Thread Tools
Old 29th August 2007, 16:24   #1 (permalink)
bhavit46's Avatar
Default Pioneer DEH-P6850 Trouble
Hi! I have installed Pioneer DEH-P6850 headunit in my Palio S10 around a year back. It looked awesome with its blue display and motorised panel and was working fine.
But last night it started working abnormally. Even when i touched it, it switched off by itself and restarted by itself and that happened a number of times. The HU worked perfectly if you use the remote control. If i have to change from tuner to compact disc, then the HU goes blank (No lights on the display) and suddenly after 5 seconds it restarts again.
What according to you should be the problem? Should i get the HU cleaned with an electronic cleaner? Kindly help me....
__________________
May the force be with you....
bhavit46 is offline   Reply With Quote
Old 29th August 2007, 18:18   #2 (permalink)
panky12345's Avatar
Infractions: 0/1 (4)
"reset" it and you'll be fine.
__________________
SINGH IS KINNNNNNNG..
Old 29th August 2007, 20:47   #3 (permalink)
Just remove tha detachable pannel, check if the connectors at the back of pannel and in the front of the unit and then fit the pannel back. This happens mainly due to detachable pannel not fitted properly.
Hope this solves your problem .
Saurabh
saurabhkum is offline   Reply With Quote
Old 29th August 2007, 23:29   #4 (permalink)
Jaggu's Avatar
saurabh has a point, check contacts as well as see if the points are clean, also if any one of the contacts are broken or bent
__________________
The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin
Thread Tools
Double Din DVD HU Thread: JVC KW-AVX800 \ Alpine IVA-W200 \ Pioneer AVH-P6850 vittalnrv Product Discussions 71 12th September 2008 17:16
Pioneer DEH 5850 djjebs Ask the Gurus 3 10th June 2008 08:53
PIONEER AVH-P4000DVD or Pioneer DEH-P7900BT abhisheksircar Ask the Gurus 23 18th May 2008 16:18
Pioneer DEH P5850 for Sale deepak_ms Shifting gears 4 14th December 2007 14:07
Pioneer DEH-P4650MP Dippy Ask the Gurus 14 11th November 2004 11:45
Powered by vBulletin
