| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #1 (permalink) |
| Newbie Join Date: Aug 2007 Location: delhi
| i recently booked an aveo ls... it comes with a kenwood mp3 player(i think the 4029)...4 speakers nd two tweeters what can i do in order to get more bass? i dnt want to change the system..just want to add to it! max budget-10k plz help me out... |
| | #2 (permalink) |
| Senior - BHPian | Get a decent 2-channel amplifier, say 60.2 for 4-4.5k, put a GT4-12+Custom sealed enclosure for 6-6.5k, bargain with or strangle the dealer for 1k discount, use the credit card that you swore you never would for 2k and get the wiring and install covered. Total cost should be about 13k. ![]()
__________________ ... Everything should be made as simple as possible, but not simpler |
| | #5 (permalink) | |
| Senior - BHPian Join Date: Mar 2006 Location: New Delhi
Infractions: 0/1 (4) | Quote:
__________________ SINGH IS KINNNNNNNG.. | |
| | #6 (permalink) | |
| Quote:
aisa koi jugad nai hai jisse everything(volume..quality etc) remains the same nd only the bass increases?? nd wat if i dnt use a sub/tube...only buy an amp nd connect it to the speakers..nd use an equaliser to get more bass??? will this wrk?...will thr be ne negetive effect on my speakers by doing this? | |
| | #7 (permalink) |
Infractions: 0/1 (4) | if only bass (and practically no voice/mids/music etc) is needed go in for amp+sub/tube combo ONLY. I suggest you listen to this first before you buy. If need proper sound: 1. go in for a decent 4 channel amp, replace your stock speakers with comps in the front and 6X9 in the rear. 2. when pocket allows, add a mono + sub/tube.
| | #8 (permalink) |
| Distinguished - BHPian ![]() | If you don't wanna upset the present setup, you can go in for an active sub. Since it comes with a built in amp, it'l save time, money and space. We've got an 8" Soomoku (hope i spelt it right) active sub in our Innova. It's prob an entry level system but it does the job pretty well. With a little tuning you can get a very soothing low frequency output from it. I think it costs around 5-5.5K if i rem right. I'm sure there a many more sub-10K active subs in the market. Shan2nu
__________________ VTEC flyby - youtube.com/watch?v=1AhWJlVRPqE Last edited by Shan2nu : 17th September 2007 at 16:03. |
| | #9 (permalink) |
| BHPian Join Date: Jul 2007 Location: Lucknow/New Delhi
| sidomania I had a bit similar problem sometime before, got to my senses after the panky bhai did a bit of counselling ... ![]() but now its really clear to me, SQ is what I want (obviously apne budget wali .. ) |
| | #10 (permalink) | ||
| Senior - BHPian | Quote:
Bass tubes are also VFM and preferred by many. But active tubes (with built-in amplifiers) are not preferable to amp+passive sub. You may consider a 2-channel amplifier and a bass tube like JBLGTO1204T which is a much better choice and fits your budget.
__________________ ... Everything should be made as simple as possible, but not simpler | ||
| | #11 (permalink) |
| ok so i think i will go in for either a 2 channel amp nd a bass tube or i will buy an active sub... which one is a better choice? nd will the sub give gud tight bass? nd will this result in only low frequencies?..i dnt wanna compromise on music quality.. which one will be a better option keeping this in mind... nd also plz suggest tht wat will be the effect of connecting a 4 channel amp with the stock speakers? |
| | #13 (permalink) |
| in the end.. LP ![]() BtW the end has not come as yet, going to Delhi on 19th, will decide what to buy according to my very tight budget yar, till now thought of everything - a decent amp + comp + sub, I really don't know how would I get it though you refer to this thread if you want http://www.team-bhp.com/forum/ask-gu...tml#post562775 (budget - 11 k, amp + Sub or amp + comps?????) cheers |
| | #14 (permalink) | |
If you want good tight bass, go for a sealed enclosure. Yes, subwoofers are designed to produce only low frequencies. SQ will be hampered if you keep the sub level at moderate to high, since bass will start to dominate. That is why a pair of components is preferrend along with this. Either of them will have the same effect on your setup, it is just that active will not be a good choice. The stock speakers may not able to take the load and may rattle, forcing you to keep the sub level low and the volume in the HU high. You'll have to set the HPF and gains at moderate to low levels.
| Thread Tools | |
Similar Threads | ||||
| Aveo vs Verna EDIT: Bought Aveo | an10 | Sedans | 82 | 8th April 2008 18:01 |
| Help!!! Bass Too Loud | m4ugr8 | Ask the Gurus | 31 | 21st August 2007 20:59 |
| Improving BASS | shashankre | Ask the Gurus | 32 | 4th April 2007 01:07 |
| Which is better - Bass tube or s/w? | panky12345 | Product Discussions | 16 | 7th August 2006 23:21 |
| loss in bass | kooldude | Ask the Gurus | 22 | 25th June 2006 19:41 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
