Thread Tools
Old 16th September 2007, 10:14   #1 (permalink)
Default How to get good sound in a Skoda?
Hi guys,
Most probably buying a Laura today [used]. The sound I hear is not so good and I might want to upgrade the speakers.
The rear deck is a lifting type and looks pretty flimsy so what do I do for speaker mounting? AFAIK in door speakers can never give enough bass? I also dont want to use up luggage space for a sub etc.
Any suggestions?
I saw this post where he has mounted speakers in the lifting deck. Is the deck solid enough to take it without vibrating?
http://www.team-bhp.com/forum/sound-...tall-pics.html ("Barracuda" Autopsyche Octavia - ICE Install pics)
My knowledge about ICE is ZERO so any help will be much appreciated.
__________________
Thanks,
Kumar
kumar2007 is offline   Reply With Quote
Old 16th September 2007, 10:47   #2 (permalink)
vid6639's Avatar
The parcel shelf will have to be replaced with an MDF one. Even then there will be some rattle as it will be or large size and will flex with the speakers weight. Also, the shelf will not be removable when you open the boot. A better option is to have all the door speakers and go for a sub in the boot.
The laura has a big boot and when you think teh sub is taking away room you can disconnect it and keep it at home.
__________________
\ / ][ |) `/ [_] "!"
vid6639 is offline   Reply With Quote
Old 16th September 2007, 11:37   #3 (permalink)
Sam Kapasi's Avatar
The Laura is a solid car. Speaker mounted in the door of the laura and even octavia sound surprisingly good.
__________________
Live the YetiLife®
Old 16th September 2007, 11:54   #4 (permalink)
gunbir's Avatar
Infractions: 0/1 (4)
Well that pic was put there as an indication of what NOT to do. Please avoid using the parcel shelf to install speakers, and use the stock locations instead.
__________________
Often imitated, never duplicated!
gunbir is online now   Reply With Quote
Old 16th September 2007, 12:00   #5 (permalink)
karan561's Avatar
If you arent satisfied with the volume , then let me enlighten you that , In the laura , as the speed increases the volume increases too , and as far as BASS is concerned the components on each door give a great effect . I geuss 12 speakers are enough , i am seriously surprised seing you unsatisfied with the ICE .
karan561 is offline   Reply With Quote
Old 16th September 2007, 12:06   #6 (permalink)
panky12345's Avatar
Volume is directly proportional to speed? this is kinda unheard in Laura Ads.
12 speakers? when did he say that?
__________________
SINGH IS KINNNNNNNG..
Old 16th September 2007, 12:10   #7 (permalink)
DerAlte's Avatar
Navin has a Skoda (Octavia, I guess) so he is very familiar with the nooks and crannies. You can check out pics of his setup - search the forum for "pink protruberance" (OK, OK, no funnies please, @iraghava, that was a mnemonic I remembered from my posts). One of the best uses of space I have seen. His stuff cannot be easily replicated, but the space usage definitely can be - Skodas don't vary much.
You have not mentioned a budget, so can one assume that you don't have a limit?
There is no reason why door mounted speakers cannot give good bass (mid-bass, really, since a sub handles the really low stuff). And for the front, there is no alternative in large cars (smaller cars have a dash mount option). Go for good components in front: Infinity, Illusion, Hertz, JBL, Blaupunkt, ... wide range of makes an models an prices. Audition them and select based on what you prefer, since their sounds differ (though all of them are good).
You can always replace the deck with a 1" MDF plank covered with automotive grey carpet, and that will not be flimsy at all. This would be good enough for 6x9 oval coaxials (good low end thump, but not the same as subs) or 6.5" components / coax (even 8" at a pinch).
Alternatively, you could have the "flimsy" parcel shelf stiffened with fiber glass on the underside, and damped with sound damping. That would give you very decent results instead of the MDF.
Mounting a sub-woofer on the parcel shelf is not ideal, since this IB (Infinite Baffle) arrangement does not produced well defined bass. For that, a sealed box is ideal for SQ - check out the way Navin has mounted a fiber glass box in a normally unused space. Use a 12" IDQ (Image Dynamics) sub in such a box - it needs very less box volume. Navin has an Infinity sub.
Of course, everything is relative to your choice of music, and there is no "one size fits all" concept in ICE. Trust your own ears for making the right choice.
The best would be to go step by step, feeling comfortable with what you get, and knowing what more you need, along the way:
1. Put in sound damping / deadening, and check if the stock system is still lacking for you
2. Change the stock speakers to good components, check if the HU power is insufficient for you
3. Add amp(s) and sub if you need more
__________________
Never believe it cannot be done - it's only that you haven't found out how!!!
Old 16th September 2007, 12:19   #8 (permalink)
hydrashok's Avatar
The Laura is indeed a good car to ICE. Solid body panels. You won't need to spend much on damping. And it has stock provision for 3-way comps in the front door, if you want to do that. I'm sure you'll get good results from midbasses installed in the stock locations in the doors.
Better avoid the parcel tray for any kind of speakers. A sub there is a definite no-no. Unless you haul a lot of stuff on a daily basis, you'll be able to sacrifice about 1.5 cu-ft of space for a sub-box in the boot, won't you?
What's your budget? Do you plan to keep the stock Head Unit (HU), or upgrade the HU too?
Like DerAlte said, maybe you can start by upgrading the stock speakers. Good pairs of 2-way comps in front and coaxials in the back should keep your Stage 1 expenditure in the 12K to 15K range. You'll need to think of the rest (Amp + Sub, HU Upgrade etc) only if you're not satisfied with the results.
__________________
Alpine 9887 | TRU Tech S44 | Image Dynamics XS65 | Image Dynamics IDQ12 D2V2 | Connection Audison
hydrashok is online now   Reply With Quote
Old 16th September 2007, 12:24   #9 (permalink)
DerAlte's Avatar
VW (and Audi / Skoda / SEAT etc.) specs for mid-range cars onwards. Their stock ICE vendors have to comply with that. There is a vehicle speed signal given from the engine / transmission ECU which gives wheel RPM (vehicle speed, assuming that the tyres are touching the ground), which the HU is supposed to use for adjusting volume proportional to vehicle speed. Can be analog (smoothly proportional) or binary (e.g. above a certain speed), and is implemented as a %change on the set volume.
__________________
Old 16th September 2007, 15:57   #10 (permalink)
karan561's Avatar
Thanks @ DerAlte , u saved my time , otherwise i would have to explain all of that to panky12345.
Old 17th September 2007, 12:37   #11 (permalink)
panky12345's Avatar
WOW! This is something that I've learnt today....Thanks!
__________________
Old 17th September 2007, 13:27   #12 (permalink)
navin's Avatar
There is no reason why door mounted speakers cannot give good bass..Go for good components in front: Infinity, Illusion, Hertz, JBL, Blaupunkt, ...
1. Do not, I repeat DO NOT mess with the rear deck. The existing rear deck is flimsy but well made. If you notice it is deigned to be clamped when the hatch is shut and will not vibrate much. If you use a MDF deck you can design it to do the same but the hydralics will not be able to lift the weight of such a deck. If you stiffen the MDF deck with FRP (resin bonded fiberglass) it will also be quite heavy esp. after you install speakers on it). You would need atleast 6mm of FRP to make the deck stiff enough.
2. The Skoda has well built doors and body panels but they still could use damping. I would damp the sides of the trunk, the 4 doors and the firewall. You will need about 10 sheets of American Dynamics for that. I used 8 sheets of AD and 2 sheets of Dynamat Extreme. If the Skoda needs 8-10 sheets think how much one needs for a Honda City (that tin box is smaller but needs as much if not more damping that the Octy/Laura).
3. If you can afford 3 way speakers in the front by all means get them. The Laura was made for 3 way. My Octy was not. Illusion (Bass and Trouble), Hertz (Gunbir), DLS (Low Bass Makker - ok he does not represent them but he has them) all make very good 3 way speakers.
4. Any good component system (esp 3 way) will demand a good amplifier. You can choose from Infintiy, Audison, Tru Tech or Steg (LBM's favourite amp).
5. An ID sub will do very well on the left hand side of the Laura. The cavity should be about 1 cu. ft. It was a bit small for the Infintiy I had around so I had to go aperiodic (the other choice was push-pull Isobarik but there was not enough room for that either).
6. The most diffcult part of the Octy (I dont know if it is the same for the Laura) was providing a sound stage for the rear. The rear pods accomodate only 12-13cm woofers. So you have choose them carefully. Few 12-13cm woofer can produce good SPLs at 80Hz. I found a work around by using 2 (slightly modified) 6.5" bass tubes for the mid bass (80-200Hz). The rear deck is a natual acoustic filter so the 6.5" woofers midrange is attenuated and hence the midrange of the 12-13cm speakers (in the stock pods) is left undisturbed.
All cars need some damping. My Octy's ICE was built around having enough room to still carry 3 26-30" bags, 1 in-flight roll-on roll-off bag, and a few smaller bags.
It's been around for a while panky.
__________________
Scixelsyd Etinu
Old 29th October 2007, 14:13   #13 (permalink)
evo
evo's Avatar
Default Octavia Rs
Hi Navin,
Got an Octavia RS recently. I`m planning to keep the stock HU and speakers and put in an amp and a woofer. I have a sony 222 amp and a 12inch woofer with me.
I know its pretty basic, but what do you say?
Also should the woofer be in that triangular box sort of thing? And should it point towards the boot or towards the rear seats?
Can I run both the stock speakers and the woofers from that amp?
I like tight bass and listen to all sorts of stuff.
Also what is damping and what does it do?
Deval
evo is offline   Reply With Quote
Old 29th October 2007, 21:01   #14 (permalink)
To get good bass either for spl or sq having a subwoofer is a must. the size of the skoda's boot is quite big. you can have a sub(or 2) on the side of the boot without affecting the boot space much. the link below shows you one of the ways how you can place it.
http://home.twcny.rr.com/eeibooks/ro...cosubsrear.jpg
Once the sub(s) is done then you can very well go for a good components in the front and coaxials at the rear without altering anything in the car
kaadye is offline   Reply With Quote
Old 26th July 2008, 14:09   #15 (permalink)
The_Warrior's Avatar
This is applicable with my Optra also. I still dont know whether it is the HU or the Car itself which manages such a thing. But this can be painful at times, as in when you are at a red light and there is a good number playing and you turn up the volume and the moment you cross 50 KMPH the volume goes up and then again you have to turn it down....
__________________
The Man who smiles when something has gone wrong has already thought of somebody to blame it on :-))
The_Warrior is offline   Reply With Quote
Thread Tools
is SKODA RS 7L a good buy? redsfx Sedans 116 8th September 2008 18:28
Sound Quality not good on new ICE setup. Help! maverickzCar Ask the Gurus 24 28th December 2007 15:15
Good SPL Sound Jas6789 Ask the Gurus 31 27th February 2007 17:18
Jerking sound from skoda..please help me. jerish666 Technical Stuff 6 23rd December 2006 01:41
Good site for TDI lovers (skoda) jat The Indian Car Scene!! 3 8th January 2006 23:32
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
