| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: May 2007 Location: Mumbai
| Dear All, Please suggest if the Pioneer 6950 have sufficient power output to run Infinity Component both at the front and at the back. I'm planning to install the same in Accent and have some budget constrains at the maoment. I'll leave the option of adding the sub and the amp latter. I just don't want to but some cheap stuff amp and woffer. Also this will keep my option open for the better Amp and a better Sub to be added latter. But from what I've read that the output from the head unit won't be sufficient to power both the components at the front and at the back. I'll be mostly going for Infinity Ref5101cs both at front and at back. Pls help. Thanks Saurabh |
| | #2 (permalink) |
| Senior - BHPian Join Date: Mar 2006 Location: Bombay
| Its not the best idea to have good components running on the head unit directly, but like you are saying, when you get the amp later, you should be fine.
__________________ Operator! Give me the number for 911! |
| | #4 (permalink) |
| BHPian | 6950 is a good HU (iPod ready and aux-in with 3 pre-outs) and it has 4V pre-out which provides better quality music output when connected with an Amp. I would suggest a round co-axial speaker instead of Compos in the rear. You can later buy a 4-channel amp and connect the front components and bridge the 2-channels to a sub and be done with it... |
| | #6 (permalink) |
| Newbie Join Date: Aug 2007 Location: Bangalore
| I am new !!! but I have read this over & over again in this forum but I couldn't come across an explaination.... So for god's sake can anyone pls explain to me why co-axs in the rear, is it becoz they cost less (what if money was not the ??) or is it becoz no1 going be sitting in the back seat (what if there was..). If components are better spks then why not have all same spks in the car for a better overall SQ ? Can the gurus pls throw some light on this ....?
__________________ Pain is temporary. Quitting lasts forever. |
| | #7 (permalink) |
| BHPian Join Date: Feb 2007 Location: Kolkata
| Some suggest components in front, a sub at the back & no rear fill. Others suggest components in front, a sub at the back & coaxials for rear fill. Still others suggest components in front, a sub at the back & mid-bass or mid-range speakers (but no tweeters) for rear fill. They argue that if tweeters are installed in the rear, they tend to drag the sound-stage to the back. Maybe the Gurus would like to elucidate. Thanks.
__________________ The most exciting phrase in science is not "Eureka" (I found it) but probably "That's funny...."! |
| | #8 (permalink) | |
| Team-BHP Moderator ![]() Join Date: Mar 2007 Location: Bangalore
| Quote:
Last week I was surprised to find components (6.5"; proper OEM tweeter slot - not a mod) for the rear passengers in a Toyota Prius taxi (Stockholm) and co-axials for the driver. Some of the Volvo taxis also had that. Unfortunately the drivers (from North Africa, Middle East & Iran) were not music lovers - they preferred to go yakkitty-yak on their cell-phones.
__________________ Never believe it cannot be done - it's only that you haven't found out how!!! | |
| | #9 (permalink) | |
| Senior - BHPian | Quote:
The point is, co-axials cost less and most of us out here drive the car ourselves. The faders are used extensively to make sure the sound front stage is emphasized and the rear is kept at the bare minimum. I remember this from another thread where Navin mentioned that he fades it all to the front and moves towards the rear until he hears just the audible amount. If you have excess of money, invest in other elements rather than spending on rear-fill. The overall SQ does not come into picture when you fade so much to the front. If people are seated at the back, then the fader would be used to make sure they get enough sound. If the above is the case, don't you think it is wise to spend those few thousands on better wiring/amplifiers/subs or the components itself? Think about it. However, In cars (Like Superb, Camry) where the passengers are mostly seated at the back, gurus advise components in the rear. When the car seats 4-5 and all of them require great SQ, gurus have advised components for both front and rear. (You can also check out some Show-offs with the same, many of Gunbir's threads) 'If money is not the criterion' is a very very hypothetical situation in the ICE section. There is probably no end to quality ICE that you can buy with excess of money. Hope this answers your question.
__________________ ... Everything should be made as simple as possible, but not simpler | |
| | #10 (permalink) | |
| Quote:
2. Rear channels in an average ICE HU are a simple derivative of the main signal, and Fading is relative power output to front or rear 3. Imaging (your ability to locate the individual sources of the sound by the relative time delays: virtual 3D) is more pronounced at higher frequencies If the reproduction is as good at the rear, imaging will be proportionately better in the rear, BUT since the rear is audible in the front, the "better rear image" will interfere more with the front image - effectively giving a feeling that the image is "more to the back". But, hey, there are no rules - everything goes by individual perception. Some even want all the speakers - midbass, tweeters, subs, ovals - in the rear; happy with the reflected image!
| | #11 (permalink) |
| After all the brain storning I think this is what my final setup should be. HU : Pio 6950 Front : Infinity Ref5010CS Component Rear: Still confuesd between Infinity ref5010cs component or JBL GTO937. Amp: JBL GTO75.4 ( not sure if I'll sufficient money to be put in now or the same can be added later after say 2-3 months also depends on Sam sir as what final discount can be )Sub: JBL CS1204 T ( Again this depeneds on when I'm adding the Amp And Sam Sir ). Once the Amp is added Amp will power the front and the woofer. Guys pls let me know how this setup will sound. The car in question is Accent and is driven always by me. Senior members and Gurus pls advice. I'll like to thank Sam Sir and Firoz for the advice and all the valuable time they have given. Saurabh |
| | #12 (permalink) |
| Distinguished - BHPian ![]() | You're a sweet well behaved gentleman. Very polite. I think you should put coaxial speakers in the rear. JBL or infinity up to you, but I think putting components in the rear will be wasteful.
__________________ Live the YetiLife® MA-DONNA! MA-DONNA! MA-DONNA! |
| | #13 (permalink) | |
| Quote:
I'll surely take your advice. So guys Finally it will be JBL GTO937 With Amp and Woofer at this stage or not will finally be decided on the total cost I'm going through. (Sam Sir's help ) | |
| | #14 (permalink) |
| Dear Rocksterraghu & Deralte, Thank you very much for helping in decoding that mystery for me. As I was really very confused after going thru pages and pages of posts..... Finally I have decided that I will go for Components at the back as well becoz from what you guys say, co-axs in the rear are just for cost-cutting as there is usually no1 sitting at the back !!! Moreover the cost difference, of the quote I got from my supplier, is only Rs. 1000. So my final setup would look like this.... HU - Pio 6950 6.5K Spks - JBL 607C 4.2K * 2 Amp - JBL 60.4 (5K) for Spks & Sony 444 for Sub Sub - 10" Pio sub any comments or suggestions ?
| Thread Tools | |
Similar Threads | ||||
| Amplifier output query | panky12345 | Ask the Gurus | 17 | 8th December 2007 22:40 |
| Difference between Poineer 6850 & 6950 HU | saurabhkum | Product Discussions | 11 | 11th August 2007 04:35 |
| Need Higher Output Alternator And Electrical Help | Tool | Modifications & Accessories | 5 | 1st June 2006 18:06 |
| Help ... Need High Output Alternator TOO MUCH LOAD | low_bass_makker | Ask the Gurus | 44 | 14th March 2006 09:14 |
| Engine Output and Torque power | Surprise | Technical Stuff | 20 | 25th May 2005 20:52 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445
