| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #1 (permalink) |
| BHPian | Hey Guys, I recently upgraded my ICE setup...now, when i play the radio (FM, AM) and blow the horn, i get a irritating disturbance from my speakers...this does not happen when the CD, DVD, AUX etc is playing...what gives? My antenna is the glass embedded type (Elantra). HELP!!
__________________ I'm not into exotica & badges, just horsepower & handling! |
| | #5 (permalink) |
| Senior - BHPian Join Date: Mar 2006 Location: Delhi. Travelling as usual! Mumbai was great.
Infractions: 0/1 (4) | Check the grounding points and the horn relays. That'll sort it out in most cases.
__________________ A very big THANK YOU, Bombay! Will miss you guys! :( |
| | #7 (permalink) |
| Senior - BHPian | Similar threads... http://www.team-bhp.com/forum/ask-gu...-speakers.html (Horn playing through speakers) http://www.team-bhp.com/forum/ask-gu...orn-blown.html (hissing noise from speakers when horn is blown)
__________________ Hold fast to dreams, for if dreams dry, life is a broken-winged bird that cannot fly. |
| | #9 (permalink) |
| BHPian | Guys, I checked the horn relays & ground points...all is ok. Cannot seem to find the exact cause...the installer put a relay on the horn side & the interference reduced quite a bit...but not fully... please suggest something...??
| | #11 (permalink) |
| Team-BHP Support ![]() Join Date: Mar 2007 Location: Bangalore
| Perhaps you could try a small-value capacitor across the horn side of the relay? Also, see if a different pair of horns give the same problem?
__________________ Never believe it cannot be done - it's only that you haven't found out how!!! |
| | #13 (permalink) |
| BHPian | Tried changing the horn...but to no avail...will try the capacitor method 2moro (monday 26th) & let u guys know...thanks for your support... 1 Important Query: If i connect the ground wire from the amps etc., directly to the battery negative terminal...will that be good or bad?
__________________ I'm not into exotica & badges, just horsepower & handling! Last edited by 1self : 26th August 2007 at 20:32. |
| Thread Tools | |
Similar Threads | ||||
| Mind Blowing Info. | physicspsyche | Introduce yourself | 2 | 7th October 2008 19:17 |
| AC fuse blowing after some time | tsk1979 | Technical Stuff | 22 | 20th July 2008 10:09 |
| Cellphone interference in car speakers | ozzyrules | Ask the Gurus | 7 | 1st May 2008 00:29 |
| Colour-Shifting Interference Paint finish | Ram | Technical Stuff | 10 | 28th January 2006 00:47 |
| Mind blowing F1 stat. | Hatari | Motor-Sports!! | 13 | 2nd June 2004 23:37 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
What names yaar!!
