Thread Tools
Old 18th January 2008, 16:45   #16 (permalink)
viper's Avatar
Hi Guys,
Just got a set of Focal Polyglass series 165 V2 component speakers. Wanted your suggestions on the following ideas.
1> Replace existing Hertz from front doors with the Focals.
2> Replace Hertz coaxials with the front components on rear parcel tray.
3> Change 12" Hertz woofer fitted on shelf with another free air woofer(suggestions for make & model needed). I was told the existing woofer is more suitable with a sealed enclosure.
4> Add another amp. I want more power for the fronts and woofer what amp would you guys recommend(not too expensive)
Also am very keen on installing the Pioneer In-Dash DVD with the VDP1 so I might be looking at selling of the Alpine 9887 HU. Reasons for doing so
a> can play DVD Audio
b> All relevant vehicle info on display(most imp reason)
c> Can attach my a/d/s/ iDat-M D/A convertor to the DVD unit.
What do you guys think of the above idea.Plan to do all of this in the coming week itself.
Viper
viper is offline   Reply With Quote
Old 19th January 2008, 10:03   #17 (permalink)
navin's Avatar
before you upgrade your amps can you tell us what amps do you have currently? I would suggest using your current amp maybe in bridged mode for the front and add another amp for the rear components and sub.
If you are looking at free air why not the 15" IDQ. I think Gunbir has used this woofer in a free air install (behind the rear seat back rest).
__________________
Scixelsyd Etinu
Old 19th January 2008, 18:39   #18 (permalink)
panky12345's Avatar
Infractions: 0/1 (4)
Yup, its in flying bong's cedia.
__________________
SINGH IS KINNNNNNNG..
Old 5th September 2008, 09:13   #19 (permalink)
viper's Avatar
Default Update- ICE upgraded
Hi Guys,
Finally took the plunge and upgraded the speakers and woofer in my car. The new spec list is as follows.
Front comps: Illusion Audio Electra Series Comps EL 5.1
Rear 6x9: Ground Zero GZTF 69T
Subwoofer: Ground Zero GZTW 12MK2
They are a major improvement over my earlier setup. The sound is much more crisp and the bass tight. To be fair it could also be due to the fact that my earlier setup was carried forward from the Getz and maybe was not suited for the Honda City.
I have retained the earlier Audison amp. Some additional Noise Kill damping sheets were installed as well.
Installation carried out by Ajay himself and finally got the HU tuned as well. All in all a job well done. Will take some pics later of the install as was not present when it was carried out.
Viper
Old 5th September 2008, 19:35   #20 (permalink)
Magma's Avatar
Smile
Hi Guys,
Viper
ummm..
sir this is an upgrade or downgrade?
at least financially this must have cost you way less than the hertz setup!
glad to know you like the base model illusions over the mid range hertz.
i have the same setup in my car as well
installation and tuning done by Ajay himself..
arre ajaybhai "aur mere liye?"
__________________
An expert is someone who takes a subject you understand and makes it sound confusing.
Magma is offline   Reply With Quote
Old 5th September 2008, 19:39   #21 (permalink)
viper's Avatar
Lol,
I dont judge products by the price. As far as I am concerned they sound better than what I had. In any case I did not have a big budget as all of that was eaten up by the engine mods.
Viper
Old 5th September 2008, 20:00   #22 (permalink)
Jay
Jay's Avatar
So this is your 3rd upgrade in a year is it Jiggy ? Some pics of the install...
__________________
ZONDA !!!
Jay is offline   Reply With Quote
Thread Tools
ICE upgrade for OHC VTEC. Gurus please help. vishnuvijay Ask the Gurus 45 29th March 2008 01:54
Help .. For tyre upgrade for OHC VTEC .. devilvtec Tyre & Alloy wheel Section 4 10th August 2007 00:31
Suggestion + Upgrade my system smreddy Ask the Gurus 16 10th July 2006 15:30
NHC-Vtec or OHC Vtec..which is a better buy? sunith Sedans 4 2nd May 2006 22:25
Wanted: OHC VTEC or OHC 1.5 adit1329 Shifting gears 4 16th March 2006 18:39
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
