| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #1 (permalink) |
| Newbie Join Date: Oct 2007 Location: Mumbai
| Hi. I would appreciate help on selecting speakers (rear, front door and/or dashboard) for my Indica XETA. I have a HU with the following specifications. Sony MEX 1GP: Overall Max Frequency Response: 20 kHz Overall Min Frequency Response: 10 Hz Signal To Noise Ratio: 120 dB Maximum Power Output: 52 W/channel RMS Power Output: 17 W/channel There are two sets of 4-volt pre-amp outputs that are selectable between the rear channels or a subwoofer. When a subwoofer is selected, a crossover and independent volume control are activated. I do not intend to go in for a subwoofer at this point in time, maybe later. The budget is around 10k and can be stretched to 15k. I have the following questions: 1. What would be good combination for speakers. If I go in for 6x9 oval spearkers in the rear, will it be a good idea to have door or dashboard speakers in the front ? 2. Will Blaupunkt (Blaupunkt THX 693 speakers) or JBL (JBL Car & Marine Audio) or Pioneer(5 way) be good ? (with around 70 to 100 RMS for the rear speaker). 3. Will my Sony HU support front speakers (40RMS * 2) and rear speakers (70-100 RMS * 2) or will I need to add an AMP. I am not planning to have a separate sub. 4. Do I go in for comp speakers in the front (in that case do I need an amp) 5. Please suggest a setup with model nos and price if poss. 6. Can someone also suggest a place near Andheri/Bandra (Mumbai) where I could get a good demo of the above mentioned brands. Thanks. AAD |
| | #2 (permalink) |
| BHPian Join Date: Sep 2007 Location: Bangalore
| Please refer to this thread http://www.team-bhp.com/forum/ask-gu...dica-xeta.html (Music System for Indica XETA) |
| | #3 (permalink) | |||||
| Senior - BHPian Join Date: Mar 2006 Location: Bombay
| Quote:
__________________ Operator! Give me the number for 911! | |||||
| | #4 (permalink) |
| Thanks for the suggestions. A few more questions please. Q1. With reference to the 6x9, these are the specs of the recommended two: a. Blaupunkt THx 693 Max. power 280 watts Nominal power 70 watts Frequency response 40 Hz - 22,000Hz (Better?) Sensitivity 93 dB Nominal impedance 4 ohms b. JBL GTO937Power Handling, RMS100 Watts (Better?)Power Handling, Peak300 Watts Frequency Response (±3dB)50Hz-21,000HzSensitivity94dBImpedance2 Ohms My understanding is that the watts of JBL is better whereas the Frequency response of Blau is better. Just to understand a bit better, how much would the difference in Frequency Reponse affect. Also out of Sensitivity/Impedance which is better technically and how much would these 2 parameters affect. Q2. Can you pls recommend whether to have dash or door speakers for front and the brand and approx price for that. Also whether to go in for coaxial or component ? Q3. Can you pls recommend an amp (brand and price) and would having an amp make a big difference to sound quality ? Would an amp be like mandatory for comp spk and optional for coaxial spk ? |
| | #5 (permalink) | |
| Senior - BHPian | Quote:
![]() Q2. Not sure about the Indica dash speaker size - but you could do with a 4" component (Illusion 4.1) or you could opt for better midbass by installing a 5 1/4" or 6 1/2" in the doors. In the larger segment, you would have a lot of options like Illusion, Hertz, JBL, etc. Q3. Your first part of the question - the JBL amplifiers are recommended for VFM. You may try the GT5 series or you can get the more expensive GTO series. The prices would be about 7.5k and 12k respectively (approx). The second part - it is not absolutely necessary, but good speakers, whether components or co-axials, sound way better with an amplifier. | |
| | #6 (permalink) |
| Newbie Join Date: Jul 2007 Location: san jose
| Since indica xeta is a hatch back please do not install the 6x9 speakers at the rear. also since you are planning a subwoofer later avoid the 6x9 at the rear. the 6x9's generally need a good enclosure to produce good bass. |
| | #8 (permalink) | |
It is generally recommended where subwoofer cannot be accommodated due to budget/space constraints - nothing in particular to do with the size of the car. However, it would reduce the height of bootspace available in a hatch because of the tray.
__________________ ... Everything should be made as simple as possible, but not simpler | |
| | #9 (permalink) | |||
| Team-BHP Support ![]() Join Date: Mar 2004 Location: mumbai
| Quote:
Now getting back on topic... If you are not getting a sub 6x9 will offer you a more balanced sound as they will provide more bass. You will need to change the rear deckt o one made of MDF and the hatch might not be able to lift this deck but the original fiber deck will resonate like crazy if used. Remember that adding 2 6x9 and a MDF board instead of the existing rear deck makes it heavy but it offers the 6x9 a solid platform. In general 2-3 way speakers sound better than 4-5 way speakers, atleast to my tired ears. Do not worry abot power handling or number of "ways". It is only about the music. Get the HU and 4 speakers as suggested by B&T. B&T also represents Illusion and hence cannot recommend them but I can! :-) I am not sure if Illusion Electra (the cheapest Illusion seris) will fit in your price range though. They are worth a listen. Once you get the HU + 4 speakers see if you are pushing your HU past's it's half way mark if so then get an amp. If not then you are doing fine. Blaupunkt makes a good at called the GT4 for about 7K. Pio's 6300, Kenwoods 8401, JBL's GT5 are other alternates. I heard 2 of them, the 8401 seems to work harder but the GT4 sounds smoother to me.
__________________ Scixelsyd Etinu | |||
| | #10 (permalink) | |
| Quote:
But I'll let you take a shot at what 2007 must probably stand for. ![]()
| | #11 (permalink) | |
| BHPian Join Date: Feb 2007 Location: Kolkata
| Quote:
__________________ Every man has his follies. And often they are the most interesting things he has! | |
| Thread Tools | |
Similar Threads | ||||
| Car Audio Advice from the Audio Gurus: Use "Search thread" before posting a new Q! | Sam Kapasi | Ask the Gurus | 8960 | 18th November 2008 22:24 |
| Indica Xeta - First Experience-How Xeta won the race | nirmalkumar | Test-Drives & Initial Ownership Reports | 12 | 20th April 2008 17:41 |
| indica xeta, is the car reliable? | dr_aryan | Hatchbacks | 56 | 4th November 2007 11:44 |
| Suggest me ::audio system:: for Indica xeta | abhee | Ask the Gurus | 9 | 4th May 2006 09:12 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
