| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #1 (permalink) |
| Newbie Join Date: May 2007 Location: Indore
| Would it be a good idea to replace JBL my-T1 tweeter with infinity tweeter. the tweeters of 607c are very bright even when the equlaizer curve is set for a very low level for high frequncies. Are inifnity tweeters available in india?
__________________ Swift Vxi ,GTO 75.4, CS1204B, GTO607, GTO937, Pioneer 7950UB |
| | #3 (permalink) |
| BHPian | my two bits: components are matched for a particular crossover frequency, the infinity tweeters go down to lower frequecies (~2KHz) compared to the JBLs, so they give more depth in the sound. You would intend to replace your crossovers now, but then, what about timbre matching? Ideally, try tuning the setup, I've found the JBLs to give a peak at about 8KHz, so if you have a Parametric EQ, cut down the 8KHz band, it should help. And one more thing, are the tweeters firing towards the windshield? If they are, try lifting them up (firing towards you) it should help, it helped a lot in my case, thanks to evo6! If you can, try placing the tweeters on the door panel! EDIT: just saw your signature stating that you have a 7950, I think it has a Parametric EQ, read the manual, and you will understand how it works. Set the freq to 8KHz and start of with a 2N (narrow band) and then slowly step up to 1N, 1W and 2W, listen and decide what suits you the best! If you still find it shrill, its time to upgrade your HU mate! ![]()
__________________ Technical skill is the master of complexity, while creativity is the master of simplicity... Last edited by shrivz : 30th October 2007 at 22:21. |
| | #4 (permalink) |
| BHPian | The basic difference in JBL and infinity is the material of the tweeter. JBL are Aluminium dome. They are good if you listen more to techno, Metal, hard rock. They have a kind of sharp and loud. Its for loud music Infinity is silk dome. Those are made up of silk cloth. They are good for listening more of trans, gazal, pop, and soft rock. You can adjust the EQ as well as crossover to make them sound good. These are for crisp lyrics.
__________________ Firebird _________________ Matiz SG - 2000 Sold Palio 1.6 Sport-2006 TEAM-BHP LEAGUE OF ORDINARY PEOPLE WITH EXTRAORDINARY RIDES |
| | #5 (permalink) | ||
| Senior - BHPian Join Date: Mar 2006 Location: Bombay
| Quote:
I doubt the Infinity tweeter would play lower than the JBL or anything since it is not a Low Fs tweeter. A better quality tweeter it certainly must be. Baaki, I think the swap will almost certainly improve the sound. Quote:
__________________ Operator! Give me the number for 911! | ||
| | #6 (permalink) | |
| Distinguished - BHPian ![]() | The word you seek is My-Ti, not my-T1. The JBL tweeters are made of a composite of Mylar and Titanium. Hence My-Ti. Not Aluminium. Quote:
__________________ Live the YetiLife® | |
| | #7 (permalink) |
| BHPian | ohh my-T1...Yes they are tinatium. About the silk dome, yes I have compared the sound from Aluminium and Silk dome. The silk dome is soothing and aluminium dome is harsh. So IMHO it matter although depends on the individual also. I selected infinity for the silk dome tweeters.
| | #8 (permalink) | ||
| Distinguished - BHPian ![]() | Quote:
On the infinity the crossover can be adjusted to 0dB and +3dB. The same arrangement is there on the JBL GTO crossover as well. P.S. It is not my-T1 it is My-Ti Mylar-Titanium
__________________ Live the YetiLife® Last edited by Sam Kapasi : 31st October 2007 at 00:34. | ||
| | #9 (permalink) |
| BHPian | Yes sir got it. Its "Ti" But somehow, when I tried listening to soft music it looses charm on aluminium, may be resonense in some frequencies due to some properties of aluminium (just a wild guess). I failed to understand the significance of Titanium in speaker cone or tweeter construction. Is it some marketing stuff. Titanium is for reducing weight .The basic thing remains is the Metal and cloth material.
| | #10 (permalink) | |
If I look, I should be able to find Dr. Floyd Toole's paper on this. If I find it I'll post it here.
| | #11 (permalink) | |
| BHPian | Quote:
I am not in any different league sir Timbre matching is required, I feel so since I've seen the difference with it, again, it could be just me! but I still stand by my philosophy: Stick to the same brand, and if possible, the same series in that brand! ![]()
__________________ Technical skill is the master of complexity, while creativity is the master of simplicity... Last edited by shrivz : 31st October 2007 at 01:30. | |
| | #12 (permalink) |
| BHPian | A little googling, and I stand corrected!!! http://caraudiosecurity.com/shop/pro...s_id/2419.html V/S http://caraudiosecurity.com/shop/pro...s_id/4306.html The JBLs have a freq response from 2.5KHz The Infinities however have a freq response from 3.5KHz ohh well, It was the other way round! somebody please whack me for posting incorrect data! ![]()
__________________ Technical skill is the master of complexity, while creativity is the master of simplicity... |
| | #14 (permalink) |
| Team-BHP Support ![]() Join Date: Mar 2004 Location: mumbai
| why not try relocating the tweeter? if you are somewhat handy with a sodleing iron you could pad the tweeter a bit too. It is not diffcult. you just need some nice 10W resistors.
__________________ Scixelsyd Etinu |
| | #15 (permalink) |
| Senior - BHPian | You could try the Illusion Audio tweeter that comes with the EL series of components as well the co-axial systems they sell. The tweeter has a flat response and gives out a lot of detail compared to the Infinity I used. This should work with the existing JBL XO you have. Try it out and let us know the results. I have a pair lying with me which I will test using the JBL XO's in Shrivz's car.
__________________ "As long as there are short, balding, middle-aged men, there will always be a market for the Porsche 911." - A BMW Owner. :) |
| Thread Tools | |
Similar Threads | ||||
| GTO 608c Tweeter Terminals | vrrraju | Ask the Gurus | 10 | 2nd September 2008 01:26 |
| Tweeter Mounting Position - Rear Door Component ? | BHAGWAN | Ask the Gurus | 2 | 23rd June 2008 12:23 |
| tweeter advice | shrayv | Ask the Gurus | 68 | 2nd July 2007 14:32 |
| immediate sale amp,tweeter,sub,spkr | clipto333 | Shifting gears | 1 | 8th February 2007 04:55 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
