Thread Tools
Old 10th October 2007, 19:37   #1 (permalink)
gigatech2006's Avatar
Default Sound Enhancement - Please advice
I've installed Pioneer headset 2950, a pair of oval speakers (Pioneer) at the rear with padding, and a pair of round speakers at the frost (door insets). Though the audio quality is good, I feel like most of the sound is from the rear ones (though the front ones are working 100% and output low freq tones). Should I install tweeters in the front to overcome this issue? Pls advice. I've found those tweeters in most of my friends' cars, and in my opinion they look kind of weird perched on either side of the dashboard. Is there any work around for this?
I've another problem with the rear-left oval speaker. Sometimes, the volume goes really low and I could hear noise from it. This problem is hard to diagnose as this happens only occasionally-and when this happens tis highly irritating. I checked the wires and they are well connected. What would be the problem?
Thanks in advance!
Giga
__________________
Hyundai Accent GLE 2007
gigatech2006 is offline   Reply With Quote
Old 11th October 2007, 01:06   #2 (permalink)
DerAlte's Avatar
Pound for pound, ovals do sound 'louder' than the circular ones (they manage to push more air).
What is the model of speakers that you have mounted in the front? A Pio would not be *that* bad that you would want to add a tweeter.
One way to get a temporary correction would be to set the Fader to F2 or F3 - that would make the front slightly louder.
Real good sound can come in the front only if you change the front circular (most likely coaxials) to COMPONENT speakers, such as from JBL, Infinity, Blaupunkt, Illusion, Hertz etc. Components are most commonly a mid-bass speaker and a tweeter. The sound that you would hear from components - even the economical variety from JBL or Blaupunkt - would be definitely better than from the current Pio coaxes.
No, tweeters don't look that odd if they are discretely mounted, for example on the door itself. If on the A pillar, you can always (well, almost) have the tweeter housing painted to match the A pillar plastic. If you have electrical ORVMs, the logical place is inside of the mirror mount.
Most likely the connection to the rear left oval is loose at the HU end - difficult to check unless you take the HU out.
__________________
Never believe it cannot be done - it's only that you haven't found out how!!!
Old 11th October 2007, 18:51   #3 (permalink)
Me too was facing this problem of volume going low from front left and sometimes both the front speakers. Got the entire speaker wiring re-done with better quality cables in place of the old stock ones. Now it's working perfectly OK.
And I too was thinking of adding tweeters (Sony GT-560 with JBL CS-2104 and GTO-937).
What say? Will it enhance the soundstage?
anuragn is offline   Reply With Quote
Old 11th October 2007, 20:57   #4 (permalink)
DerAlte's Avatar
Well... yes and no! It depends on what you have currently.
If you already have a coax in front, adding tweeters may cause chaos and/or harshness (depending on which tweeters you add).
It is always recommended that one replaces front coax with components - midbass + tweeters - so that imaging appears uniformly. Components are not always a costly proposition - the improvement over coax (or coax + tweeter) is significant.
__________________
Old 12th October 2007, 11:31   #5 (permalink)
navin's Avatar
there is no need to. why do you feel the need for tweeters?
you can fade to the front. addind tweeters is not usually a nice solution.
if you have checked all the wires (the best way is to run a sperate wire and see if the problem goes away) then get teh HU checked. maybe the chip-amp in the HU is having a problem.
__________________
Scixelsyd Etinu
Old 12th October 2007, 13:40   #6 (permalink)
Thanks Navinji. I have 4" coax's in the front, mounted in the dashboard facing upwards (stock location in Wagon-R). And the sound comes after reflecting from the windscreen. Hence, I thought tweeters facing directly towards the passengers might help a bit.
By the way, how much would 4" JBL components cost?
Old 12th October 2007, 13:54   #7 (permalink)
Sam Kapasi's Avatar
You don't get JBL 4" components. In that category the options are Kicker and Illusion.
The Illusion are superior by far.
__________________
Live the YetiLife®
Thread Tools
Need advice - Thud Sound while taking IKon out from Parking FlairBoy Technical Stuff 4 9th July 2007 12:01
Sound Advice For Santro kamikaze_713 Ask the Gurus 79 29th May 2007 13:39
Sound Advice needed for 2 Cars.. A Palio and an Accent.. Ad1tya Ask the Gurus 10 4th May 2007 13:44
Performance enhancement..? girlieonwheels Technical Stuff 35 10th June 2006 23:49
Any suggestions on performance enhancement of the Tata Indigo? maxim_mumo Modifications & Accessories 2 20th January 2006 12:50
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
