Thread Tools
Old 31st October 2007, 17:10   #1 (permalink)
Question Need advice on woofer for my Swift
Hi Gurus,
This is my first post on team-bhp!
I have a maruti swift zxi - petrol version.
My music system specs:
Pioneer DEH 5850
I have installed 4 x6" Coustic US CX603 speakers on the front and rear doors.
Specs for the speakers are mentione below:
Tweeter: 6-1/2" Triaxial-Poly Woofer, 13mm Tweeter, Piezo Super Tweeter Power Handling: 50W RMS/150W Max Power
Sensitivity (1W/1m): 88.0dB
Frequency Response: 70Hz to 20kHz (±3dB)
I have been having this for an year now. Now, i want to add an sub-woofer to my car. I know this will eat up a lot of space now.
Also, my knowledge on this area in very minimal.
My qstns:
1. Does this model (head unit) have an in-built amp? should i definitely buy an amplifier?
2. Should i go in for a box or tube - type sub-woofers? which would be better both in terms of sound quality and saving space?
3. what options do i have for both amp and sub-woofers?
4. I'm in pune. what dealers can i get in touch with?
5. I'm a guy who listens to thumping bass - mainly hip hop and pop music. what models and specs should i go for?
6. the dealer next to my house was recommending to go for JBL and my collegue recommends sumokoo...
i know my qstns show my knowledge is poor in this. however, would appreciate your views and advice.
Venkatesh
venkateshs is offline   Reply With Quote
Old 1st November 2007, 12:07   #2 (permalink)
navin's Avatar
Originally Posted by venkateshs View Post
Pioneer DEH 5850
all HUs have amps, if you find your self pushing the HU past it's half way mark get an amp for the 4 speakers. you will need an amp for the sub too. However some 4 ch. amps are power ful enough to drive a sub when 2 of their channels are bridged, by using such an amp and using the Hu to drive the rear speakers only you can save part of the cost of the subwoofer amp.
since you like BOOM get a tube sub. Most people here would recommend JBL over Sumokoo. I have heard Sumokoo a few times and have NOT been impressed. I sure hope their products have improved.
BTW what is your budget?
__________________
Scixelsyd Etinu
Old 2nd November 2007, 11:35   #3 (permalink)
Thanks for the comments. BTW, my budget is 10k.
Old 2nd November 2007, 12:39   #4 (permalink)
navin's Avatar
spend half on a HU like a Pio 2950 or Blau Mumbai, and half on speakers like the JBL GT5 series or Blau GT series.
__________________
Scixelsyd Etinu
Old 2nd November 2007, 13:55   #5 (permalink)
kumar_ranjan's Avatar
I think this is your budget for Subs + Amps, Right? You can look at the Blau Bass tube GTT 300 + GTA 2 Channel Amp (GTA 275 or GTA 280).
__________________
No GOD no PEACE, know GOD know PEACE
kumar_ranjan is offline   Reply With Quote
Old 2nd November 2007, 14:02   #6 (permalink)
montyguru's Avatar
Cool soomoku and more.
for completing an existing set-up, nothing beats soomoku in sheer value. (for hatches, in space too).
at around 10k, you would get:
option 1.
a 100w RMS mono-block amplifier (with lpf, gain and phase control)
a 10" subwoofer
a factory sealed ported enclosure
a wired remote on your dash
(all of this in one compact box that can be moved around in your boot)
option 2
same setup with two 8" woofers - if you are looking for 'loud' bass.
(this takes more space)
option 3
save money. get the 8" pre-amplified box, saves space and is more than enough to complete your 50w coustic 4 speaker set-up. retails for Rs. 7500, may be less for you ;-).
you can use your speakers outs to drive the amp, with no need to change your head unit.
jbl also has one such product which has probably been discontinued i guess.
JBL Car & Marine Audio
MRP in India is Rs. 12,500, but not available, probably around Rs. 8,000 in grey, this has a quad voice coil and a 4-channel amp.
pioneer and alpine too have similar products which you can check at pioneer electronics europe website or alpine website in pre-amplified subs. these products simply complement 4 speaker factory set-ups and are not for loud or thumping bass. any of these should be as fine i guess.
montyguru is offline   Reply With Quote
Old 2nd November 2007, 14:49   #7 (permalink)
you might have to spend some amount on the wiring also... 2 to 3K
Krato is offline   Reply With Quote
Old 2nd November 2007, 15:19   #8 (permalink)
Technocrat's Avatar
Venkatesh Most have been said. I will just list down what you need:
If you want to add just a subwoofer & are fine with the output from speakers at slightly higher volume(read more than 50% Volume) You need:
- Two channel amp
- A sub
If you want to sub as well as more sound read that as good clarity at higher volume the you need:
- A four channel amp
- A sub
Normally A Sony is no no but on a tight budget the amp & sub are fine if not good as its cheaper than most other brands with B/W
There are lots of people with varied ICE setups in Pune. We can have an ICE meet so that you can personally listen to various options for type & brand of Subs & amps
p.s. I think I will get killed for suggesting a Sony
__________________
The Holy Trinity: Traction, Torque and Tarmac
Old 2nd November 2007, 15:29   #9 (permalink)
Thanks for the replies guys.
Just to clarify:
I have already spent 14k on the HU and the 4x6" speakers on the doors last year.
All i want now is 1 x 12" sub-woofer tube type as i want high bass and an amplifier. For these I have a budget of around 10k.
I would serioulsy like to have a look at the systems that Pune BHPians have in their cars if we could have a meet this weekend...
My number is 98810 69630.
Venkatesh
Old 2nd November 2007, 18:42   #10 (permalink)
I have finalized CS1204T as the subwoofer. Could you pls give me options for the 4 channel amp?
i can sqeeze in about 12k (amp+sub)...please let me know the amp options that I have with Blaupunkt, JBL and Pioneer?
Also, how are Coustic and MTX amps?
Old 2nd November 2007, 19:41   #11 (permalink)
navin's Avatar
7K for amp (4 options - Pio, JBL, Kenwood, Blau) and 5K for sub (2 options Pio, JBL).
__________________
Scixelsyd Etinu
Old 5th November 2007, 11:14   #12 (permalink)
Hi All,
I have finally ICE-d by Swift.
have installed JBL CS 60.4 amp and a GT4-12 sub in a box. Thanks for all the sugesstions and support from all the BHP-ians.
Old 5th November 2007, 13:29   #13 (permalink)
Hi All,
Congratulations on your install.
Enjoy the music and drive safely.
Old 5th November 2007, 13:54   #14 (permalink)
Technocrat's Avatar
Congrats Venkatesh for the upgrade, Hope you are enjoying it
Are you powering the front comps with amp now ?
__________________
Old 5th November 2007, 15:15   #15 (permalink)
moralfibre's Avatar
He doesn't have comps in the car at all. He has 4 x 6" co-axials running off the HU. IIRC he bought a JBL CS 60.4 for Rs. 5,500/- and a CS1204? sub in a sealed box for around 3k? Now he is running the front co-axials off two channels of the amp and the other two are bridged to drive the sub.
__________________
"As long as there are short, balding, middle-aged men, there will always be a market
for the Porsche 911." - A BMW Owner. :)
Thread Tools
Need advice on selling my Swift LXi saravanan2603 Hatchbacks 6 20th June 2008 00:07
Between the Swift and the Baleno! Advice please shanx Hatchbacks 8 5th August 2006 13:59
woofer in tray of swift 200mph Ask the Gurus 16 2nd July 2006 01:57
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
