Thread Tools
Old 13th September 2007, 23:51   #31 (permalink)
amit_sound's Avatar
Guys guys...chill remember wat this thread was about??
We going a little offtrack..
__________________
BASS ADDICT
Digital Designs 3512 x 2
Digital Designs M3 mono block amp
Next is What?.....surely not a mobile phone :P
amit_sound is offline   Reply With Quote
Old 14th September 2007, 10:22   #32 (permalink)
amit_sound's Avatar
Sorry if the this question has been asked eaarlier....
I am getting a little confused on the impedence part, i.e 2 ohm and 4 ohm
Did a little bit of search on the net, from what i understand is that a 2 ohm amp/woofer will allow more current to pass through it than a 4ohm
I lay-man terms kindly explain the following.
Consider the two systems at different impedences
1) A 400 watts RMS DVC woofer run with a 400 Watt RMS amp at 4 OHMS
2) A 750 watts RMS DVC woofer run with a 750 Watt RMS amp at 2OHMS.
(Technical perspective) Now considering the above system, from my basic understading, i say the 2 ohm consumer more power and has more power output.
((SPL) BASS HEAD prespective)Which is louder 2 ohm or 4ohms?
__________________
BASS ADDICT
Old 14th September 2007, 11:05   #33 (permalink)
Sam Kapasi's Avatar
OK amit, let me help you.
Imagine a tap with a pipe connected to it. The tap pushes water out through the pipe. As you can imagine, without the pipe the water will flow very well, with no resistance.
But when you connect the pipe, the water flow is a little restricted.
If you have a thick large pipe, the restriction is less. If the pipe is thin, the restriction is more. However, you can control the water better, with a thin pipe.
In the case of copper wound coils, the restriction is called impedance. How much impedance the coil offers the amplifier is more or less decided at the manufacturing stage.
An amplifier that is capable of putting out 100W at 4 ohms will generally offer 150 to 170% more when connected to 2 ohms. (I know what you're thinking, it should be twice as much and sometimes it is too, depending on the quality of the amplifier).
BUT an amplifier running a lower impedance speaker is always under greater stress.
Neither 2 ohms nor 4 ohms translates into SPL directly. However, following the above explanation, a 2ohm woofer will play much louder on the same amplifier, with the same settings. The amplifier would need more current and will get hotter as it will run with a load twice as much.
__________________
Live the YetiLife®
Old 14th September 2007, 12:02   #34 (permalink)
navin's Avatar
additions:
1. some woofers use aluminum voice coils. neither is better than the other it all depends about the total transducer design.
2. most amplifiers are voltage amplifiers. That is they amplifiy voltage for say a 0.5V signal to say a 20V signal. since they are voltage amplifiers as resistance halves current will double. so say the amp is putting out 20V at 4ohms = 5 Amps. P = 20 x 5 = 100W. Now the same amp is putting out 20V at 2ohms = 10 amps P = 20 x 10 = 200W. as long as the amplfier's electronics (transistors, tubes, etc..) can handle the larger current this will happen.
3. The NOMINAL sensitivity of speakers is often quoted at 2.83V. THis voltage was derived becuase most speakers were 8 ohms and 1W/8hms = 2.83V (P = V^2 / R or PxR = V^2). Now a 4 ohms speaker when fed 2.83 volts is actually geting 2W ((2.83*2.83)/4). This means that it's nominal sensitivity will be 3db higher unless the manufacturer specifically states that the ratings were at 1W or 2V (not 2.83V).
__________________
Scixelsyd Etinu
Old 14th September 2007, 12:17   #35 (permalink)
panky12345's Avatar
Infractions: 0/1 (4)
LOL! Classic Navin explanation! I was looking for it for quite sometime now.
Amit, See layman terms mein:
1. 2 Ohm will play louder than 4 ohms.
2. Woofer generally would be either single coil (SVC) or double coil (DVC), allowing you to extract 4 ohms or 2 ohms from your amp (depending upon amp's capablities).
3. System # 2 in your post would be much louder than in System # 1
__________________
SINGH IS KINNNNNNNG..
Old 14th September 2007, 12:53   #36 (permalink)
amit_sound's Avatar
Hey panky!!!!!!! u the man...sahi simple layman terms
SAM, good to have to back...nice BMC type explanation. Really was easy to understand.
Navin thanks for all that technical information....phew some of it was a bouncer.
__________________
BASS ADDICT
Old 14th September 2007, 12:54   #37 (permalink)
amit_sound's Avatar
And my cousine in US has got the ZX2500.1 and S12L5 - 2 ohms bass system
__________________
BASS ADDICT
Old 14th September 2007, 13:03   #38 (permalink)
panky12345's Avatar
congrats amit, please post exact details with prices please, including the buying source.
waise i somehow feel that your cousin would gift this to you in near future. ;-)
__________________
Old 14th September 2007, 13:33   #39 (permalink)
blueraven316's Avatar
Congrats! he has to wire the subs in series , parallel to get a final 2 Ohm load.
And ask him to go easy on the gain, Kicker amps will always churn out more than rated, so he will be getting around 2700 to 3000 RMS actual out of that amp.
blueraven316 is offline   Reply With Quote
Old 14th September 2007, 14:05   #40 (permalink)
amit_sound's Avatar
hmm...u trying to read the furture OR u trying to solve the trick of this thread.
__________________
BASS ADDICT
Old 14th September 2007, 14:06   #41 (permalink)
amit_sound's Avatar
thanks for the info blueraven
Quite helpful indeed
__________________
BASS ADDICT
Old 14th September 2007, 14:31   #42 (permalink)
panky12345's Avatar
Both....and I'm pretty sure I'm RIGHT!
__________________
Old 16th September 2007, 03:01   #43 (permalink)
amit_sound's Avatar
Hey panky....keep guessing.
Aacha btw cousine said thanks to team-bhp community for helping him with everything. Says he too will become a member.
Now the keeda part in me.
I am,
Planning to settle in for a new zx1500.1 mono amp. (Kicker)
It chruns out 1500x1 rms @ 2 ohms
and 750 x 1 rms @ 4 ohms.
I am throughly confused between the 15" L5 and L7 solo baric woofers.
Note: I am taking about L5 and L7 which run at 2ohms. I am not intrested for the 4 ohm woofer
Official kicker website sugests. (If u need to confirm kicker recommendation....kicker.com -> Support -> Tecnhical Support -> Sub-to-Amp Guide) And a round table sort of opens up
1) Two 15" L7 1000 rms at 2 ohms can be played with a single zx1500.1 amp.
2) Two 15" L5 750 rms at 2 ohms can be played with a single zx1500.1 amp
Now the L7 is rated at 1000 RMS @ 2 ohms and the L5 is rated at 750 rms at 2 ohms.
So u see confused!!
The zx1500.1 seems a little undepowered fot two L7....but as blueraven suggested that kicker amp outputs a little more than wat they mention on paper. So practicaly making assumptions from blueravens quote, 1500.1 can output aarox 1700 + (appx) at 2 ohms.
Although 1500.1 looks a perfect match for two L5...no doubt about this. But still heart wants more ....So mind say L5 but heart says L7.
Opnions??
Which Car is This for ?
The two systems are miles apart, Kicker is a pure SPL belter and a pair of L715s will will yank the wax out of his ears (if that is what he wants, then yes its fine) However, that amp will overpower the subs running 2500 RMS @ 2Ohms.
Yes overpowered it looks....but 1500.1 looks a little under powered.
Also,
Something about the boxes....as far as my knowledge is concerned a sealed box is supposed to give tight bass. Where as a ported is not as tight as a sealed but certainely much louder than the sealed enclosure.
Also, it is suggested that if u have enough amplification then a sealed box iis a good match. If amplification is little less then ported should be choice.
So i think that zx1500.1 with 2 L7 in a ported box should perform awesome job..wat say?
BTW i have never heard L5 OR L7 play before. Currently wat i have is two 15" JBL GT4-15 subs and a single GTO601.1 mono amp. I am preety satisfied with the current setup . But still, how much of a difference can i expect by switching from current JBL to two L7s/L5s, hooked with a zx1500.1 in a ported box?
So finally....can i settle in for a 15" L7 with the 1500.1 inside a ported box? (yes/no)
__________________
BASS ADDICT
Old 16th September 2007, 04:21   #44 (permalink)
A sealed box can sound tight as long as the volume is kept on the lower side, on a L7, anything above 1.3 CuFt will boom, so if he is looking at tight bass then 1CuFt is more like it.
Compared to the GT4 15" subs in your car it can sound 3 to 4 times louder (LITERLALLY!)
If you want a ZX1500.1 then you have to pair it with a single 15"L7 Dual 2Ohm sub and connect it in series! safer and will beat the cra@ out of the car.
Old 16th September 2007, 10:50   #45 (permalink)
amit_sound's Avatar
(LITERLALLY!)
Sorry blueraven could not understand this.....U saying to use a zx1500.1 with a single 15" L7 2ohms connected in parallel?
I am looking at two subs....
Also someone please answer my post #43 in detail....too a lot of time out on a SATURDAAY night and wrote it..
__________________
BASS ADDICT
Thread Tools
Kicker and SQ? determinus Product Discussions 6 2nd July 2008 09:24
The Kicker Swift blueraven316 Sound Off and Show Off 7 28th November 2006 13:26
kicker santro cartouch_56 Sound Off and Show Off 20 10th March 2006 13:56
how is kicker rear speaker amit_sound Product Discussions 9 20th February 2006 13:37
Any idea about KICKER car audio? karthik247 Ask the Gurus 13 14th March 2005 10:46
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
