Thread Tools
Old 9th November 2007, 12:45   #1 (permalink)
Default Amplifier rating Vs Speaker rating
Hi all,
First up wish you all a very happy Diwali.
I have a query regarding Amplifier wattage and speaker wattage.
My question is, is there any thumb rule in the selecting amplifier wattage w.r.t. speaker wattage?
For eg, if I use a 75 Watts amplifier, will it sound good on a 70/75 watts speaker or a higher wattage speaker (say 120 watts), assuming other things unchanged?
The reason why I am asking this is that the Blaupunkt dealer in Pune has told me that the speaker ratings should be preferrably 20% higher than the amplifier rating. I am not sure about this.
Your thoughts?
Mods, sorry if this has been discussed before. I could not find any post on this subject.
TIA
CaAT is offline   Reply With Quote
Old 10th November 2007, 01:16   #2 (permalink)
rocksterraghu's Avatar
All I know is that it is enough to keep them close - unless you want to pump the hell out of them. A little higher rated amplifier over speaker is fine, but I don't know about this 20% funda.
__________________
Everything should be made as simple as possible, but not simpler
Old 10th November 2007, 01:19   #3 (permalink)
low_bass_makker's Avatar
I would consider the reverse a 80 watts speaker connected to a 100 watts amp as the amp if rated at 100 watts will play clean at 80 watts and without any clipping.
Old 10th November 2007, 10:21   #4 (permalink)
panky12345's Avatar
Infractions: 0/1 (4)
idea is to feed the driver atleast 70-75% of its RMS wattage to make it run OK, but overpowering it to certain extent in controlled way would give more headroom.
__________________
SINGH IS KINNNNNNNG..
Old 10th November 2007, 11:24   #5 (permalink)
Autophile's Avatar
Headroom is a term associated with the amplifiers not the speakers.
How can you overpower a speaker in a controlled manner?
__________________
Danes Don't Lie !
Autophile is offline   Reply With Quote
Old 10th November 2007, 11:40   #6 (permalink)
gunbir's Avatar
CaAT, Happy Diwali to you too!
There is no simple answer to this. Some manufacturers underrate their speakers, some overrate. Some amps are underrated, most overrated. Then some speakers are more power hungry than others, while others need less power to get just as loud.
Also, keep in mind that music is dynamic, not static like a tone. It has dips and peaks and the demand on the amp is variating. Your speakers also get power in bursts, depends on the kind of music you listen to. A quality speaker that is rated for 100w RMS can take more power on music. Its nice to have a more powerful amp as there are times when a passage in your music may demand more power for a few seconds to deliver the dynamics the music demands.
End of the day, the simple answer is that if you set your gains right and theres no clipping, you can get away with even more than twice the rated power of the speaker. But you have to know your equipment and treat it with respect. So 20-25% more power is usually not an issue if the speaker is rated properly.
__________________
Often imitated, never duplicated!
gunbir is online now   Reply With Quote
Old 10th November 2007, 12:09   #7 (permalink)
panky12345's Avatar
arre JB bhai, what i exactly meant was speaker would play cleaner with less effort - (hence the "headroom") if the gains, BB and other settings are set properly on the amp considering the speaker in question. (hence the controlled way).
__________________
Old 10th November 2007, 12:21   #8 (permalink)
I dont agree.
Headroom - Wikipedia, the free encyclopedia
Old 10th November 2007, 12:26   #9 (permalink)
panky12345's Avatar
Thanks LBM..............
__________________
Old 10th November 2007, 13:09   #10 (permalink)
jerish666's Avatar
I have question.I have Alpine R series compos 4 pairs front and rear driving the a 4 channel blaupunkt 440watts amp.But when i increase the volume speakers are jarring .Alpine R series compos is 70watt.Why it is like that?Can anyone help me?
jerish666 is online now   Reply With Quote
Old 10th November 2007, 13:24   #11 (permalink)
Autophile's Avatar
LBM,
Headroom is provided by the amplifier not by the speaker. So called speaker headroom is heaviliy dependent on the amplifier it is partnered with and bandwidth.
Without getting into bookish arguement let me tell you that a speaker will stay clean till the time it is not reached to its motor limits. A crappy 50 Watts amplifier can drive a speaker to its mechanical limits where as same speaker will play clean on a well designed 100Watts amplifier.
Same way as advanced transmission and differential is useless without a powerful engine.
Panky, you forgot the most important controlling factor - crossovers.
Also any set of drivers will play much cleaner on a powerful amplifier in an active setup than passive because of the limitation of passive network components. Power handling is also highly dependent on the crossover slopes.
__________________
Danes Don't Lie !
Old 10th November 2007, 20:56   #12 (permalink)
TIA
20% is just a safe margin. It's like marking the REDLINE at a LESSER rpm than the ACTUAL LIMIT.
Basically, it's to make sure that the speaker is able to handle whatever the amp throws at it. Hence a rating greater than the maximum rating for the amplifier.
-- Torqy
Torqy is offline   Reply With Quote
Old 10th November 2007, 21:46   #13 (permalink)
jerish666's Avatar
Old 11th November 2007, 10:59   #14 (permalink)
Autophile's Avatar
What is the model no. of your Blaupunkt amplifier. Using appropriate HPF on HU / amplifier should help. If the jarring comes from the door panels then deaden them using damping material.
__________________
Danes Don't Lie !
Old 11th November 2007, 16:11   #15 (permalink)
montyguru's Avatar
Cool
that's right.
however, in most cases installers consider the fact that young guys wanting to show off their system would crank up the volume to the full... and if you do that, without knowing where to stop, God save the speakers. therefore a safer way is to have a higher rating speaker and a 20% lower rated amp, just like the dealer suggested. you may lose speaker potential by some margin... but then, atleast you won't go back to the dealer with a sub gone "kaput". in reality, unless you test... you wouldn't know, cause speakers react differently to different amps. it's all a mix n match and try n test funda. and ratings themselves have no parameters. ID subs, for example do not follow a sinewave, they follow a squarewave... and Polk doesn't have RMS, they have a thermal rating. hee hee hee hee.
__________________
life is a song!
montyguru is offline   Reply With Quote
Thread Tools
Speed rating? What if I cross it? nanu28 Tyre & Alloy wheel Section 13 14th November 2008 06:17
JD Power : Low rating for Baleno venkatrx The Indian Car Scene!! 46 18th May 2006 09:04
rating auto magazines kallil The Indian Car Scene!! 1 20th March 2005 02:05
Euro 3 and Octane Rating rahulmd Modifications & Accessories 5 19th January 2005 10:41
Euro NCAP rating Revvmaster Technical Stuff 0 26th May 2004 01:26
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
