Thread Tools
Old 13th September 2007, 00:03   #1 (permalink)
viper's Avatar
Default Suggestion for Upgrade in OHC Vtec
Hi Guys,
As usual I get bored of stuff pretty soon and keep looking at upgrading. Listing below existing setup :
Existing:
Head Unit - Alpine CDA-9887 installed today.
Front Speakers - Hertz ESk 165.2(6.5" Components)
Rear Speakers - Hertz ECX 165.2 (2 Way Co axials)
Subwoofer - Hertz ES 300(12") mounted on Rear Tray
Amplifier - Audison SRx5 (5 channel 60x4WRMS + 1x180WRMS)
RCA Cables - Audison - BT6600
Speaker Cable - Audison FL214BL
Amplifier Power Kit - Audison FPK 300
Weurth Spray on damping extensively used all over
Am looking at a bit more punch in the bass at low volumes and better front stage and a more powerful system overall.
Dont mind adding another amp, changing speakers & subwoofer either from same brand or another brand. The subwoofer will have to be tray mounted as I cannot compromise on boot space.
BTW I want a total SQ system and not SPL. As an indication looking at spending max Rs50k more.
Looking forward to your suggestions.
Viper
viper is offline   Reply With Quote
Old 13th September 2007, 10:50   #2 (permalink)
viper's Avatar
Bump,
Where are all the Guru's.
Viper
Old 13th September 2007, 10:55   #3 (permalink)
shrivz's Avatar
Im no guru, but i'll try and help.
Jiggs, just clarify whether the Sub is recommended for free air usage.
If not, you'll have to change it, moreover since you're looking at a free air Sub, the 180 watts from the audison is gonna be a little less to drive it, but probably if you arent looking at high SPL, you can give the sub a higher gain setting. For front soundstage, Its the tuning which matters a lot.
I personally think that you have a good setup, it just has to be tuned right, cut off the speakers with the electronic x-over on the amp as per the specifications of the speakers, and then fine tune it by ear.
Also, set the HU EQ to flat and then adjust it as per your taste.
On alpines, I usually end up take the treble -1db and if required, the bass +1db.
__________________
Technical skill is the master of complexity, while creativity is the master of simplicity...
shrivz is offline   Reply With Quote
Old 13th September 2007, 10:58   #4 (permalink)
DerAlte's Avatar
1. How about trying out an IDQ12? Put a fiber-glass enclosure the width of the parcel tray about 6" deep (even lesser if you don't mind a protrusion to accommodate the sub depth). That should give you a decent box volume without compromising boot space, and more important, give you a sealed box for more bass definition at low volumes instead of the usual boomy IB. Time alignment in the Alpine HU would bring the bass forward.
2. Since you have already crossed the levels of ordinary, maybe it is time to put in ID compression horns below the dash to improve the front imaging. Gunbir / JB would be the best to advise on this. A tad costly, but the results would be spectacular
My 2 bits!
__________________
Never believe it cannot be done - it's only that you haven't found out how!!!
Old 13th September 2007, 11:00   #5 (permalink)
RedOne's Avatar
Viper
Viper,
How easy was it to fix the 6.5 on the doorpad? Drop in, just cutting the pad or extensive modification? I too am considering same.
Gears,
Red-One.
RedOne is offline   Reply With Quote
Old 13th September 2007, 11:29   #6 (permalink)
viper's Avatar
Its a drop in fitment.
Viper
Originally Posted by RedOne View Post
Viper,
Gears,
Red-One.
Old 13th September 2007, 11:45   #7 (permalink)
iraghava's Avatar
Viper - I'm pretty sure that fitting a 6.5" component requires cutting of the door pad since I tried to fit the same in my car & they wouldn't fit without cutting.
__________________
Power corrupts. Absolute power is kind of neat.
iraghava is online now   Reply With Quote
Old 13th September 2007, 11:48   #8 (permalink)
viper's Avatar
Ishan,
This car had come with 6" co-axials installed by previous owner. Either he had cut the door pad or they fit as I certainly did not cut them. I simply replaced them with my speakers and they fit perfectly on mdf spacers.
Viper
Old 13th September 2007, 12:22   #9 (permalink)
Viper
Ishan and Redone, MDF spacers will do the work as the OHC's plastic door cladding protrudes in the front enough to accomodate the push by the MDF spacers.
Unless the speakers' base magnet design is such that it is too big for the OEM hole, it should not be a problem.
__________________
...looking forward to sit a few feet above mean road level and away from potholes...
gbpscars is offline   Reply With Quote
Old 13th September 2007, 12:33   #10 (permalink)
iraghava's Avatar
Well when I tried shifting my Velocity's to the front, they didn't fit since the installer said that the magnet was too deep & would foul with the door.
Sam, Ajay, Navin - any personal experience with this? I wouldn't mind having 6.5" comps in the front of my car.
__________________
Old 13th September 2007, 12:43   #11 (permalink)
Bass&Trouble's Avatar
If the Electra 5.25" driver could be installed then the 6.5" after cutting will fit too, since the difference in mounting depth is just 3mm. 63 v/s 66 mm.
However, that would hardly be an upgrade, may I suggest the Luccent 6" comps. Mounting depth of 40mm.
__________________
Operator! Give me the number for 911!
Bass&Trouble is online now   Reply With Quote
Old 13th September 2007, 12:54   #12 (permalink)
blueraven316's Avatar
Have you heard the Audison push that same sub off an Enclosure till date ? If no, then try that just for the heck of it to see whether even with a box does the amp live up to the power you seek. The sub for sure can handle more juice (almost double of what it's getting now) .
If you are satisfied, then you probably don't need a amp change.
If not, then you should go in for a new mono Amp. Good Options would be likes of JL Audio 250/1.
The 12" inch sub is on the parcel tray now, so you have already cut the metal below the parcel tray to a significant extent. I think getting an enclosure incorporated on the parcel tray itself will be little difficult for a 12" sub, but for a 10" sub you can get a new parcel tray custom built with a sealed enclosure at the bottom of the sub, hence not eating into boot space, and giving you some real tight and strong bass.
Now, depending on how much more juice you need from the fronts you may change the component Speakers, but that entirely lies upon what kind of SQ you want from the speakers, whether it's more loudness or stronger mids.
Existing:
blueraven316 is offline   Reply With Quote
Old 13th September 2007, 13:11   #13 (permalink)
iraghava's Avatar
Hmmm... interesting, why didn't you tell me this info when I was getting the 5.25"? Would have done the upgrade then itself.
Got any complimentary set lying around kya?
__________________
Old 13th September 2007, 14:12   #14 (permalink)
navin's Avatar
Hi Guys,
Existing:
1. when you get bored of the 9887 let me know.
2. If you are willing to modify the front door panles I would suggest that a 8" 3way would be your best option.
3. it is very difficult to tune an IB sub to deliver the best SQ. one option would be switch to smaller subs (2 x 8" or 10 in custom boxes that fill up the nook can cranies in hte OHC boot. This will still rertain most of teh boot space (the nooks and cranies are rarely used when you are carrying 30" bags). I did something similar in my Octy and Gunman and co did something simialr to a CRV (2 x 8").
4. The SrX5 is too small an amp for your SPL needs. One option is to get a second SRx5. run the front and rear bridged. and use the 2 mono channels to drive 2 smaller subs (10" would be great).
__________________
Scixelsyd Etinu
Old 13th September 2007, 15:23   #15 (permalink)
hydrashok's Avatar
For an SQ setup, I'd also think in terms of the following:
1) 2 x 10" subs. Preferably IDQs. Because these babies need very little enclosure volume (0.4 cu.ft per sub is enough), maybe you'll be able to get a shallow sealed enclosure made right in the parcel-tray itself with FG.
You'll definitely need to change the sub-stage for a proper SQ setup. IB-install for SQ is a definite no-no, IMHO.
This would burn about 22K-24K of your budget, including FG.
2) A new amp, for sure. Ideally, a Mono to drive the subs. Else, I'd get a powerful 2-ch amp like the SRx2S or the LRx2.500 and run the subs with it.
Or, you'll have to go crazy and sell the SRx5, and get a 4-ch amp and a mono amp/powerful 2-ch amp Very very expensive upgrade.
Navin's suggestion of a new SRx5 also sounds good -- the speakers get more power (the channels get bridged), esp. the front stage getsthepower it needs. However else you upgrade, I think one channel of that SRx 5 would remain idle. But an additional SRx5 would make sure that all channels get used.
BTW how does the new 9887 sound? Review pleeeeeeeeeez.
__________________
Alpine 9887 | TRU Tech S44 | Image Dynamics XS65 | Image Dynamics IDQ12 D2V2 | Connection Audison
hydrashok is online now   Reply With Quote
Thread Tools
ICE upgrade for OHC VTEC. Gurus please help. vishnuvijay Ask the Gurus 45 29th March 2008 01:54
Help .. For tyre upgrade for OHC VTEC .. devilvtec Tyre & Alloy wheel Section 4 10th August 2007 00:31
Suggestion + Upgrade my system smreddy Ask the Gurus 16 10th July 2006 15:30
NHC-Vtec or OHC Vtec..which is a better buy? sunith Sedans 4 2nd May 2006 22:25
Wanted: OHC VTEC or OHC 1.5 adit1329 Shifting gears 4 16th March 2006 18:39
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
