rest to front left speaker
c) Front right head-rest to front right speaker
Now my sub is placed behind the rear seat of the Santro & it faces the hatch door. So is a) the distance from sub-driver to front right head-rest or is it sub-driver to hatch door to front right head-rest?
My front speakers are 3-way components with the tweeters placed on top of the dash, the mid-ranges in the lower part of the dash & the mid-basses in the lower part of the front doors. So I have 3 distances for b) & 3 for c)! How do I convert them to get a single figure for b) & a single figure for c)? Do I calculate averages?
Thanks in advance.
__________________
Old 15th January 2008, 15:46   #134 (permalink)
Firstly dont measure from head rest. It should be from the center of the head, so insert the measuring tape to there through your nose. Well, actually, tilt the back-rest ahead so that the point on the backrest from where you are measuring is the apparent center of your head.
You need to measure distances for the rear speakers also (or you don't have rear fill?)
3-way dilemma:
Option 1: Ideally, all three drivers per side should be equidistant. Easier to achieve with 2-way, sometimes impossible with 3-way. This will produce the best results.
Option 2: Mimic the effect of all 3 drivers being equidistant by attenuating closer drivers through the passive crossover of the speakers. Does your 3-way have this option?
Option 3: Align just bass. This can be done by feeding the distance of the midbass alone in the TA menu. Downside: Imaging not upto the mark
Option 4: Align using tweeter's co-ordinates only. This would produce a good image in 2-ways, especially those with tweeters playing low. In your case, not much help since tweets of 3-way systems are usually cut off quite high (not sure about the set in concern, please check this) Downside: bass alignment is not correct.
Option 5: Take the average. This will neither be perfect for bass, nor for frontstage. A general mashup sounding perhaps a bit better than without any TA whatsoever.
__________________
Old 15th January 2008, 18:20   #135 (permalink)
nura's Avatar
Thanks Bass&Trouble. I guess I could try option 2 first, since the XO has +2dB/0dB/-2dB options for the tweeter as well as the midrange.
__________________
Thread Tools
Some Queries on My Santro Xing MadhuG Technical Stuff 13 28th October 2008 14:37
Tuning your Ice: What are Your Settings? Magma Sound Off and Show Off 35 11th September 2008 00:41
I-10 ICE [equipment & installation] Pictures BHAGWAN Sound Off and Show Off 125 6th September 2008 22:08
Tuning queries for Pioneer 7950 and JBL75.4 vkhandelwal Ask the Gurus 21 17th September 2007 15:43
My latest ICE Installation - NHC AshOnTheRocks Sound Off and Show Off 21 20th March 2007 00:46
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
