| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #1 (permalink) |
| Newbie Join Date: Oct 2006 Location: Trivandrum
| Is there any advantage in using ports with larger diameters? To get the same port frequency, larger diameter ports need to be longer than narrower ones. I see this as a disadvantage because, as the port gets longer, it starts dictating the dimensions of the enclosure. My sub manufacturer has recommended a port with 3" diameter and a length of 10.04" to achieve a tuning frequency of 35hz. Using the port length calculator at Subwoofer Enclosures - Fraction to Decimal, Parallel, Series, Port Length and Volume Calculators I found that using a 2.4" diameter port, the same frequency can be attained using a shorter length - 8" Why then would a manufacturer recommend a larger port? Is the sole purpose of a port just for attaining a desired tuning frequency? If so why cant it be achieved using the diameter and length that best suits the user needs? What effect does the tuning frequency have on the sound output? Which is better? A lower tuning frequency or higher? Or better still, what is the ideal tuning frequency to have for an SQL application? I'm starting this as a new thread so that this becomes a single and unified source for all porty knowledge. |
| | #2 (permalink) | |||
| Team-BHP Support ![]() Join Date: Mar 2007 Location: Bangalore
| Quote:
If by output you mean "loudness", it is independent of the frequency the sub system is tuned for. There are no 'ideal' frequencies - it is matched to the driver. Of course, there is always the design objective - towards which a suitable driver is chosen, and then a box is designed.
__________________ Never believe it cannot be done - it's only that you haven't found out how!!! | |||
| | #3 (permalink) | |
| Quote:
I didnt mention cost saving as an advantage. Its just that I prefer a straight pipe and I wanted to know why one would have to bend the pipe if the same tuning frequency can be achieved with a less dia pipe. And yes you answered that question. The AR 65V, a flared port, has an internal dia of 2.4" I'm still looking for answers to other questions. Here's one more. On what basis does one decide upon the tuning frequency? I know it depends on the box volume. But assuming I can build a box of any volume and a port of any length/diameter, how do I decide upon a particular tuning frequency? | |
| | #4 (permalink) | |
| Sure, but what about the pipe behind it that you have to pick up locally? Quote:
That tuning frequency depends on what driver you pick up (sub characteristics, incl. Fs) and how low you want to hear the notes. Sometimes you don't want to go down to the 1st octave, if the kind of music you hear doesn't have instruments that do. Don't confuse it with the apparent 'goodness' of bass - not much is actually heard but felt (not everyone's ear 'listens' down to 20Hz) and that feeling is actually bolstered by sub and mid-bass drivers' ability to reproduce in a controlled manner the overtones (harmonics) of the lower notes. So, if you use a good sub and a bad mid-bass, the result would still be lacking. Bad drivers & systems make the harmonics linger around longer than required making the music sound "boomy" and "muddy". The advantage of the bass-reflex (ported) enclosure is that the system mechanically boosts the output produced by the driver around the tuned frequency. But not that it can make 45Hz Fs driver sound like a 27Hz Fs driver. So, rolling back to the start, first you select a driver (sub) based on what you need: Price, Loudness (electrical power handling AND driver sensitivity), size (depth), construction (frame, coils, ventilation etc.) and mech/elect parameters (depending on Q, some sound best in a sealed box, some in higher order like BR). Follow LBM's process - he is doing it right now. He has been using IDQ divers in a ported box, and his system is SQL (he got 152.7dB of LOUD but accurate music). He is now revamping his bass system - and has just selected a driver. Navin, B&T, Gunbir et al have written a lot on the forum regarding driver selection and influence of different parameters - search and read, that is the real Knowledge Base.
| | #5 (permalink) |
| You dont have to "fix/attach" any pipe behind the AR 65V. It is a complete product in itself. DerAlte, thanks for your time in posting this long reply.. But, I am not looking for options/process suggestions as to my ICE upgrade/subwoofer selection. I already have a sub. All I intend to know is about ports in this thread(Specifically answers to questions I've asked). Anyone else who can chip in with answers to the questions.. please! |
| | #6 (permalink) | |
| Senior - BHPian Join Date: Mar 2006 Location: Bombay
| Quote:
However, in car audio, high excursion designs mean that you should choose a port size larger than what may be indicated as per this rather home-audio based chart. (I cant find a link to it) | |
| Thread Tools | |
Similar Threads | ||||
| Loan Closing - Some doubts. | HKP | Indian Car Loans & Insurance | 48 | 13th October 2008 00:36 |
| endcan for diesel-doubts | ram_hyundai | Modifications & Accessories | 2 | 1st December 2007 18:10 |
| More Impedance Doubts | 929RON | Ask the Gurus | 8 | 6th July 2006 15:01 |
| Doubts | qqplus | Technical Stuff | 15 | 10th February 2006 23:20 |
| Doubts abt airbags | speedsatya | The Indian Car Scene!! | 4 | 5th September 2004 14:20 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
