Closed Thread
Thread Tools
Old 11th November 2007, 00:49   #1 (permalink)
navpreet318's Avatar
Smile ICE for Laura DSG
hey people,
after a long long session of brain storming and test drives
i've just booked a laura dsg.
this was partly because my baby sister has a lot of say in the family and she simply loves the laura.so over-priced or not laura's the one.
so i am planning to change the ice setup.
i want a SQ setup.
the laura takes in a 3 way setup in the front and real doors.
fronts getting 6.5" woofer,3" mid and 1"tweeter
likeways for the rear with the diff being a 5.25" woofer.
now the route i am planning might be a bit different.
this is what i have in mind.
1.connect the 4 woofers seperately to a 4 channel amp in with a low pass filter.to deliver the lows say 100-200hz
2.connect the four 3" mids and tweeters to another 4 channel amp in an above 200hz filter through a crossover.
3.use a mono sub amp to power a small 8" sub to deliver tight crist bass without sounding loud.
won't be hearing very very loud.
just occasionally turning it up for my fav songs.
mostly i like vocals.with tight base.
i don't like brightness.tend to give me a pain in the ear.
now i have selected hertz seperate components to use in the install.
hv 165L
hv 130
hL 70
ht 25
hx 200 in a tuned for tight bass box
or if budget permits
a ML 2500.1
now are there crossovers available seperately or are the in built on the amps to cover the different frequencies
sub: 30-100hz
woofers: 100-200hz
mids & tweeters:200-22khz
i will be keeping the stock HU so i would be needing an amp with high level inputs.
maybe the audison Lrx series.-4.1k
what do you say about this plan.
how would the system sound if i use a 2 way 5.25" component in the rear speakers.
this way i could save on one amp too.
any and all suggestions are very much welcome as i am a novice at this and have only superficial knowledge
prices of the above components would be essential as they will be the deciding factor.
looking forward to inputs from all ICE enthusiasts and gurus.
navpreet318 is offline
Old 11th November 2007, 11:30   #2 (permalink)
Autophile's Avatar
Congratulations Navpreet for your Laura.
And regarding the ICE you have listed quite an elaborate setup.
The Hertz components you have selected are straight fit in Laura stock locations. I believe DSG comes only in L&K trim which has got 3 -Way in the front (6.5") and rear (5.25").
If you intend to keep your stock unit. Then I would recommend that you go for the passive sets HSK 163 (HT 25 + HL 70 + HV165L) for the front and with HV130 for the rear. If you drive on your own you can go for cheaper option of 2-Way HSK 130 in the rear doors.
This way you will save a lot of money on the amplification as you need only one 4 channel amplifer.
The way you have mentioned it is expensive (more amplifiers, more cables) and does not offer you any advantage over the passive setup. You need multiple channels of amplification with mandatory bandpass filter for midrange driver. The cheapest option will be 2 X LRx 6.9's, one for the front stage and the other for rear. Hence stick to passives powered by 4 channel amplifer like LRx 4.1K
For subwoofer section I would recommend minimum 12" Subwoofer running off an LRx 1.1K or LRx 2.9 (Bridged) depending upon subwoofer choice and coil configuration. For subwoofer level control you need Audison VCRA.
All LRx amplifiers have speaker level inputs and preamp outputs.
__________________
Danes Don't Lie !
Autophile is offline
Old 11th November 2007, 15:46   #3 (permalink)
well just went through the prices in some uk sites.everything i planned has gone out of the door.
it seems that it'll be better if i use a passive 3 way in the front (HT 25 + HL 70 + HV165L) and a 2 way rear (HSK 130)
that way one 4 channel can power in this order:
front channels:HT25+HL 70+HV165L with a passive crossover
rear channels: hsk 130
and the sub can be powered via a mono amp.
i think this is just what autophile just said in the above post and i just rephrased it.
just checked out the prices of the lrx series in a uk site.man! they're so damn expensive.
can you help me out with some other high level input amplifier.something in the range of 20k for the 4 channel and 20k for the mono.
suddenly the GTO 75.4 is coming again and again in my mind.too bad its gone.
i haven't heard that amp.
if the 75.4 can be comparable to a 20k four channel then let me know where can i get a left over.preferably around delhi.
i'm looking to a budget of approx 80k +- a little bit.
help me out guys.
Old 11th November 2007, 15:49   #4 (permalink)
i'm so confused now that i'm looking at other speaker ranges too.
the infinity reference series is good too.i have that in my swift. they sound very very good and i think the kappa series isn't too expensive too.
i'm going bonkers. next i'm gonna be surfing the sony site.
so help people!
Old 11th November 2007, 16:18   #5 (permalink)
montyguru's Avatar
so help people!
great. go to onlinecarstereo.com, crutchfield.com and get more confused. sony doesn't have 3-way at least in the india line up.
__________________
life is a song!
montyguru is offline
Old 11th November 2007, 18:24   #6 (permalink)
clipto333's Avatar
hi,
you have made an excellent choice of getting the hertz hi-energy components and audison amps.
in 80k i would suggest you get the 3ways for fronts and 2 ways for the rear. get the audison srx amplifier. a mono with a 4 channel or a 5ch amp. and get a 12" sub as an 8" will be too small for the laura. a 12" in a sealed enclosure will be nice and tight.
please keep a budget for wiring and install. connection audison are good quality wires.
do listen to other brands before deciding.
cheers
clip
clipto333 is offline
Old 11th November 2007, 19:14   #7 (permalink)
other brands is exactly what i am thinking.
the Lrx series seems to be out of my budget.
how is infinity reference series compared to the sxr of audison.
the prices seem to be reasonable.
especially the mono ref611a and the ref7541 or the ref475a
also the infinity kappa 1.7cs seems to be a good 3 way.
if anyone knows the exact price of the same please let me know.
Old 11th November 2007, 19:16   #8 (permalink)
also do only the audison range have high level inputs.
how are other amplifiers connected through high level inputs.
Old 11th November 2007, 20:25   #9 (permalink)
ok so here is another tentative list-
infinity kappa 1.7cs 3-way components
infinity kappa perfect 12.1 subwoofer
infinity reference 611a amplifier
infinity reference 7541a amplifier
so can any one let me know the prices of these components.
Old 11th November 2007, 23:13   #10 (permalink)
low_bass_makker's Avatar
Nice equipment which is priced quite good and sounds good also...and that to in your budget.
Originally Posted by Sam Kapasi View Post
The picture i posted.. that is the Kappa 1.7CS, this is for 17,990/- with BW
There is also the Kappa 1.5CS this has a 6X9" woofer along with 4" midrange and tweeters. This is also for 17,990/-
Prices and specs of the Infinity amps...not the same model you mentioned. but will do fine in your case..
Originally Posted by low_bass_makker View Post
they are Ref475a (Rs 14990) and the Ref1600a (Rs 19990)
Infinity - Car Audio
low_bass_makker is offline
Old 12th November 2007, 00:51   #11 (permalink)
gunbir's Avatar
Infractions: 0/1 (4)
Those Infinity Kappa Perfects are nice speakers. Just ensure you will be able to fit the 4" midrange in the stock location. As far as I can recall, the stock Laura 3 way uses a 3" cone midrange. So do your homework before you buy.
__________________
Often imitated, never duplicated!
gunbir is online now
Old 12th November 2007, 07:45   #12 (permalink)
ScarySkulls's Avatar
Oh my dear dear old friend Navpreet. Congratulations for the Laura DSG. Glad you picked that car over Skoda RS. I'm happy sense prevailed and you said a Firm NO to the "Slush Engine".
Anyways. Very good choice of equipment. I'm impressed with your homework, as always.
Enjoy the stock Laura ICE for a little while till you do your homework well. Keep off your money spending untill you do a well enough demo of your selected brands and have compared them well to the Stock ICE in laura. (which is pretty good anyways)
You can call me anytime you want and eat my head for discussion on ICE, just like I eat yours for discussion on superbikes. haha.
ScarySkulls is offline
Old 12th November 2007, 09:48   #13 (permalink)
alright gunbir i had thought that that 1.7cs uses a 3" mid.
if its a 4" then its out of the equation then.
well rajat thats what i'm planning. run the car stock till december-jan starting.
make a trip to delhi in jan first week or so and get some work done on it.
i'll have a discussion with you soon enough.
gunbir i was actually planning to get the install done from you in delhi.i know how shoddy the work is in dehradun.i would never get it done here.
i'm in the planning stages right now.setting the budget for different things like performance mods,ICE and other mods.
can you suggest any other SQ combo which will stay in this budget and be a substancial upgrade on the stock ice.
Old 12th November 2007, 10:11   #14 (permalink)
gunbir's Avatar
Well Navpreet your budget is fine more or less. Its just that there aren't many brands available in India that have a direct replacement for your stock speakers. In most cases you will have to do some mods / cutting on your door panels.
Go for a multichannel amp as that will help conserve space and cabling. There are many amps that have high level inputs now.
It would help us to know your listening preferences like how much bass you like etc.
__________________
Old 12th November 2007, 10:34   #15 (permalink)
well i don't like too much bass .
love hearing good music with vocals.where every thing is in perfect coordination.
i haven't heard too many speaker systems but to give you an example i love the bose wave radio.it have perfect everything an less of treble.
so cut it short i like bass which supports the music and does not over ride it.and i don't like treble at all.gives me a big headache.
and what ever bass is there should be tight and punchy.not fluffly.it should be there in extremely short bursts.
that is why i was initially looking for small 8" sub which would run in coordination with the rest of the music and not over power the music with its bass.
bass should be there where its originally meant to be.
i have seen and owned systems which put bass even in the non bass songs. and i don't like that.
thats a long detail.hehe.
Closed Thread
Thread Tools
Skoda Laura Ambiente-cheaper Laura deuce-deuce The Indian Car Scene!! 94 11th July 2008 07:53
Laura Elegance ICE Setup brett Ask the Gurus 82 5th November 2007 14:32
Facelifted Octy, Cheaper Laura EDIT : Laura Elegance ajmat The Indian Car Scene!! 139 27th August 2007 11:47
Skoda Laura manual or DSG(auto) ? atul_chabra Sedans 19 28th July 2007 12:25
Whats the fastest way to drive a Laura DSG? GTO The Indian Car Scene!! 30 8th January 2007 09:40
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
