Thread Tools
Old 11th October 2006, 16:52   #1 (permalink)
windsurfer's Avatar
Default The Palio ICE Thread
I have gone through a good number of threads before posting this. I have booked a Palio 1.6 Sports and would need to setup ice this weekend. I had a Indica earlier which had a sony MP3 player. two Oval Pioneer speakers mounted on the read parcel tray. And 2 small speakers in front and none on the doors. i was pretty happy with this system. The only problem was mounting the those huge speakers on rear - it rattled a lot. I don't want this problem in my palio.
Now my budget is around 25-30K. How good are component speakers? And here are my requirements -
1. Need components speakers for stock sockets/slots provided. Don't want to put heavy speakers on rear tray.
2. No Amp, Sub now. I will upgrade later.
3. Regarding the quality - Well, I like Sound quality and loudness. Depends on my mood.
Please suggest a setup for this. Also, I am based in Hyderabad. I need a good installer to setup this system.
windsurfer is online now   Reply With Quote
Old 11th October 2006, 17:18   #2 (permalink)
mobike008's Avatar
Post
Originally Posted by windsurfer
Firstly, your budget of 30K is a bit on the higher side for an ICE without an amp and woofer ( infact you can get a decent amp and woofer within this budget)
Component speakers are really good and an amp is needed to drive the front comps. I have recently fitted an ICE into my new car and the SQ is quite nice, I went for a Pio 6850 ( best that is available in this price segment), Blaupaunkt front comps, JBL GTO 937 for rear and Pio Sub woofer and a sony 554 4 channel amp. you can get all this within your budget.
I got my ICE fitted from Max Motors in Minister road, good service and recommended to me by a fellow tbhpian.
__________________
[b][i]The nail that sticks out gets hammered !!!
Old 11th October 2006, 18:00   #3 (permalink)
esteem_lover's Avatar
Infractions: 0/1 (5)
the last line in your post should be given the first priority. learnt that from experience.
you could also take a look into this to arrive at what kind of a system you will require regarding budgets for each item.
cheers
__________________
Goodbye Dada, you made us proud.
esteem_lover is online now   Reply With Quote
Old 11th October 2006, 18:16   #4 (permalink)
rsjaurr's Avatar
If u got 30k for HU and speakers [if not using ur old sony HU] go for pio HU with atleast 3pre-outs fro abt 9k.
For speakers i would advise u to go for infinty kappa if u can buy within 20k.Other alternatives r focal,boston,hertz,polk momo and JBL.
rsjaurr is offline   Reply With Quote
Old 11th October 2006, 19:03   #5 (permalink)
iraghava's Avatar
I would say get a good HU at about 9K and get components for the front at about 6-10k and co-axials for the rear at about 4-6k. Remaining money buy a good 4-ch amp like the Pioneer 6200 for about 7.5 or JBL 75.4 for about 13k to power the speakers. You should plonk an amp now since components tend to work really well with external amplification as the HU's internal amp cannot give them enough juice!
__________________
Power corrupts. Absolute power is kind of neat.
iraghava is online now   Reply With Quote
Old 11th October 2006, 19:58   #6 (permalink)
windsurfer's Avatar
Thanks Guys. Here are some basic questions. I am not a Pro at this, so please excuse if they are real silly -
1. Front speakers are compo. Rear would be co-axials. Why not compo at rear as well. Can the rear speakers be fitted in the slot provided and not on the tray. This is my prime concern.
2. Regarding, the AMP and sub - I don;t want to loose any boot space. So is it advisable to go for it? Can I only buy the AMP and not sub?
Old 11th October 2006, 20:01   #7 (permalink)
Hey windsurfer,
Get A Good Pioneer Head Unit With 3 Pre-Outs.
Comps For Front - 7 to 10 K.
Coaxials For Rear - 3 to 6 K.
Amp - Pioneer GM6200F 4 Channel Amp. 7.5 K
You Have Illusion Option As Well.
Cheers,
Mugen_Power.
Mugen_Power is offline   Reply With Quote
Old 11th October 2006, 20:05   #8 (permalink)
If you are going for Comps and Coaxials then you should have to install 4 Ch Amp.
Cheers,
Mugen_Power.
Old 11th October 2006, 20:28   #9 (permalink)
airfoil's Avatar
I'm going to try my hand at suggesting an ICE setup for the first time. I guess I qualify since have a similar setup in my GTX:
HU: Pio 6850> Rs. 8800 w/o B&W
Front Comps: JBL GTO 607> Rs. 5500
Rear Comps: GTO 507> Rs. 4500
Amp: JBL CS 60.4> Rs. 8500
Cables + install: Rs. 3000
Comes to Rs. 30,300 in all (I hope I have the prices right). You could add a subwoofer later, along with its dedicated amp. I'd want to say a component speaker based setup may not make sense without a subwoofer though.
You may want to get suitable coaxials for the rear (they should be adequate) and drive a sub (added later) in bridged mode off the 60.4.
airfoil is offline   Reply With Quote
Old 11th October 2006, 20:36   #10 (permalink)
rsjaurr's Avatar
1.You can also fit compo at back as well and that will even be better,but coax r usually recommended not to overshoot the budget [compo r costlier than coax] ,especially if u drive the car urself so keeping better spk at front is better option ["front sound stage"]than having 'em at back.
If u like to have comp at back as well,go for it but some expert would even advise to do away with rear spk as these r mainly used as fillers along with front which r more imp for front soundstage.
2.Yes u can.and i again say that would even be better.Amplifier not only helps in achieving more SPL [loudness] but also it provides cleaner signal to ahcieve SQ even at higher volumes.
Right now go with HU with 3 preouts,front compo,rear coax and a 4-ch amplifier.Go for 6.5" size spk even if u have modify ur stock location little bit as these r the biggest door size spk and will be able to produce more bass than any other door spk.You will be looking for bass from door spk as u r not interested in sub.
Infcat i would also advise u to invest some amount in damping material as well so that u can set HPF at lower possible level [~80Hz] and subsquently u will get more bass.
Other option [if u need boot space]for u is to install sub in spare wheel well in the same way as Gunbir have shown us in his thread about ICE install in Getz,especially if u have tubeless tyres.
Still wondering what is HPF,damping material,go through some of the sticky threads.
Have a nice evening...
@Mugen-i have never heard or heard about illusiobn audio before B&T told about these.Infact i have never or may be once or twice the other brands but i have heard about 'em when i was looking for my set-up.
I hope u must be enjoying ur system very much,it was very neatly installed.
Old 11th October 2006, 20:48   #11 (permalink)
airfoil's Avatar
RSJ, I'm wondering why tubeless tyres are preferred for a spare wheel well sub?
Old 11th October 2006, 21:08   #12 (permalink)
hydrashok's Avatar
I think airfoil's setup is good!
I would also suggest you give a listen to Hertz comps (for the front). I'd listened to the ESK165 and the DSK165. Both sounded really good to me. But Hertz will cost you quite a bit more than JBLs (I think 8500/- for the ESK165. The DSKs maybe the same as the JBLs, but I'm not sure. Gunbir should be able to help you with the prices). Hertz also have co-axials, if you want to consider them for the rear fill.
You will need an amp (to get best results) if you're going in for comps.
If you don't want to spring for an amp now, I would suggest you use the saved amount (using airfoil's setup as a base) to get a really good HU. Don't be afraid to spend in the 15k to 20k range, if you plan to set up a proper SQ system over time by adding an amp later, and then next an amp + sub combination after that.
For a 15k to 20k budget, you will get good Alpine/Blau/Kenwood/Pio HUs with 2+1 pre-outs (4V pre-outs I think) and enough additional features. You'll get better quality output from HUs in this range. Remember, the HU is something you're not likely to be able to upgrade later (without spending some serious money), so make sure you get a good one.
And, since you plan to go in for a sub+amp later, you will need to use only the stock speaker location in the rear. You won't really need 6x9s. A MDF plank (required for 6x9s) will give you trouble sooner or later. And, stock install = stealth install, which is a big plus. You can fit upto 6.5" speakers in the rear, with some mild adjustments. Same for the front. Make sure you get 6" or 6.5" woofers in front. Depending on the speaker, you can fit them (6 or 6.5") with just a little adjustment in the front (or without any at all).
You can actually save some money if you install co-axials in the rear. If you will be driving/sitting in the front seat most of the time, you really don't need comps in the rear.
And don't be afraid to spend some money on good cables if you're getting an amp installed (power & RCA). You'll keep enjoying the benefits for your future upgrades also.
I drive a Palio 1.2, BTW. <shameless self-promotion> Check out my ICE in my BHP garage. Just put it up today :-) </shameless self-promotion>
__________________
Alpine 9887 | TRU Tech S44 | Image Dynamics XS65 | Image Dynamics IDQ12 D2V2 | Connection Audison
hydrashok is online now   Reply With Quote
Old 11th October 2006, 21:11   #13 (permalink)
hydrashok's Avatar
Well, tubeless tyres a way more puncture resistant thatn tubed tyres. And even if you do get a puncture, you can generally keep driving for quite a while if you top-up the tyre pressure. So, a spare tyre may not be needed. And when you have extra space, you have to ICE it, right? :-)
__________________
Old 12th October 2006, 00:29   #14 (permalink)
Thanks Sir.. And enjoying the system very very much.
I had not heard before few days but i think you should have to listen Illusion.
BTW Illusion lm6.1 Comps are for approx 11K.
Cheers,
Mugen_Power.
Old 12th October 2006, 09:13   #15 (permalink)
airfoil's Avatar
Aah, that makes sense. I was thrown because I thought a tubeless spare wheel itself was recommended for a spare wheel well sub install.
Thread Tools
The *Active* ICE Discussion Thread MillionSwords Ask the Gurus 45 19th June 2008 14:25
The Top ICE Amplifiers Discussion Thread BHAGWAN Product Discussions 53 18th April 2008 13:41
Home Audio thread with inputs from the ICE forum gunbir Gadgets, Computers & Software 13 3rd August 2006 12:45
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
