Thread Tools
Old 31st October 2007, 16:34   #76 (permalink)
determinus's Avatar
Originally Posted by moralfibre View Post
Ajay, I found out a guy who can make inductors here in Pune. Can you further guide on what I need to ask him to make? I have a pair of Illusion EL 6.1 set XO's lying with me. We could put them to use?
Why do you want to make inductors (unless that is the DIY project)? You get established xo designs - with certain limitations as gurus will tell you - on the net. All you need is to buy components from one of those bowels (*peth) of Pune and you can get going.
Originally Posted by Sam Kapasi View Post
You got that X2 for Rs. 5000/- only!!?? That's a great price!
Great? That's a whole-lot-of-unprintable-get-banned-from-forum-adjectives price!
Related query: Is an open box (claimed brand new) SRX1 worth 200 USD? What is the price of a new one here? That price seems too low to be true (just like in this case). Any comments?
__________________
"Reality continues to ruin my life"
determinus is offline   Reply With Quote
Old 31st October 2007, 16:46   #77 (permalink)
moralfibre's Avatar
MF, you want me to create a new thread in the DIY section by that name? I thought any member can do that. you dont need to be a Mod to create a thread.
I wanted you to create a thread because it would be easier for you to move the relevant posts from this thread to the new one.
before you go making inductors I suggest you download Clio, Calsod, or LSpCad Lite, etc.. and simulate the existing EL 6.1 XO. The EL 6.1 XO is designed specifically for the drivers (all speaker companies do this). It takes into consideration the frequency response, power handling, excursion capabilities and other driver specifications.
Are the softwares listed above, open source or do I need to purchase licenses for these?
What these XO do not (and cannot) take into complete consideration is listener preference, driver installtion, etc..
Once you modelled the existing XO you can then tinker with the components and see what the change in each component does to teh phase, freq and power respone of the individal drivers and the system as a whole. It is not that tough, this post makes it look tougher than it is.
Latin for now. Will see how it goes.
What you need to keep in mind
1. tweeters are fragile. their excusion limits can be easily exceeded and you can blow them that way. Their thermal limits aare better but alos limited.
2. midranges and midwoofers ofnte have break up modes in th upper midrange. this is more common for the "exotic" stiff matierals such as kevlar, aluminum, carbon fiber etc..
3. phase response is critical. Try to keep phase within 45 deg. This is TOUGHER than it looks.
I shall keep this in mind Navin.
Its a DIY project buddy .
If you saw this at Poona motors then it belongs to fellow member Vikram_18. If you are interested in a SRX1 (to store in your cupboard) then you can contact Vikram. Otherwise put the CS60.4 I sourced for you to good use
__________________
"As long as there are short, balding, middle-aged men, there will always be a market
for the Porsche 911." - A BMW Owner. :)
Old 1st November 2007, 13:21   #78 (permalink)
determinus's Avatar
Vikram who switched to Genesis, right? I thought he had SX4 and a GTO mono. But if he is selling, esp at "nice" prices, I am interested You can always find a car to plug them in.
__________________
Old 1st November 2007, 13:30   #79 (permalink)
moralfibre's Avatar
He is selling both. I stand corrected. It is an SRx4 and a GTO 301.1. PM him.
__________________
Old 2nd November 2007, 11:32   #80 (permalink)
navin's Avatar
they have free and paid versions. the free versions are crippled but will do for now.
__________________
Scixelsyd Etinu
Old 3rd November 2007, 22:42   #81 (permalink)
shrivz's Avatar
He could also consider the SRx5
50/75x4 @4/2ohms + 180x1 @4ohms
It has a Multichannel option to run 3-way components
The front channel drives the 4" mid-range + tweeter, which is connected to the X-over supplied by the speaker manufacturer.
The rear channel drives the woofer, and the X-over point for this can be adjusted between 50 ~ 400Hz, so the rear channel is basically a bandpass with a fixed 12db slope.
The sub channel drives the subwoofer, again its X-over point can be adjusted between 50 ~ 220Hz with a fixed 12db slope!
__________________
Technical skill is the master of complexity, while creativity is the master of simplicity...
shrivz is offline   Reply With Quote
Old 3rd November 2007, 22:46   #82 (permalink)
can someone please suggest if and how i can fit in this HU
Kenwood DDX7039M
brett is offline   Reply With Quote
Old 5th November 2007, 14:32   #83 (permalink)
navin's Avatar
Kenwood DDX7039M
bret, i am sorry i could not respond to your PM. I was a bit busy. have not slept much.
the 7039 is a Dual DIN HU and should fit into a Laura but will occupy both slots. I have not seen the Laura dash but my Octy's dash can take a double DIN HU and I assume your Laura is similar.
PM Gunbir or Bass & Trouble has they have worked on a Laura and he will/should know. after the last fiasco they will also be a bit more careful in double checking the details bfore replying! :-) ha ha.
__________________
Scixelsyd Etinu
Thread Tools
HELP: What ICE setup for fabia elegance for Rs.50k Invinsible Ask the Gurus 57 30th June 2008 15:46
Optra Magnum diesel LT or Laura Elegance ?need help anant.arora Sedans 74 31st October 2007 15:51
Facelifted Octy, Cheaper Laura EDIT : Laura Elegance ajmat The Indian Car Scene!! 139 27th August 2007 11:47
embera crdi or skoda laura elegance bajwasingh Sedans 16 6th June 2007 13:07
Honda Accord ML vs Laura Elegance autozoniac Luxury, Imports & Niche 28 2nd April 2007 15:59
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
