Thread Tools
Old 8th October 2007, 19:26   #1 (permalink)
Su-47's Avatar
Default Now: Question about ICE
Guys,
I have this ICE on my Safari, and as expected I am dissatisfied with it:
HU: Pioneer 2950
Speakers: JBL 5-1/4” on the stock door locations.
Issue: No Bass, No mid-bass!
The reason because of which I ended up with this setup is:
  • Was out of cash after expensive Michelins and sun-film
  • Didn’t want to add any box like thing in the boot.
  • I thought I don’t need much bass, as I never switched on the sub at home. My HT amp driving the Polk-Audio bookshelf-speakers always seemed nice and sufficient. How wrong I was!
  • I had used 4”Front (JBL) + 6x9 (Sony) + Sony HU combo in my earlier car and that was pretty decent. I had hoped that this setup would sound similar.
So, can the gurus give me suggestions about how can I fix it? Please bear in mind, I just need a *bearable* system and I still don’t have all the cash in the world to spend:
  • Get rid of the speakers in the rear doors and add boxed 6x9s in the boot.
Speakers: GTO937 4900 + Box 900 + Install 700 = 6.5K
Will this make things better? Or, I would end up with a marginally improved system because the HU is too anemic to drive it? Any other speaker recommendations in 6x9 size?
  • Add an amp and a sub.
    • Any suggested configuration and estimates on how much would this set me back by?
    • Would this setup still lack mid-bass?
  • Throw away everything and start from scratch. What an idea, makes me cry!
  • Any other suggestions… Like some wonderful speakers that fit in the default location and still give good bass!
Thanks!
Su-47
__________________
Never wrestle with a pig, for if you do, you will both get dirty, but the pig will enjoy it - Charlie Munger
Su-47 is offline   Reply With Quote
Old 9th October 2007, 10:46   #2 (permalink)
navin's Avatar
Issue: No Bass, No mid-bass! [*]Add an amp and a sub.[list][*]Any suggested configuration and estimates on how much would this set me back by?
A the GT4-12 sub can now be had for 4K. Add a sony 552 or Blau GT2 amp for 3-4K and 1K for the box and you 8-9K with box you can have a boxed sub.
__________________
Scixelsyd Etinu
Old 10th October 2007, 23:12   #3 (permalink)
Do you need a sub? I was of the impression that you need better quality speakers.
BTW, for the first time I listned to JBL oval speakers (on a swift) GTO937 I think, they are simply EXCELLENT!! I would suggest that you replace your speakers with JBL ones.
But please be warned that I am a COMPLETE NEWBIE to ICE.
__________________
Proxima
2004 Safari LX
2008 Pulsar 180
Proxima is offline   Reply With Quote
Old 10th October 2007, 23:22   #4 (permalink)
blueraven316's Avatar
Putting 6X9s in boxes in the back is not such a good idea, the speakers especially JBL GTOs tend to boom a bit in a box, Now, I am not sure what kind of mids you are looking for.
Which JBL 5.25" Speakers do you have ? CS ? GTO ?
Component Speakers will produce better mids and more clarity paired up with an Amp. If on a budget a CS60.4 makes sense, if you can stretch a bit then 75.4 sounds much better.
Maybe you should look at a full change, maybe not, but no matter what happens the system has to be setup properly by someone who knows some tuning cos even the best stuff can sound bad when setup wrong, and even not so good stuff can sound good with a good amp and tune job.
blueraven316 is offline   Reply With Quote
Old 10th October 2007, 23:37   #5 (permalink)
nitrous's Avatar
He's already got JBLs ,man. He needs a pair of 6x9s , a good 12" sub and a packing amp with a sprinkling of raven-ish installation.
__________________
2004 2005 2006 2007 2008 - 5 consecutive titles.
Arguably,the best the sport has ever seen!
Old 11th October 2007, 17:41   #6 (permalink)
Su-47's Avatar
First, thanks to all you guys for your suggestions.
No boom for me please!
CS
Here is a visual illustration, of what I desire .
@#1#ImageShack - Hosting :: musicoh8.gif
A couple of more comments
- I do not want boom and it is prefectly ok if the system is not loud.
- Given the current state of my system, think I would need the cutoff freq of the woofer to be around 120-150Hz.
+ Do woofers have decent frequency response at higher frequencies like 150-200 Hz?
+ Do amps have the LPF setting programmable?
+ Also, is the loudness of woofer controllable?
The spec on my HU (Pio 2950) says it has only 1 preamp out (dont know if it means a LR pair, or just one output). Assuming, I am not pyschologically prepared for changing the HU, what shall I do:
a) Use a 2-channel amp: Use it in bridged mode to drive the woofer.
b) Use a 4-channel amp: 2-o/ps for rear speakers, and 2-bridged for the woofer.
What kind of a woofer would the gurus suggest for me?
__________________
Old 11th October 2007, 18:12   #7 (permalink)
tsk1979's Avatar
Just add 2 channel amp(2.5K) and a subwoofer(4.5K with box).
you will have enough boom.
If you go 4 channel amp way you can go for 2.5K coax in rear + small sub.
This will improve your bass and midrange.
__________________
Reclaiming.....!
Old 11th October 2007, 18:28   #8 (permalink)
anonymous's Avatar
How is this Pio 2950 HU?
I am planning to have 4 Channel Amp and Sub Woofer with this HU. The Woofer and rear Coax will be running from Amp and front Compos will get power from HU. Howss that?
anonymous is offline   Reply With Quote
Old 11th October 2007, 18:39   #9 (permalink)
FATAL3RROR's Avatar
hello anonymous!
As most gurus would suggest, power your front comps and the sub (in bridged mode) from the 4ch amp and let the HU take care of the rear coaxes.
FATAL3RROR is online now   Reply With Quote
Old 11th October 2007, 19:25   #10 (permalink)
Su-47's Avatar
Tsk, which 2-channel amp is available at such wonderful price?
And, what do you mean by a small sub? How small is small?
I will get to know how good it is in a while (once I am done with the next step..?)
__________________
Old 11th October 2007, 22:58   #11 (permalink)
Su-47's Avatar
Navin had mentioned about Sony 552, but on the Sony site I also see these two new amps. Any ideas how are these?
Sony India : XM-ZR604 (XMZR604) : Details
Sony India : XM-ZR602 (XMZR602) : Details
Would these be a good match for:
http://www.team-bhp.com/forum/produc...tml#post588270 (JBL GT5 Series)
What are the pros and cons of a sealed box vis. a vis ported one?
Last question: where to go for an install? And, Grey Vs. B&W?
Cheers,
Su-47
__________________
Old 11th October 2007, 23:54   #12 (permalink)
Cheers,
Su-47
Well I would not pair a Sony amp with a JBL sub, as it will be wasting the JBL sub. If you are on a budget you can look into a JBL CS60.2 to run a JBL sub, will sound decent enough. This I am suggesting because you will get bugged with the sony soon, and espeically when you are on TBHP don't make the decision of buying a Sony Amp with a JBL sub.
There are no cons of having a sealed enclosure, except for it cannot get as loud as a ported enclosure, but it has a lot to do with what kind of sound you prefer. Since you are against BOOM, then sealed should be a good option for you. In Sealed too you can make the response change with enclosure size/volume.
When it comes to Speakers/Subs always buy with someone who offers genuine replacement warranty. Amps you can risk grey as almost all parts are available for a repair and they dont cost a fortune (at least for me).
Old 12th October 2007, 09:23   #13 (permalink)
tsk1979's Avatar
Well there are a few available. Sony(cough cough!)
By small I mean 10"
__________________
Reclaiming.....!
Old 12th October 2007, 12:13   #14 (permalink)
navin's Avatar
Navin had mentioned about Sony 552, but on the Sony site I also see these two new amps. Sony India : XM-ZR602 (XMZR602) : Details
1. I have not seen the 602 in the market but I my knowledge is not current. maybe the 602 has replaced the 552. BTW JBL's new GT5 amps might be in the same price range as the 602.
2. it will drive a 12" sub well. It does put out about 100W when bridged
3. sealed boxes have less boom but require more power, ported boxes require less power (to achieve the smae SPL) but can BOOM.
The Sony 602 and the JBL 60.2 put out about the same power. They will dive the sub equally well. For full range speakers the 60.2 mightbe a nicer choice though.
__________________
Scixelsyd Etinu
Old 12th October 2007, 22:48   #15 (permalink)
Sir I don't think the 300W Sony 2 Channel amp we have been seeing till now will drive a sub as well as the JBL 60.2 as it has a flat LPF switch limiting the way it can be tuned which is not the case on the JBL,
However I have not used the new XM-ZR602 amp, so cannot really say how good or bad it is.
Thread Tools
Suspension setup Safari Dicor 3ltr v/s 2.2 ltr PAVAN KADAM Technical Stuff 13 13th May 2008 14:49
ICE Setup for Safari drifter Ask the Gurus 64 3rd December 2007 12:36
Elantra ICE Setup 1self Sound Off and Show Off 78 19th October 2007 02:59
ICE Setup for Swift prashant.dinkar Ask the Gurus 5 11th October 2007 13:20
ICE setup minus the HU ! jkdas Ask the Gurus 16 28th December 2006 10:48
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
