Thread Tools
Old 20th August 2007, 12:56   #1 (permalink)
arup10's Avatar
Default Sound Setup Tuning for my Aveo
I recently bought an Aveo 1.4
My take on the Aveo: http://www.team-bhp.com/forum/long-t...-review-2.html (An Aveo 1.4 Review)
I got the following components installed from Driven's in East Of Kailash.
HU: Pio 5950
Rear Speakers: JBL GTO937
Front Speakers: 4" company fitted (will replace with components later)
Amp: JBL 60.4
Sub: Currently testing Pio 307D2, earlier tested Pio 306C for a week
Custom made MFD box
Power Cables: Tsunami
The guys took a lot of time to fit the system and I feel they did a very good job with the installation.
Although I am reasonably happy with the current sound, I would like to know whats settings(amp and HU) would be ideal for this setup.
I listen to all kinds of music, ranging from Jazz, Instruments, Hop Hop/RnB and the usual hindi/punjabi stuff.
The audio accessories guy suggested the 306 over the 307 to me as he was quite confident it was much better. So I tried out the 306 for a week, played quite a few songs of different genres and with the current Amp setting (which I have no clue about) and some adjustments in the HU, the sound output though powerful, felt a little boomy to me, in other words the bass I felt wasn't tight enough at times.
Yesterday, got the 307D2 fitted in the same MFD box. With the same settings, my observation is that the bass is much tighter now, but somehow the power of the 306C is missing.
So if I compare the two, I would say the 307 sounds better to me, but the lack of power (although its 200 watts pmpo more than 306) is bothering me a little.
Would really appreciate if you guys can suggest the ideal settings so that I can get my setup tuned better. Also suggest me which one is a better sub-woofer of the two with the right tuning.
Thanks.
Arup
arup10 is offline   Reply With Quote
Old 20th August 2007, 13:48   #2 (permalink)
clipto333's Avatar
Originally Posted by arup10 View Post
HU: Pio 5950
Amp: JBL 60.4
Custom made MFD box
Thanks.
Arup
hi arup,
what amp are you usind to drive the sub? your sub is a dual 2 ohm sub right?
i had a 306c in my earlier install and it is powerful. i havent heard 307 so cant comment on its performance.
the bass from the 307 could be missing compared to the 306 because of the enclosure. im not sure about this but i think the enclosure dimensions of both the subs differ and that could be the reason.
what type of enclosure do you have?(ported, sealed etc) and how is your sub wired?
the best settings for the HU is to keep the loud off, eq flat.
cheers
clip
clipto333 is offline   Reply With Quote
Old 20th August 2007, 13:55   #3 (permalink)
Sam Kapasi's Avatar
Can you use the same sized enclosure for the 306 and the 307??
__________________
Live the YetiLife®
Old 20th August 2007, 15:43   #4 (permalink)
navin's Avatar
Depends of the T/s specs dude.
__________________
Scixelsyd Etinu
Old 20th August 2007, 16:05   #5 (permalink)
arup10's Avatar
Just checked the Pioneer site,
It says 'Recommended Enclosure Use: 0.85 ~ 1.75 Cubic Feet' for both, the 306C and 307D2 subs.
Old 20th August 2007, 16:14   #6 (permalink)
Eddy's Avatar
How much did the HU and rear speakers cost ? Is the HU compatible with a steering remote ?
__________________
Car is no longer a luxury; parking space is.
Swift VDI(ABS) Sep 07 - 31K Kms
Ford Ikon Flair Sep 04 - 54K Kms
Eddy is online now   Reply With Quote
Old 20th August 2007, 17:20   #7 (permalink)
panky12345's Avatar
Infractions: 0/1 (4)
what is 307 D2; 2 2 ohm voice coils or 2 4 ohm voice coils?
I think you were using 306 SVC off 2 channels bridged in 4 ohms, now only 1 coil is being used (if 4 ohms) or both the coils (if 2 ohms) to present a 4 ohm load. either ways, the bass would be more or less the same.
and yes, enclosures can be same.
__________________
SINGH IS KINNNNNNNG..
Old 20th August 2007, 18:28   #8 (permalink)
low_bass_makker's Avatar
D2 means 2 VC of 2 ohms each. and D4 means 2 VC of 4 ohms each.
Old 20th August 2007, 19:32   #9 (permalink)
panky12345's Avatar
Thanks LBM....I was suspecting the same.
__________________
Old 24th August 2007, 12:33   #10 (permalink)
arup10's Avatar
Hi guys, I am still waiting for an answer.
I think the box (enclosure) issue has been resolved as both the subs (306 and 307) can be fitted in box of the same dimensions.
Would really appreciate if you guys could suggest the ideal settings for the Amp and HU with my current setup. Also your suggestions on whether to keep the Pio 307D2 or go back to the 306.
I am posting the specs of the components below:
JBL GTO937 Speakers Specifications
Power Handling, RMS: 100 Watts
Power Handling, Peak: 300 Watts
Frequency Response: (±3dB) 50Hz-21kHz
Sensitivity : 94dB
Mounting Depth: 2-15/16" (75mm)
Cut-Out Diameter: 8-11/16" x 5-7/8" (151mm x 221mm)
Impedance: 2 Ohms
Pioneer TS-W307D2 Sub Specifications
Watts MAX. Music Power: 1200 Watts
Watts Nominal Power Handling: 400 Watts
Frequency Response: 18 ~ 500Hz
Sensitivity: 89dB
Ohm Rating: (1 or 4 ohm)
Recommended Enclosure: 0.85 ~ 1.75 Cubic Feet
Dimensions: 327 mm x 172 mm
Mounting Depth: 153 mm
JBL 60.4 Amp Specifications
Power Output : 60 watts RMS x 4 channel at 4 ohms and = 1% THD + N
S/N Ratio : 86dBA (reference 1 watts into 4 ohms)
Dynamic Power : 145 watts at 2 ohms
Effective Damping Factor : 6.39 at 4 ohms
Frequency Response : 10Hz - 27kHz (-3dB)
Maximum Input Signal : 6.0V
Maximum Sensitivity : 100mV
Dimensions : 2.2" x 13" x 10.3"
I can post some pictures of my ICE setup if needed.
Thanks.
Arup
Old 3rd September 2007, 18:17   #11 (permalink)
arup10's Avatar
I was very lucky that Gunbir Ji was visiting Driven's yesterday.
He graciously accepted to listen to my sound setup and made the necessary changes.
And indeed the tweaks done by him have made the sound much better and cleaner now.
Thanks once again.
Thread Tools
Woofer from a computer sound system possible in a car audio setup? Deeps Ask the Gurus 2 5th August 2008 23:51
Sound Quality not good on new ICE setup. Help! maverickzCar Ask the Gurus 24 28th December 2007 15:15
Surround Sound Setup in SX4 deusex Ask the Gurus 3 3rd September 2007 20:31
Need help on audio setup for my Aveo namit Ask the Gurus 24 8th May 2006 16:54
The Dawn of Turbo Diesel Tuning in INDIA - Pete's Tuning Box turboindia Modifications & Accessories 108 17th April 2006 13:33
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
