Thread Tools
Old 5th December 2007, 08:44   #16 (permalink)
hydrashok's Avatar
As always, I'm not in favour of bypassing the HU. If you take the big picture, you will need a HU somewhere down the line.
HU: I'd back Raghu on the Pio6950. Good HU is you're particular about 3 preouts *and* iPod connectivity. If you're not particular about the iPod, but 3 preouts are a must, you can get the 5950 and save abit of green.
BTW, why 3 preouts? You'll need 3 preouts only if you plan a 4ch amp + mono amp setup (and so naturally 4 speakers + sub) in the future. If you do, by all means, get a 3 preout HU. Else, if you'll be ok with a single amp setup (fronts and sub running off the amp, and the rears running off the HU) in the future, a 2 preout HU would do. Even a single preout HU would do, as you could fade the fronts and rears, keeping the sub-level constant. You'll get far more options for lesser if this is what you plan to close your setup with. You can settle for the Pio2950, or go for the Alpine 987x (single preout, but still has full speed iPod control, and I wager it will sound better than most HUs in the 8K range)
Speakers: You've got it right. Get comps in front. You can run them off the HU first, and then from an amp later. Since you have a limited budget, but still want low-end punch, I think you should leave the rears out, and get a sub instead (later), and get the rears last, if you really feel the need for them. Speedzak has mentioned all the options you can consider. The JBL GT5s will be 4K for a 6.5'' comp. You'll need to cut the front door panels for a 6.5'' comp, or get a 4'' comp from Illusion for the stock location in the dash.
Sub: A GT5-12 (5K) or a CS1204 (4K) should be fine.
Amp: 5k is good enough for the Blau GT4 special. But this amp will not drive a sub in a sealed box. It will be god enough for comps and 6x9s. A sub in a ported box or a bass-tube would sound ok with this amp. Other options would the upcoming GT5 series amps from JBL and Pio amps (the 6700) at about 7-8K. The kenwood amp you mentioned KAC8401 is reportedly a pretty good sounding amp.
You step-by-step plan is good, and the only change I'd suggest is to leave out the 6x9s as you really won't need them once the sub comes in. you can always get 5.25'' coaxials or 6.5'' coaxials for the back. And of course, I'd suggest getting a HU in the beginning, with the comps. You can get a 6K HU and 4K comps now. Or wait a while and get a 6K HU and 6K comps.
And as FlyingBong said, it would be a good idea if you fix a total budget for the ICE. It will help you decide on how much to spend now (and on what stuff to buy now).
[This has gotta be the biggest post I've made from my phone. please forgive typos Editing a post is tough from the phone]
__________________
Alpine 9887 | TRU Tech S44 | Image Dynamics XS65 | Image Dynamics IDQ12 D2V2 | Connection Audison
hydrashok is online now   Reply With Quote
Old 5th December 2007, 08:58   #17 (permalink)
MillionSwords's Avatar
Infractions: 0/1 (4)
Post Thank You So Very Much!
SpeedZak bhai,
I had seen you at the Autocar, but did not barge in to say hi, I repent for it now!
Thanks a million for the so long summary, it really makes me happy, that you guys are thinking in tandem for each other in the forum. Web2.0 has so much advantages we never knew when we made sites.
Back in topic,
1. Thanks for the compliments
2. It is not an iPod, it is a Personal Media Player from Philips. I would never buy the iPod, with knowledge about PMPs from gen1, I was one of the first buyers of MP3 players way back in 1998/99 when MPMan was rolled out!
3. Nice correction there to get the Subs after the Compos!
4. I would like some dampening too! Thanks for concreting my idea!
5. Will surely get the HU, and I don't fiddle with the MP3 player, it is a breeze to use unlike most of today's HUnits! Playlists save the day!
6. So you suggest I keep the wiring part to the last step - how much does the twister wiring cost?
7. Oh yeah, the monoblock was always there in my mind with the Sub, but the order in which you placed it different from mine, which makes more logical sense! [as per ur suggestion, A pair of Compos + 4ch Amp + Subs + Dampening is wonderful]
Hmmm about the next car, lets see - I love the Sonata and the Lancer, if the Zen bugs me I will make a decision, but the first car centiment might irk a bit, lets see how far I can shake it off?
[After so many offers for my 5Speed Yamaha, I have never felt the reason to give it off!] The Zen Estilo is not a Yam I agree!
Originally Posted by speedzak View Post
I am really impressed by the way you have planned to do your setup in step by step. Ofcourse, there would be some corrections I may like to make. But going the step by step way is very very correct if you are short in moolah.
I'd say, get the components and amp first. Run it off from the MP3 player (is it an iPod?). Use 2channels from the 4channel amp for this. Then (when your moolah permits) you should get a subwoofer and run it off the other 2channels from the amp. Get some damping job on the doors and boot. You should be SET by now.
You may want to add a HU soon. Infact, you should get one. Fiddling with the mp3 player menu while driving is not something I would recommend. Get a good HU with some sort of mp3 player connectivity (iPod control, if it is). Whatever the world may say about compressed formats, there can't be anything more satisfying than the good ol' audio cds. I would recommend you to get the HU as soon as possible.
After you've done so much, then you may also add some sort of rear fills. Usual 6.5" coaxial speakers from the same range as your components would do. Run it off from the HU itself. You may also increase your damping a bit as necessary. Now, you should've reached a full SET system. Bilkul SET!
Let some more moolah come in. It's time to get some good wiring. Yes! Earlier, you could've even used any normal wiring such as Twister, visionik etc.... Now, you can spend some hard earned greens on brands like Monster, Connection Audison, EFX etc... Get good power wires, RCAs and speaker cables.
More moolah? Time to add another amp to your setup. Yes! A good monoblock which can bring out the real music out of your sub. Switch off the internal IC of your HU, power all the speakers thru the 4channel amp and the sub via monoblock. You will also have to add a distribution block to the power line between the amps.
Now, You'll have a full perfect setup. But being the upgrade bug bitten you, it'll be not long before you think about better, bigger amps/components/sub etc... But for that, you need a bigger/better car as well. You're always welcome to come back here then and we'll be glad to help you in what car section and once again here, in the Wicked ICE section.
Regarding good brands to look out for while shopping;
HU: Pioneer comes first choice in features and VFM, Alpine comes in for good SQ, build quality and higher costs, JVC for good VFM and so does the Kenwoods.
Components: JBL comes first in VFM, Hertz and Illusions are famous for their mindblowing SQ with a bit higher prices and you can stay away from Pioneer, Fusion etc...
Amp: The Kenwood you have chosen will do it's job well. You may also check the JBLs, Pioneers, Alpines, Audisons, Genesis etc... Stay away from Sony, Auzo, Fusion and other unknown brands.
Your next car: Mercs are a good choice but expensive for ICE. Maruti cars are ok for ICE but they tend to rattle a lot that means more damping. Hyundai makes good cars for ICE. After zen estilo, the perfect car to upgrade would be the ...... Huh! This is the ICE section. As I told earlier, Let's discuss that in What car section later.
Some more guidelines which just came to my mind.
1. Regardless of the brand, choose what your mind is happy with.
2. Don't take any shortcuts by buying many lower quality stuff together and regretting later. Buy the best with your hard earned money and keep the rest aside for the next upgrade/step.
3. When you're done with/doing the setup, we will be very happy to read about it and see pictures of it. That actually makes our day more than anything.
4. All the above words are according to my liking and thinking. Think twice and hard before you decide to implement any.
All the Good lucks with your ICEing!
__________________
Cheers,
MillionSwords
MillionSwords is offline   Reply With Quote
Old 5th December 2007, 09:19   #18 (permalink)
Post I love you guys for this! - a super long post from a Phone! whoa!
Ok I made you to speak - Me Happy!
I agree with your idea of "NO Hu No favor"
But you and a lot of other people mistook the idea.
The idea of running the setup from my MP3 player is to cunningly bring in the Amp into the setup, and then buy a good HU. it paves way for my step by step upgrade, I never wanted the setup to sound Best [to my ears] in the coming 2 or so months and I decide - OK This is done!
I would have settled with what ever I have bought if I bought a HU + 4 speakers. Dhud - no dhum in the ICE section then - right?
Well Ashok,
You and Speedzak made the same point, and thus concreting my idea on a Sub and Dampening! I was miserable in deciding a 6x9er for the rear before the Sub, I should have thought, but when you fellas think for me I can take the privilage of making small mistakes. Hehehe
2. The 3preout thingie, I discussed with B&T Bhai and thought 3preout is needed if i plan to go for a upgrade over the period of time. I agree we can live with a 2 preout comfortably!
I need to list the 2 and 3 preout HU's and See the feature list and compare before I take a plunge!
- no the Estilo comes with a 6.5"door panel, but I may need to cut the Plastic Grill area.
I replied earlier to Flyingbong.
__________________
Cheers,
MillionSwords
Old 5th December 2007, 10:55   #19 (permalink)
low_bass_makker's Avatar
Since you are in mumbai I would simple contact Ajay Bhai (Bass&Trouble) on this forum and all your dilemma to install the setup will be gone.
Old 5th December 2007, 11:12   #20 (permalink)
Bass&Trouble's Avatar
I'd say, get the components and amp first. Run it off from the MP3 player (is it an iPod?). Use 2channels fro.
Was this just another helpful post or an entry for the ICE Section Threads' 'Hall Of Fame'?
Bass&Trouble is online now   Reply With Quote
Old 5th December 2007, 12:05   #21 (permalink)
Flying Bong's Avatar
Originally Posted by MillionSwords View Post
6k Every 2 months gap, if nothing else comes up...
Hope you get the idea?
I agree with Hyrdashok's suggestion to buy a HU first. You could consider the following phased plan, with about 3-4 months gap b/w each step:
Step 1: HU (2/3 preouts) + front components
Step 2: 4-channel amp + wiring
Step 3: sub + damping
Do consider spending a little more in Step 1
Rear fill/6X9 is not really necessary if you drive yourself most of the time.
Flying Bong is offline   Reply With Quote
Old 5th December 2007, 13:06   #22 (permalink)
I met B&T Ajay Bhai, he was so nice to have come from All the way down from Parel to santacruz to show me the Illusion Electra, though he works for Illusion, he extended such a friendly gesture, and I'm thankful for that.
We had a nice long chat, and will surely meet up again before setting up my ICE. I liked the Illusion Electra, it was subtle, and had nice features, it was not too bright, nor too subtle. I would attribute the thump in his car to the Sub and Speakers at the rear with some 2 AMPs, and Oh yeah a lot of dampening. Still I liked the Electra Compos.
II. Thanks to Pankaj Bhai, he was a very warm and nice man, just love the way he smiles and tells about his thingie with a neat touch of experience. FMDrive showed me how the MP3 player(generally called iPod) + AMP + Speakers would sound. It was just the right kind of stuff I wanted to listen to, and I fell in love with the setup immediately. I listened to the numbers I wanted to listen to, and love them! [[ @vebmetal - No doubt it works, and it sounds A M A Z I N G!! Just perfect man!]
One second I thought why not just Buy the 2CH Kenwood amp + The JBL CS Series 70 Watts Coaxial 6x9ers (used here for demo) and stay in peace! It sounded so neat and got the required thump and nice notes.
I'm yet to listen to the JBL Compos - Sam ji can you tell where I can get a demo of the JBL 6.5" Compos (guess the GT5 series?)
I wish to listen to the Hertz Compos again. I will go to the Blau showroom today, listen to the Blau 6.5" Compos and then decide on the Speakers.
Anyone willing to show me their Compos, Any Brand that we discussed here and in the range of 5-6k Please contact me through PM and I will be thankful for taking a few minutes of your precious time.
__________________
Cheers,
MillionSwords
Old 5th December 2007, 13:10   #23 (permalink)
DerAlte's Avatar
Surely belongs to the "Hall of fame". @speedzak has excelled himself - this post was close to being poetic!!!
@MillionSwords, there is nothing inherently wrong in your plan - as long as you are able to get the prices to control the budget.
I am sure @B&T-bhai will be able to get you a real good deal for the Electra 6.5" for the front. The Hertz Deici would also be around the same, as would the JBL GTO607. Blaupunkt Velocity V6 Vantage would be a bit lesser at 5.5K. These would give a more than decent mid-bass whack. All the other eligible models would cost more: > 8K.
An alternative for the amp could be Blaupunkt GTA280 @5.5K (with b&w; lesser if you get a discount) - 2 channel with "Direct Aux-in" which will give you fuss-free connection for your PMP, and has adequate power. Wiring can be much less than the 3K you have assumed - you have to select the economical, not cheap.
When you upgrade, you can get a better 4-channel and use the 2-channel for rear fill with the 6x9's. 2 channels of the 4ch amp could be bridged to drive a sub (adequate for the Estilo, unless your likings grow to deafening proportions).
In a way, it is better to go for coaxials on the rear doors and add a sub as step 2, instead of the 6x9 on a parcel shelf in the Estilo (somehow, I can't get myself to call it a Zen; can't think of doing 170 in an Estilo that I did in the Zen).
@blueraven has put a sub under the seat of a M800 - I am sure you can too. Being up front, this arrangement is likely to be less power hungry.
__________________
Never believe it cannot be done - it's only that you haven't found out how!!!
Old 5th December 2007, 21:33   #24 (permalink)
I searched for "Illusion Electra", "Illusion Carbon" and "Illusion Component" in google, and found results only from TBHP and no where else. But Illusion audio had much more results.
Is the Illusion Audio Speakers relatively new to the market? or is that there are just no results in google? Just wondering?
B&T might pop in with some clarification?
__________________
Cheers,
MillionSwords
Old 6th December 2007, 13:39   #25 (permalink)
Illusion Audio web site:
::* i l l u s i o n** a u d i o* ::
Old 6th December 2007, 15:49   #26 (permalink)
The Electra is a 2007 line. Carbons were the first Illusions. Been around since about '97, I think. The Lucents debuted around 1999 or 2000.
__________________
Operator! Give me the number for 911!
Old 6th December 2007, 19:21   #27 (permalink)
Default Illusion EU series
And now the Illusion EU series is being launched.. Was wondering whether available in India too?? Waise what do you think about this new series from the shelves of illusion... Any idea of there price range??
Perry is offline   Reply With Quote
Thread Tools
ICEing Baleno.. pl jump in to help Merlin Ask the Gurus 17 30th November 2007 13:23
ICE setup in my Estilo - Kudos to blueraven Krato Sound Off and Show Off 31 20th October 2007 18:46
Portable Jump-Start Packs rameshspassion Technical Stuff 3 21st March 2006 11:30
Need a jump over 3230 sinner Gadgets, Computers & Software 28 13th October 2005 04:21
Do you jump red lights? tsk1979 Shifting gears 72 10th October 2005 12:09
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
