| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #46 (permalink) | |
| Team-BHP Support ![]() Join Date: Mar 2004 Location: mumbai
| Quote:
__________________ Scixelsyd Etinu | |
| | #47 (permalink) |
| BHPian Join Date: Aug 2006 Location: New Delhi
| Thanks navin, what range can this work under? For example, would 300mV be adequate as well? And would there be any advantage of going with a 100mV input sensitivity amp as opposed to a 200mV or 300mV one? Also, the blaupunkt installer had said that the higher the pre-out voltage of the audio device, the better the sound I would get. He said ideally it should be upwards of 2V. (I imagine the output of a mp3 is somewhere between 100 and 300mV.) Is there any strength in what he says? Or is it just a matter of matching the two - i.e. if the mp3 player gives 200mV and I set the amp to a sensitivity of 200mV, then I get 'optimum' performance? Last edited by vebmetal : 2nd October 2007 at 02:48. |
| | #48 (permalink) | |
| Senior - BHPian Join Date: Mar 2006 Location: New Delhi
Infractions: 0/1 (4) | Quote:
__________________ SINGH IS KINNNNNNNG.. | |
| | #50 (permalink) | ||
| Senior - BHPian Join Date: Sep 2007 Location: New Delhi
| Quote:
..the LOUDER the sound you will get. Quote:
You would need to turn the amp's sensitivity control till you get loud enough output, ie nearly the max that the amp can deliver OR till you're happy with the loudness. If that proves impossible (with the amp's control even at max) you know that your source needs to give higher output. 200 or 300 mV might be too little to drive most power amps to full output. The standard is more like 775 mV RMS. I'm not familiar with what your amp needs by way of input signal to give it's rated output. Last edited by anupmathur : 2nd October 2007 at 12:58. | ||
| | #53 (permalink) |
| ^rrrrrrriiiiiiiiiiigght.... coming back to my question is the voltage issue going to be a problem in my setup? Will the low pre-out voltage of the mp3 player mean that I would have to set the input sensitivity very high, and does that mean that I would compromise on the quality of sound? |
| | #55 (permalink) |
| hmmm.. practically speaking how much of a risk am I running in terms of getting said noises and disturbances? The setup would be like this: Amp: Placed under passenger seat. Power connected to battery. Ground connected to wherever it needs to be. Speaker wires for front components going under the dash to connect to whatever provisions exist to connect to speakers. Remote (Turn-On) wire connected to ignition, with a switch in the middle so that the amp is not on always. Cabling: Tsunami for amp. Connection Audison for Speaker wires going from amp to under the dash. Stock wiring for speakers. Last edited by vebmetal : 2nd October 2007 at 16:38. |
| | #56 (permalink) | |
| Quote:
I was following this thread, but there has been an inordinately long silence. About your query: Should be alright. However, please note I am not into ICE installs and hence not familiar with the specific hardware you are talking about. YOU are quite familiar with that aspect. In fact, I'm only answering this as (being a national holiday) it seems that Navin and Sam have headed out already to the neighbourhood pub for their evening W & S! In case your MP3 player does not have a line out but has only the headphones out, you might need to 'load' your output with an appropriate resistor (8 ohms or 32 ohms, 1/2 W) to achieve best performance. (Sometimes the phones output does not directly give good/clean output when plugged into an amp's line in). _______________ No offence meant to anyone please! | |
| | #57 (permalink) |
| My mp3 player only has a headphone jack. I haven't seen any mp3 player with a line-out. If you know of one, please do let me know because that would solve my problem!! (And anyway a DAP upgrade is due for me). As far as this resistor thing goes, I wouldn't want to do a mod / jugaad to my mp3 player, so do let me know if there is any device (that I can fit after the headphone out) available in the market (India or U.S.) that would do what you describe. |
| | #58 (permalink) |
| What I have described is not a 'jugaad' by a long shot! All it means is that you are providing optimal 'loading' for the MP3 player's phone output by soldering on an appropriate resistor across it's output (anywhere that you find convenient along the whole length of the wire going from MP3 player's phones out to amp's line in) so that it (the player) believes it has a 'headphone' connected to it. That voltage signal across that resistor can then be led to the amp's line in. It's just a resistor 'soldered on' in parallel, IF required. And I did mention that it is required ONLY in SOME cases. NOT always. Nothing needs to be imported from the U.S. I only mentioned this point because I am well aware that MP3 players do not have a line out. And, SOMETIMES, the phones output does not exactly 'match' an amplifier's input impedance/characteristic. |
| | #60 (permalink) | |
| Quote:
That's why I mentioned the 32 ohms resistor. And for that matter there are some at 600 ohms too. Idea is that once the 'seed' is planted a hobbyist kind of 'gets the idea', right? Again, I have said the same. But there ARE those cases. | |
| Thread Tools | |
Similar Threads | ||||
| 3D MAX work on computer modelled cars & bikes | blueraven316 | Shifting gears | 42 | 2nd October 2008 01:00 |
| Crazy Idea 2- using pc speakers rather subwoofers - Will this work??? | coolaks7 | Ask the Gurus | 38 | 24th November 2007 18:40 |
| Does K&N really work? | amu1983 | Technical Stuff | 1 | 14th March 2007 22:29 |
| Any idea about FIAT Idea? | Minardi | The Indian Car Scene!! | 13 | 28th May 2005 13:38 |
| Getz & Focus - Any idea when? | neverclever | The Indian Car Scene!! | 48 | 7th August 2004 02:22 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
