Thread Tools
Old 24th September 2007, 10:38   #1 (permalink)
Default Need help ICE GURUs : Possible Sync problems
hi Navin,Sam,LBM,Gunbir and all others,
i need some help regarding a possible sync problem with sound setup in my safari.
let me ist list the setup
FRONT
DSK components running with a 2 channel Blau Amp.
REAR
2 pio 6x9s and a Kenwood sub running with a Sony 554
now the problem,whenever i change the song,i hear some noise from the rear setup.
the noise lasts just for say 10 milli sec,but its there
and it looks as if the rear setup responds a bit late
so i thought its a syncronization problem
i'm using all 3 preouts of my HU
Please advise how can i get away with this?
is it something that happens often?
Thanks in advance
simply_sunny001 is offline   Reply With Quote
Old 24th September 2007, 10:53   #2 (permalink)
low_bass_makker's Avatar
What type of noise ? And how are sure that the delay is 10 milli sec or it is just your assumption.
Old 24th September 2007, 11:07   #3 (permalink)
the noise is like when u shut off some speaker abruptly
and it last very little much less than a second so i wrote that
Old 24th September 2007, 11:13   #4 (permalink)
This noise is caused by ground loops. I had the same problem in my car, but with the front speakers.
Check the following things :
1) Try to change the ground of the amplifier to some other point and see if it solves your problem
2) Try to change the RCA and see if the problem is solved
3) Ground the chassis of the head unit and see if the problem is solved
4) Ground the RCA with the chassis of the head unit and see if the problem is solved
5) Ground both the amplifiers to the same point
akg7091 is offline   Reply With Quote
Old 24th September 2007, 11:32   #5 (permalink)
but i am not sure abt Grounding cud be the reason here.
cos i have properly grounded the Amps and HU and i have done it myself.
will try to change the grounding points though
but i wanted to ask GURUs if this is a common problem?
if we do any specific things while installing to avoid such things?
Old 24th September 2007, 14:13   #6 (permalink)
DerAlte's Avatar
Could you check in the Sony 554 manual the method used by the amp to go to / come out of sleep, and soft start?
Perhaps the amp is sensing the input signal level (at the RCA) to do some jugglery to minimize power consumption - which is causing delay in amplification.
I hope you don't mean that the 554 is constantly retarded - constant delay that one can make out front to rear, which might produce an eerie echo-like sound.
__________________
Never believe it cannot be done - it's only that you haven't found out how!!!
Old 24th September 2007, 18:32   #7 (permalink)
I have faced the exact same problem in the past ( speaker used to make clicking sound as if a wire is loose whenever I used to change songs or switch the stereo on/off ) and I solved it by grounding both amplifiers to the same point. The ground may be fine, but sometimes due to the potential difference between the different ground points noise may occur. Just try it once and post the results. The other method I used way back was to take a small wire, tie it to the outer connector of the RCA and then tie it to the chassis of the head unit.
Also, make sure when you are grounding it to scrape off all the paint from the area you are grounding it to. This will reduce resistance and make a better ground. Or if you can, take a thick wire and ground the amps to the floor panel of the car.
Old 8th October 2007, 13:12   #8 (permalink)
i tried grounding both the AMPS to same place but it dint work out
still having the noise problem in rear speakers.checked cabling,everything looks OK to me.
please advise on any other possible problems.
Old 8th October 2007, 15:45   #9 (permalink)
hmmmm
Go to a good installer. He can find out what's causing the noise. Also, are you running both power and rca/speaker cables alongside eachother ? This may also cause such a noise.
Thread Tools
Motorcycling in sync GutsyGibbon Motorbikes 0 27th July 2008 08:25
ICE upgrade for OHC VTEC. Gurus please help. vishnuvijay Ask the Gurus 45 29th March 2008 01:54
Ice Setup Zen – Audio Gurus plz help nicejits Ask the Gurus 14 20th September 2007 16:45
Need help ICE GURUs :- HU forgets the settings with every restart simply_sunny001 Ask the Gurus 13 23rd August 2007 13:13
Problems with ICE in my Viva Crdi mobike008 Ask the Gurus 47 2nd March 2007 13:32
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
