Thread Tools
Old 13th September 2007, 07:46   #1 (permalink)
Vino_David's Avatar
Default Pls help in ICE upgrade in Santro
am planning to upgrade my front existing Boston 4" coax (it seems it doesn't exist there) , the rear is so dominating, car is Santro.
am planning to install MB Quart DSD210 4" 2-Way Component Speakers --brought from UK
the specs are:
4 (100mm) 2- Way Separate System
Tweeter: 3/4 (19mm) Titanium dome
Woofer: 4 (100mm) Polypropylene Cone
Crossover: 12 dB/Octave @ 4000Hz
Impedance: 4 Ohms (nominal)
Freq. Response: 65Hz to 32,000Hz
Power Range: 30watts (rms.) to 70watts
Gurus i think Illusion also has 4" compo, i don't think i can audition MB Quart anywhere, so suggest whether i can go ahead with MB Quart.
__________________
Every Weapon Needs A Master
Vino_David is offline   Reply With Quote
Old 13th September 2007, 13:31   #2 (permalink)
panky12345's Avatar
Infractions: 0/1 (4)
I dont think upgrading from 4" coax to 4" comps will increase the front stage drastically. Go in for bigger comps if you want to concentrate on improving the front stage.
__________________
SINGH IS KINNNNNNNG..
Old 13th September 2007, 13:54   #3 (permalink)
navin's Avatar
you got them, why not use them?
__________________
Scixelsyd Etinu
Old 13th September 2007, 13:58   #4 (permalink)
DerAlte's Avatar
Arrey Panky-saheb, the tweeter of the compos will be mounted on the dash near the A-pillars, and hence will definitely improve the front imaging.
Bigger comps will only improve bass over this. If @Vino_david is OK with the current bass level (the mid-bass of the compos is expected to be slightly better than the co-ax), he need not bother with cutting-shutting the Santro door to mount the larger speakers.
__________________
Never believe it cannot be done - it's only that you haven't found out how!!!
Old 13th September 2007, 14:06   #5 (permalink)
panky12345's Avatar
DerAlte bhai....you are pretty right!
Vino says rear overpowers the front..considering this I suggested using bigger comps. Yes, adding comps in place of coax would definetely improve SQ, but NOT drastically. :-)
__________________
Old 13th September 2007, 14:11   #6 (permalink)
Vino_David's Avatar
@navin i still dont have those MB Qart in my hand, is MB quart a good product ?
if comps gonna change front stage, definitely i'll put 4" comp, i dont want to cut my door plsss.
__________________
Old 13th September 2007, 14:13   #7 (permalink)
navin's Avatar
MBQ is not what it used to be. Why not try Illusion or Hertz as they are available locally and are supported ably.
__________________
Scixelsyd Etinu
Old 13th September 2007, 14:36   #8 (permalink)
Vino_David's Avatar
navin, does Hertz have 4" compo, where can i get illusion 4" comp ?
__________________
Old 13th September 2007, 14:39   #9 (permalink)
DerAlte's Avatar
PM @bass&trouble for the Illusion components.
__________________
Old 13th September 2007, 15:14   #10 (permalink)
Vino_David's Avatar
@ deralte thanx for help
i will pm him
__________________
Old 13th September 2007, 15:16   #11 (permalink)
panky12345's Avatar
and PM gunbir for hertz....am sure he can help!
__________________
Thread Tools
Pls suggest me a good ICE installer in Chennai kpkeerthi Ask the Gurus 88 4th July 2008 20:49
Tyre upgrade for lancer. help pls.. prav_05 Tyre & Alloy wheel Section 9 12th November 2007 23:15
ICE upgrade in Santro Vino_David Ask the Gurus 0 12th September 2007 16:18
Video ICE for Baleno - Suggestions pls BWN Ask the Gurus 35 21st August 2007 17:49
Completing my ICE install. Suggestions Pls ! Lemon Ask the Gurus 14 29th January 2007 10:41
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
